Jump to content
AVIC411.com
  • Replies 720
  • Created
  • Last Reply
Top Posters In This Topic
  • Unpack downloaded file into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working).
  • Your device will reboot into testmode.
  • Select Write program forcedly => Copy Script, script will patch your system and reboot.
  • Remove USB stick after script finishes.
https://mega.nz/#!eNg0TI6D!_FWOYJV3zPJzx6NcRp6fJu6TVAjzv16xWJOox9qIEhA
I'm on same problem asking for sd card on iGO start but the file is not hosted anymore. Can you put the file again, please?! I think I lost my gps from the central even trying flash the firmware again. Thank you antecipated for the atention.
Link to post
Share on other sites
  • 2 weeks later...
We have finally cracked pioneer navigation software (iGO NextGen)
Now, you can put any content on the device for which you have a working license.
After installing the patch, your maps software will take any content with any valid license for that content.
Even if the license from another device (check of license hardware id (SWID) is disabled in our libraries).
You can copy manually content and licenses through File Manager, using copy_script or by inserting internal sd card into your PC.
Don't forget to set proper filesystem rights to newly copied files.
 -  x000(5000-8000NEX F960BT/DAB F60BT/DAB)  FW 1.07/1.08
attachicon.gifx000_1.07_9.18.13.411863.rar
 -  x000(5000-8000NEX F960BT/DAB F60BT/DAB) FW 1.11
attachicon.gifx000_1.11_9.18.28.610126.rar
 -  x100(5100-8100NEX F970BT/DAB/TV F70/77DAB)  FW 1.05
attachicon.gifx100_1.05_9.18.28.610130.rar
 x200(AVIC-x200NEX/AVIC-Fx8x )  FW 1.00-1.01
attachicon.gifx200_1.00_9.18.28.624842.rar
Use latest winrar5 http://www.rarlab.com/download.htm
For 5000nex-7000nex and 5100nex-7100nex users it is possible to add all features of 8000nex/8100nex:
  • 3D Landmarks,
  • 3D City Map,
  • Natural Voice Guidance,
  • Enhanced Junction View & Realistic Road Signs,
  • Free Lifetime Traffic by Total Traffic Network
Instruction to install patch
  • Download file corresponding to your navigation version. You can check your version in About/Version information in maps application.
Now you have have cracked version of maps software. This version will accept any valid licenses, even licenses not for your device.
You can find new content and licenses using gpspower.net or 4pda.ru:
http://www.gpspower.net/igo-maps.html
http://4pda.ru/forum/index.php?showtopic=141926
Adding RDS-TMC for the 5000/5100 NEX
attachicon.gifTMC UC.zip
pass: 4pda
  • Download file
Adding TTS languages
Is available in 16 TTS languages
You can add any of the available languages
TTS download files you can on 4pda
http://4pda.ru/forum/index.php?showtopic=200728&view=findpost&p=46123907
dan.dnk.naja
deu.deu.hans
eng.gbr.amy
eng.usa.salli
fra.can.chantal
fra.fra.celine
ita.ita.carla
nld.nld.ruben
pol.pol.jan
por.bra.vitoria
por.prt.cristiano
rus.rus.tatyana
rus.rus.maxim
spa.esp.conchita
spa.usa.penelope
tur.tur.filiz
If you have the latest content, you can share your license and content.
This will help other owners!
We also looking for 2015Q2 licenses from 8000nex/8100nex.
if you need the latest information
you can get it on 4pda.ru
http://4pda.ru/forum/index.php?showtopic=698751
I have installed this for 2 weeks now, and my Pioneer 5100nex is a lot more buggy than before (carplay hangs for 10s every so often, siri is very slow, ...).
How can I remove the mod and go back to factory?
Link to post
Introduction
WhatIsBypass, AdamOutler and myself present
The AVIC Development Mod
We have eliminated the barriers to development on all AVIC units including Android Auto. You can now create your own ROM on an SDCard and boot directly into it. We've broken all the security and obfuscations, and we've delivered it to you in a nice, easy-to-use web user interface. This has essentially turned the Pioneer line of units into Nexus devices, that boot off SD Cards.
We now have the ability to change the NEX BSP Settings which allow us to unlock the SD Card and change the boot settings that are in the Pioneer NEX. We are asking all ROM developers with a NEX step and help us create our own ROM to run on all versions on the NEX System.
With the help of all you we can begin to add USB Wifi Drivers, a custom app launcher, the play store, interface skins, more radio presets, radio station data augmented by the internet, Android Auto, iDatalink Gauges, and much more only limited by what we can develop.
NEVER ENTER COPY DEVICE MODE, YOU WILL BRICK YOUR DEVICE!
It is fixable though but a pain as described by WhatIsWhat
Overview
Here's a quick overview of what we will do in this post.
Overview Steps:
1. Backup your current BSP and Nor Flash
2. Backup your current internal SD Card, or obtain a backup SD Card Image.
3. Navigate to https://jenkins.casual-dev.com/job/Customize%20BSP/build?delay=0sec and select the options you want
4. Remember your build number and download your package.
5. Extract to USB stick
6. Put it into USB Port 1
7. Run Script.
8. If you removed the SD Card password you need to insert a new internal SD Card with a backup image.
9. Done!
How To
Let's talk about the details, now.
