razer Posted September 14, 2019 Report Share Posted September 14, 2019 This is still usefull stuff to me. Thanks all. Quote Link to post Share on other sites
ZoOmZoOmPoW Posted October 18, 2019 Report Share Posted October 18, 2019 Hello guys, The link to the 2017 map is not working. Does anyone have a backup link? https://drive.google.com/open?id=0B5KpUvEq0nCnb29SZFVlNTZrZUk Thanks. Quote Link to post Share on other sites
surf kook Posted October 30, 2019 Report Share Posted October 30, 2019 Hi guys, I have a bone stock X920BT, no map or firmware updates since I bought it. I have downloaded and run the ShortFuse Hack, and downloaded the Z110Z120X920CARDINFO.zip. Can anyone re-link the 2017 update? I'd be willing to donate for your time and effort. Like zoom says, the google drive link is empty. If no one has the update anymore, does anyone have experience dealing with avicfix? https://www.avicfix.com/2017-map-upgrade-pioneer-avic-x920bt-z110bt-z120bt/ Thanks all for putting out all this out there. Quote Link to post Share on other sites
thesmokingman Posted November 3, 2019 Report Share Posted November 3, 2019 I have the file but need a host. Whats a good free host as this file is 3gb? Quote Link to post Share on other sites
BlakeStone Posted November 3, 2019 Report Share Posted November 3, 2019 12 hours ago, thesmokingman said: I have the file but need a host. Whats a good free host as this file is 3gb? Send it to me, I'll host it. my forum name AT outlook dot com Quote Link to post Share on other sites
thesmokingman Posted November 3, 2019 Report Share Posted November 3, 2019 I can't send 3gb thru my email. Gonna try upping to another free host. Quote Link to post Share on other sites
thesmokingman Posted November 3, 2019 Report Share Posted November 3, 2019 https://www.filehosting.org/file/details/830690/Pioneer_T1000-25818.zip avic411s Quote Link to post Share on other sites
BlakeStone Posted November 6, 2019 Report Share Posted November 6, 2019 OK, here it is: http://www.mybyteideas.com/avic411/Pioneer_T1000-25818.zip Somebody else put a password on it: avic411s Quote Link to post Share on other sites
surf kook Posted November 15, 2019 Report Share Posted November 15, 2019 Blake, Smoke, Ron, netz, everyone...thanks! The instructions in this forum were simple and clear. This latest link worked like a champ. Did the install today, upgraded from factory original to v7.0 and BT v3.32. Still didn't fix my bluetooth connection which has never worked for android; now my phone tells me 'incorrect password' instead of just 'can not pair'. I'll keep working on that. Recap: 8gb micro sd; FAT32 format; load and run shortfuse hack; get correct cardinfo file for x920bt; download link above; replace hack on sd card with cardinfo file, firmware folder, and update folder; run update [password = passwordpassword]; update firmware in bluetooth in settings; eject sd card; enjoy updated unit. Just a note - Blake's link worked great. smokingman's link gave me a 23 hour estimated download. Quote Link to post Share on other sites
Kdogg Posted January 13, 2020 Report Share Posted January 13, 2020 Just completed the update tonight for the map and it worked flawlessly. However, when I updated the BT firmware, the unit no longer shows my iPhone connected in Bluetooth Audio mode but the phone is showing paired with the unit in the BT menu. Do revert the BT firmware version back to the pre 3.32 version or try something else? Quote Link to post Share on other sites
RonS Posted January 13, 2020 Author Report Share Posted January 13, 2020 7 hours ago, Kdogg said: ...the unit no longer shows my iPhone connected in Bluetooth Audio mode but the phone is showing paired with the unit in the BT menu. Do revert the BT firmware version back to the pre 3.32 version or try something else? You might try re-pairing the BT connection first. Sometimes it is necessary to do a hard restart after a bluetooth upgrade. Simple surefire way is to disconnect the battery for 30 seconds. Or, if you know both fuses that power the radio, you can just pull them. If that doesn't fix it then try older BT firmware. maybe even re-installing 3.32. Quote Link to post Share on other sites
Kdogg Posted January 13, 2020 Report Share Posted January 13, 2020 6 hours ago, RonS said: You might try re-pairing the BT connection first. Sometimes it is necessary to do a hard restart after a bluetooth upgrade. Simple surefire way is to disconnect the battery for 30 seconds. Or, if you know both fuses that power the radio, you can just pull them. If that doesn't fix it then try older BT firmware. maybe even re-installing 3.32. I will try disconnecting the battery tonight. Thanks for the response! Quote Link to post Share on other sites
chrishaynesusa Posted July 10, 2020 Report Share Posted July 10, 2020 upgraded 2x Nissan Xterras with Z130BT's to version 7.0000 and 3.32 bluetooth Yeah!!!(happy dance)...... followed instructions from RonS, crai6m4ck1 nezfotnemom Quote Link to post Share on other sites
DBock Posted March 28, 2022 Report Share Posted March 28, 2022 On 8/28/2019 at 11:26 AM, crai6m4ck1 said: A quick recap for those coming here in the future to upgrade their head unit to version 7 firmware, 2017 maps, and the latest Bluetooth version. A special thanks to RonS for his help! Quoted from an earlier post of his, “This is a hack to prepare your unit to install a map/firmware update. Confirmed to allow firmware updates for all Z110, Z120, Z130, Z140, X920, X930, X940 - and probably their corresponding rest-of-the-world units. I can't say whether it will work with the very old units, and it won't work with the model numbers ending in 50 or greater, or Nex units. This should work with the following F series models: F10BT, F20BT, F30BT, F40BT, F840BT, F8430BT, F920BT, F930BT, F940BT, F9210BT, F9220BT, F9310BT” This is the process that worked successfully with my x930bt and I would assume should work with all the models listed above (though I make no guarantees). First Download the ShortFuseScript.zip from here: http://avic411.com/applications/core/interface/file/attachment.php?id=16863 22.66 kB · 1527 downloads Extract the files (Hacked.dll, ScriptExec.ini, and TESTMORE.KEY) and place them in the root of an SD card. Insert the SD, it will prompt you to press any key (button) to continue - or - turn off the ignition to abort. Press a button and it should finish fairly quickly. Next Install the version 7 firmware and 2017 maps found here Pioneer_T1000-25818.zip https://drive.google.com/open?id=0B5KpUvEq0nCnb29SZFVlNTZrZUk You’ll be prompted for a password to open the encrypted file Password: avic411s Extract the files out of the Pioneer folder and put them on the root of an SD card Insert the SD card into the head unit and when prompted for the password enter: PASSWORDPASSWORD. It should take up to 30 minutes to install Lastly, go into Bluetooth settings and select upgrade firmware. You’re done! This is a really simple way to upgrade your unit that anyone should be able to handle. Just make sure that you keep the power on at all times. I even left my vehicle idling just to be safe. For those not technically inclined, the Root of SD card means that the files are at the very top level and not within other folders. So when you open the SD card you immediately see the files and you don’t have to explore folders to find them. Good luck! Hello crai6m4ck1, Thanks for this recap, when installing ShortFuseScript AND the firmware update, do we need 2 SD cards or will it work if we put all the files on one card? Quote Link to post Share on other sites
RonS Posted March 29, 2022 Author Report Share Posted March 29, 2022 20 hours ago, DBock said: Hello crai6m4ck1, Thanks for this recap, when installing ShortFuseScript AND the firmware update, do we need 2 SD cards or will it work if we put all the files on one card? To be safe, don't put them on the same card at the same time. You don't need two SDs. You can install ShortFuse then format and re-use the same card for the map update. Quote Link to post Share on other sites
