Jump to content
The AVIC Development Mod
bsp avic development developer dev xda android auto android linux kernel boot
  • Please log in to reply
590 replies to this topic
#571 phile
phile
  • Members
  • 1 posts
Posted 15 August 2017 - 07:57 AM
I have an F77DAB currently running 1.05 with patched iGo and OK button bypass.
If I update to 1.10 can I install the same patch (only version I can find just states for 1.05) using the new test mode key?
#572 SpecTrax
SpecTrax
    Member
  • Members
  • 70 posts
  • LocationNorway
Posted 15 August 2017 - 03:04 PM
yes
Spec   :mrgreen:
AVIC-F60DAB  (EU)
#573 pyxisdk
pyxisdk
  • Members
  • 2 posts
Posted 19 August 2017 - 02:28 PM
Hi experts...
has anyone tried to install a Mexico map on an avic 8100????
Best
Klaus
#574 jhalttu
jhalttu
  • Members
  • 10 posts
Posted 02 September 2017 - 07:01 PM
Hi Guys, i can t paste new map on my avic F60 Dab, he says Failed to paste....Patch ok with good version, and copy ok , but i can t paste new file in exdata/igo/content...
helpppppppppppppppppp :shock:
Hi.
I Have same problem. I can copy all other files, but not Maps or licenses! I get "failed to paste" . Are those content/Maps and content/licence folders somehow write protected? I got to delete all files from content/map folder..
I did not delete licence.
My unit is 8200
script worked beautifully. I get "OLD" and "NEW" .TXT files.
I am trying to copy Map files that I downloaded from here:
https://www.gpspower...re-2017-q2.html
EDIT: My firmware is 1.01
#575 SpecTrax
SpecTrax
    Member
  • Members
  • 70 posts
  • LocationNorway
Posted 03 September 2017 - 11:44 AM
Hi.
My unit is 8200
i deleted the folders (maps and lic)  first, then re-added folder incl new files
Spec   :mrgreen:
AVIC-F60DAB  (EU)
#576 macucesal
macucesal
  • Members
  • 2 posts
Posted 13 October 2017 - 02:55 PM
We have finally cracked pioneer navigation software (iGO NextGen)
Now, you can put any content on the device for which you have a working license.
After installing the patch, your maps software will take any content with any valid license for that content.
Even if the license from another device (check of license hardware id (SWID) is disabled in our libraries).
You can copy manually content and licenses through File Manager, using copy_script or by inserting internal sd card into your PC.
Don't forget to set proper filesystem rights to newly copied files.
Spoiler
For 5000nex-7000nex and 5100nex-7100nex users it is possible to add all features of 8000nex/8100nex:
  • 3D Landmarks,
  • 3D City Map,
  • Natural Voice Guidance,
  • Enhanced Junction View & Realistic Road Signs,
  • Free Lifetime Traffic by Total Traffic Network
Instruction to install patch
  • Download file corresponding to your navigation version. You can check your version in About/Version information in maps application.
  • Unpack downloaded file into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working).
  • Your device will reboot into testmode.
  • Select Write program forcedly => Copy Script, script will patch your system and reboot.
  • Remove USB stick after script finishes.
Now you have have cracked version of maps software. This version will accept any valid licenses, even licenses not for your device.
You can find new content and licenses using gpspower.net or 4pda.ru:
http://www.gpspower.net/igo-maps.html
http://4pda.ru/forum...howtopic=141926
Adding RDS-TMC for the 5000/5100 NEX
attachicon.gifTMC UC.zip
Spoiler
Adding TTS languages
Is available in 16 TTS languages
You can add any of the available languages
TTS download files you can on 4pda
http://4pda.ru/forum...post&p=46123907
Spoiler
Gracias!!!
He seguido los pasos y he actualizado un AVIC F860BT, muchas gracias!! Eso si lo baje a la Version 1.11, y todo perfecto!!!
if you need the latest information
you can get it on 4pda.ru - rus lang
http://4pda.ru/forum...howtopic=698751
#577 mythbai
mythbai
  • Members
  • 11 posts
Posted 25 October 2017 - 08:15 PM
Spoiler
Is above file correct and updated? Someone help me please!
I can't get my 6000NEX into TEST mode. I saw 1.15 (latest version) in the download link, so thought it's better get latest FW update first. Now I'm on 1.15, with exact Navigation version 9.18.28.610126. I followed the exact process mentioned. But couldn't get into Test Mode at all.
Did I miss anything? I'm a IT professional, so I'm sure simple technical instructions are followed.
============ Updates ============
Sorry, I sort it out by keeping reading other thread in the forum. It turns out I need the goldenapple key in the download.
"just use the correct patch/crack,and use the new testmode key (goldenapple)"
#578 tintingti2
tintingti2
  • Members
  • 1 posts
Posted 27 October 2017 - 09:44 AM
Hello,
Is it possible to use the patch on a F860BT-C (camper)?