Run Copy Script Mode:
1. Insert the USB Stick to USB Port 1 on the device.
2. Start the deck, it will then reboot into Technical TestMode. You must use the keys to navigate the menus. BE VERY CAREFUL AS SOME OPTIONS CAN BRICK YOUR UNIT.
3. Use the Vol - button to navigate to "Write Programs Forcibly"
4. Press the Home Button to select this menu
5. Use the Vol - button to navigate to "Copy Script"
6. Press the Home Button to select this menu
7. Take note of the Values on the right hand side of the screen, THESE WILL BE ERASED. (It is currently unknown if these will be needed in the future). If you really want to keep these values though, you can write them down and place them in the corresponding SDCardCWWVersion.txt before you continue.
8. Press the Home Button to run the script.
9. After it says 100% press the Home Button to reset the unit and remove the USB stick.
Full Steps to get to a development state:
1. Backup your current BSP and Nor Flash.
See http://avic411.com/index.php?/topic/81469-avic-development-mod-device-backup/ for this.
2. Backup your Internal SD Card (Skip to 3 if you have an unlocked image you want to use)
3.Install a Customized BSP
A. Navigate to https://jenkins.casual-dev.com/job/Customize%20BSP/build?delay=0sec
B. Select the options that you want to enable. The currently known defaults are already selected. For development select debugSwitch: Debug On Console On, subBootMode: Disable Warp, choicePassword: Remove the Password
C. Click Build and note the build number that was started on the left.
D. Navigate to https://jenkins.casual-dev.com/job/Customize%20BSP/NSERT_BUILD_NUMBER_HERE/artifact/ where INSERT_BUILD_NUMBER_HERE is your build number.
E. Click the (all files in zip)
F. Extract the contents of the download to a USB Stick. (FAT32 or NTFS)
G. Follow the "Copy Script Mode" steps.
H. The unit when it reboots should error out because you removed the SD Card Password lock.
4. Insert an Unlocked Internal SD Card Image
A. dd the AVIC.img you backed up to an SD Card of the appropriate size.
B. Insert the new SD Card into the Internal SD Card slot.
C. Start up the unit. NOTE: It will take a bit for the device to boot since you have disabled WARP above.
5. Congrats!!!! You can now remove the internal SD Card at will and modify the items in the partition and put it back into the Deck. Good luck on your Custom Rom Development and be sure to share your creations!!
What we are now asking of the ROM Community:
1. Help us by developing custom roms using the steps above and sharing your creations.
2. Once we have a custom rom we want to share easily, we will get to the steps where we start Creating a new WARP snapshot, and recompiling them back into PRG Update Files.
3. Find a way to enable ADB, One option would be to add a Network Bluetooth Profile, Another option is figuring out USB OTG properly.
4. Lets create an app launcher.
5. Figure out how to modify the maps.
6. Figure out Android Auto/Bluetooth Audio on older models with the new software.
Additional Reading
Repo of the PRG recompile and TestMode Scripts: https://github.com/bassrock/AVIC-NEX
Pioneer 5100 Sources: http://www.oss-pioneer.com/car/multimedia/files/avic-5100nex/index.html
Pioneer 5000 Sources: http://www.oss-pioneer.com/car/multimedia/files/avic-5000nex/index.html
Update 8/13/15: â€‹We have found a new Developer debug mode that can be discussed and spend by following the steps here: http://avic411.com/index.php?/topic/81482-avic-development-mod-developer-debug-menu/
Thank you very much.
Link to post
hopefully someone out there can help me. im going crazy in my quiet drive to work every day
avic 6000nex. switched out battery. needs password.
i entered test mode
went into File Maintenance
clicked Storage SD
clicked System
the closest thing to "User" directory i have is "usr"
went into "usr" directory.
i see no "security" directory, therefore cannot find password.
SOMEONE PLEASE PLEASE PLEASE HELP ME OUT HERE.
(see attached pics of this step by step - Linux Root is highlighted in the 2nd pic because i also searched in every directory in there as well)
Link to post
One other thing is how do I know if traffic info is working or do I need a phone with the app installed or something to make that work?
Hey guys, so I have gotten that FW update installed and done the things in this post, got my 5100nex unit updated with new maps and everything on it etc. One thing I am still curious about though is if it is possible to make traffic updates and everything work? I'm not entirely sure what is needed to do to get this working properly, have tried installing files and licenses but traffic still shows up as red when I look at my files on my headunit as if it is not activated.
Link to post
  • 5 weeks later...
pass: 4pda
  • Download file
Does this work for the 5200 too or we need another file? On my 5200 the license filename is not the same, I think it is Pioneer_Primo_NF_something.
We need the license file from a 8200?
Link to post
  • 2 weeks later...
WOW!  This is just MARVELOUS!   I love it...
You have no idea how inspiring it is for me to just read through this thread  (I've only gotten through the first 3 pages and I couldn't wait any longer- I had to post immediately)  and see all the things you have discovered, learned, figured out, de-coded, etc...
Sincerely- it is a delight to learn that this type of development is going on.   For me, any "outcome" (ROMs that are developed & shared) will all be icing on the most fabulous layer cake  ;)
And @  bass_rock:   YOU rock!!!!    For real-  you are the coolest!   You are so articulate, well-spoken, organized, resourceful & creative- not to mention patient, generous & brilliant!
THANK YOU!
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
