benjolol Posted December 9, 2023 Report Share Posted December 9, 2023 Hello guys I have AVIC-F9310BT, will map updates work for this model? If so, how do I install these files and can I do these updates with usb? Keypoints: Also what is shortfuse hack and do i need it? Should I change cardinfo and how do I do it? What does TTS have to do with all of this? Quote Link to post Share on other sites
RonS Posted December 11, 2023 Report Share Posted December 11, 2023 On 12/9/2023 at 11:35 AM, benjolol said: Hello guys I have AVIC-F9310BT, will map updates work for this model? If so, how do I install these files and can I do these updates with usb? Keypoints: Also what is shortfuse hack and do i need it? Should I change cardinfo and how do I do it? What does TTS have to do with all of this? Shortfuse hack : http://avic411.com/index.php?/topic/83535-map-update-hack-using-shortfuse-method-z110-z140x920-x940/&do=getNewComment Cardinfo needs to be changed only if the model you have is different that what godzilla has posted. I don't use TTS, so I can't help. TTS generally refers to Text To Speech, so it might be useful if you need a different language. Quote Link to post Share on other sites
benjolol Posted December 13, 2023 Report Share Posted December 13, 2023 On 12/11/2023 at 4:32 AM, RonS said: Shortfuse hack : http://avic411.com/index.php?/topic/83535-map-update-hack-using-shortfuse-method-z110-z140x920-x940/&do=getNewComment Cardinfo needs to be changed only if the model you have is different that what godzilla has posted. I don't use TTS, so I can't help. TTS generally refers to Text To Speech, so it might be useful if you need a different language. Hey so I tried to download shortfuse and do rest of stuff but this happened. Btw what do ya think does this avic have custom os or something, just asking Quote Link to post Share on other sites
RonS Posted December 14, 2023 Report Share Posted December 14, 2023 19 hours ago, benjolol said: Hey so I tried to download shortfuse and do rest of stuff but this happened. Btw what do ya think does this avic have custom os or something, just asking The script attempts to make backup copies of the two original RenewalIFlib.dll files onto the SD before overwriting them. For some reason the copy command failed. Maybe there was no more room on the SD or it was write-protected, or the file already existed on the SD (if you ran the script more than once). Anyway the copy of the original files failed and the hacked versions didn't occur since the script crashed. Regardless, you can edit the script (named ScriptExec) on your PC and remove that 1st and 2nd COPY command. Then rerun it by reinserting it into the head unit. No way I can tell if it is a custom OS - probably not Quote Link to post Share on other sites
benjolol Posted December 17, 2023 Report Share Posted December 17, 2023 On 12/14/2023 at 8:34 AM, RonS said: The script attempts to make backup copies of the two original RenewalIFlib.dll files onto the SD before overwriting them. For some reason the copy command failed. Maybe there was no more room on the SD or it was write-protected, or the file already existed on the SD (if you ran the script more than once). Anyway the copy of the original files failed and the hacked versions didn't occur since the script crashed. Regardless, you can edit the script (named ScriptExec) on your PC and remove that 1st and 2nd COPY command. Then rerun it by reinserting it into the head unit. No way I can tell if it is a custom OS - probably not Hey, so i just need to install 2019 maps, so what software can i use to edit script? And also I heard theres something you need to change in cardinfo, so if you can explain this i would be gratefull. Quote Link to post Share on other sites
RonS Posted December 17, 2023 Report Share Posted December 17, 2023 I use notepad on Windows. But any editor that edits and saves text files and doesn't insert formatting data (like Word). Also make sure you save the file name exactly the same without adding a ".txt" extension. You'll need to browse this thread for info on replacing cardinfo. Several people have written detailed instructions. I haven't messed with this stuff for 5 years. Quote Link to post Share on other sites
benjolol Posted December 19, 2023 Report Share Posted December 19, 2023 On 12/17/2023 at 7:27 PM, RonS said: I use notepad on Windows. But any editor that edits and saves text files and doesn't insert formatting data (like Word). Also make sure you save the file name exactly the same without adding a ".txt" extension. You'll need to browse this thread for info on replacing cardinfo. Several people have written detailed instructions. I haven't messed with this stuff for 5 years. Yeah i believe that, but i think people have removed those threads, since I havent seen any tutorial on that Quote Link to post Share on other sites