I transfer new maps, license ... with the testmode_A but my avic does not recognize the maps!
Thank you
#579 macucesal
macucesal
  • Members
  • 2 posts
Posted 28 October 2017 - 06:59 PM
Hola, yo lo baje a la 1.11, con la 1.15 no funcionaba, ahora va perfecto, coloque mapas de teleatlas y unas licencias, meti los radares y la verdad va muy bien. Un saludo, y gracias por compartir el trabajo
#580 davdhan
davdhan
  • Members
  • 5 posts
Posted 29 October 2017 - 04:57 PM
Hi,
Just got a Jenkins build on a 16GB USB, formatted  FAT32. The drive when plugged in USB1 (Apple usb port) is seen by the 8200Nex but it does not boot. The HU is trying to play the files from the USB
What am I doing wrong? The unit is 8200Nex on FW 1.07
Thank you
#581 dpratt1008
dpratt1008
  • Members
  • 10 posts
Posted 09 November 2017 - 06:46 AM
On the testmode_n keys, what do the Write Program, Write Bootloader, Write Boot, Write Recovery Platform, Write Opening Data options actually do?
From my reading, isn't the bootloader information in the NOR/BSP memory unique for each model number? I'm having issues with my unit immediately failing firmware updates so I believe some piece of my default system is corrupt and causes the firmware update to fail as soon as it starts...so I was hoping i could restore all of these things and not mess up my unit. But I didn't want to use the features on these testmode_n keys without understanding what they do?
#582 Magister
Magister
    Member
  • Members
  • 47 posts
Posted 09 November 2017 - 01:01 PM
From what I understand, on your USB key if you put the firmware AND the testmode key, from the menu you will be able to flash separate partition as you will. For instance if you fucked up your "platform" partition (/system), from this menu you can reflash it individually.
#583 dpratt1008
dpratt1008
  • Members
  • 10 posts
Posted 09 November 2017 - 05:21 PM
My biggest concern is the AVIC5000NEX folder that is extracted from the firmware downloads on Pioneer's site isn't the direct files that end up on disk when you update the firmware. For example, based on your description, if I have the AVIC5000NEX folder that contains the firmware updates, and I boot from the testmode_n3.key, select Write Bootloader, there isn't a folder in that firmware directory titled BOOTLOADER, so what does that function do? Your logic may apply to the functions Write Recovery Platform because in the firmware files there is a RECOVERY folder, but there's also a PLATFORM folder.
In essence, it sounds like the Write Recovery Platform option in the menu invokes a method or function like writeRecoveryPlat(Arg1, Arg2, ...) where the arguments this function would need would be a directory for source files, a mount destination to put the files, and any necessary unpacking parameters if the files are not just files on disk. but since I didn't create the key, or the list of menu options available, I was hoping someone could provide that information.
I'll have to admit I'm trying to ramp up on everything mentioned in this thread, I'm not a Linux or Android developer, but am familiar with scripts and general programming and software concepts. I'm just new to these specific concepts and file/folder/partition structures. The last thing I want to do is try something I think I understand only to fuck up my unit further. I was hoping to find a simple write-up that just explains what the functions do and their dependencies.
#584 Magister
Magister
    Member
  • Members
  • 47 posts
Posted 09 November 2017 - 06:27 PM
I don't know for the 5000, but I have a 5200 and there is a BOOT folder in the firmware.
I have some background on unix and for me, the "write" will do a raw copy (using the dd command) of the file image directly into the partition.
#585 dpratt1008
dpratt1008
  • Members
  • 10 posts
Posted 09 November 2017 - 08:05 PM
Just for confirmation, I'm working on an AVIC-7000NEX, but from what i can tell, the firmware update is applicable to 5000/6000/7000 series units.
Is there anyway I could peek into the testmode_a.key file that is found in the InternalSDCardBackup.zip, NORFlashBackup.zip, and the Jenkins online build utility that creates the archive.zip file to see how the method is defined?
Could you ELI5 what this process you're describing would be? e.g.
  1. Format USB drive (2GB or larger) to FAT32 and copy the contents of the CopyContentsToUSBDrive folder from the Jenkins build archive.zip file to the USB key.
  2. Copy the AVIC5000NEX folder from the firmware archive file downloaded from Pioneer to the USB key.
  3. Insert the USB drive into USB1 of your NEX unit and power on.
  4. The unit will reboot into Technical TestMode.
  5. Use Vol- button to navigate to Write Programs Forcibly and press Home button.
  6. Use Vol- button to select Write XXXXX and press Home button to execute that dd copy from the USB key to the internal SD card partition.
  7. etc...
Am I misunderstanding what this process would look like? This is why I'd feel more confident if I could see how these methods are defined or someone could explain their interpretation of them from some internal knowledge of the Tecnical TestMode interface.
Also tagged with one or more of these keywords: bsp, avic, development, developer, dev, xda, android auto, android, linux, kernel boot
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