RonS Posted December 20, 2023 Report Share Posted December 20, 2023 Did you get Shortfuse installed? If you've read through this thread you should have all the info you need. There's no guide - just posts from people saying what worked. Note that pages 6 - 8 have a lot of helpful info. An F9310bt is basically the same as an F930bt and does not require a different Cardinfo file. Only early series like F910 or 920 need it to ne compatible with the version that Godzilla posted. That's about all I can tell you since I've never installed this update. But the process is the same as all the previous updates (2013, 2015, 2017). So you might find better guides in those threads. Quote Link to post Share on other sites
benjolol Posted January 2, 2024 Report Share Posted January 2, 2024 On 12/20/2023 at 4:01 AM, RonS said: Did you get Shortfuse installed? If you've read through this thread you should have all the info you need. There's no guide - just posts from people saying what worked. Note that pages 6 - 8 have a lot of helpful info. An F9310bt is basically the same as an F930bt and does not require a different Cardinfo file. Only early series like F910 or 920 need it to ne compatible with the version that Godzilla posted. That's about all I can tell you since I've never installed this update. But the process is the same as all the previous updates (2013, 2015, 2017). So you might find better guides in those threads. I removed backup copy files but still get this error, what could be wrong Quote Link to post Share on other sites
RonS Posted January 2, 2024 Report Share Posted January 2, 2024 There must be something wrong with your SD. Ideas: What size? Format FAT32. What files are on it? Should be only the files from my unzipped file. The write protection tab should be turned off. Maybe try a different SD. Don't use a large SD (1 - 8 GB work well. Quote Link to post Share on other sites
benjolol Posted January 2, 2024 Report Share Posted January 2, 2024 3 minutes ago, RonS said: There must be something wrong with your SD. Ideas: What size? Format FAT32. What files are on it? Should be only the files from my unzipped file. The write protection tab should be turned off. Maybe try a different SD. Don't use a large SD (1 - 8 GB work well. I did actually use 32 GB SD, maybe thats the reason, was also formated FAT32 and there was shortfuse script with map update Quote Link to post Share on other sites
RonS Posted January 2, 2024 Report Share Posted January 2, 2024 9 minutes ago, benjolol said: I did actually use 32 GB SD, maybe thats the reason, was also formated FAT32 and there was shortfuse script with map update No map update on this SD! Just the Shortfuse files. After it is successfully patched you can format the SD and use it for the map update (or use two SDcards). On the map update do not add or modify any files except if you need to replace Cardinfo (which you should not need for your model). Quote Link to post Share on other sites
benjolol Posted January 2, 2024 Report Share Posted January 2, 2024 6 minutes ago, RonS said: No map update on this SD! Just the Shortfuse files. After it is successfully patched you can format the SD and use it for the map update (or use two SDcards). On the map update do not add or modify any files except if you need to replace Cardinfo (which you should not need for your model). Could that be a problem rather than size of SD card? Quote Link to post Share on other sites
RonS Posted January 2, 2024 Report Share Posted January 2, 2024 8 minutes ago, benjolol said: Could that be a problem rather than size of SD card? Maybe. It is easy to try. Quote Link to post Share on other sites
Timo Savelkouls Posted July 26, 2024 Report Share Posted July 26, 2024 On 5/12/2020 at 11:33 PM, godzilla said: Here we go guys https://drive.google.com/open?id=1o7rfWz2qB67V5p9CfuMb0SpmMTGNjLuN Software https://drive.google.com/open?id=13k1m5B19rP-D3lhQbGSbvUqpp5OryJMJ - TTS CD as promised Regards Godzilla Thanks for providing the software.. ive tried to uplaod it onto my F930BT but im beeing asked for my " pioneer password".. i tried finding the asnwer here in the thread but with no luck so far. Thanks in advance! Gr Timo Quote Link to post Share on other sites
Join the conversation
