Jump to content
AVIC411.com
New Release F20BT F30BT F40Bt F920BT F930BT F940Bt F840BT Etc 2019
Can anyone tell me if this is supposed to be working for F950DAB?
I got super testmode working (key), but trying to locate the files requested RenewalFlib.dll is impossible.
Attached is the information from PRG\APL
Menu
Which as far as I know is the only thing related to PRG / APL in the whole system.
From what I understand there are others with F950+ that used the same procedure as explained, but I can't grasp how as it has different file mappings.
Link to post
Share on other sites
  • Replies 235
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Can anyone tell me if this will work with the Z710DAB?
I've searched for quite a while on this forum, but cannot seem to find anything about it.
And since this unit does not have sd card slots, but only a usb port, how should I then proceed to update?
Any help is appreciated
Link to post
Do the same for the USB as others do with SD cards, if it works, which I'm not sure about.
Link to post
Witam. Aktualizowalem jakieś dwa lata temu swojego Pioneera F930BT do map z 2017 i z tego co pamiętam to zmieniałem jakieś liczby w systemie i aktualizacja map 2017 potem poszła bez problemu. Teraz chciałem zaktualizować mapy do 2019 pobrane tutaj i w ogóle nie chce nic ruszyć za każdym razem uruchamia się radio nie widząc karty SD. Jak mam to zrobić żeby zadziałało. Dziękuję
Link to post
  • 2 weeks later...
On 6/10/2019 at 12:40, spoon1 said:
On 8/9/2019 at 01:47, godzilla said:
Va bene due anni e un'altra release per tutte queste macchine. L'ultima volta che ho acquistato il software e ho diffuso la ricchezza, questa volta ho bisogno di aiuto perché la mia situazione è cambiata. Per prima cosa ho bisogno di acquistare il software con il donatore più alto che riceve il pacchetto originale e la chiave inutilizzata, tutti gli altri riceveranno il software gratuitamente ogni euro, dollaro o sterlina aiuterà il mio indirizzo di pagamento è
paypal.me/salsatnav
Ti terrò aggiornato con aggiornamenti quotidiani fino a raggiungere £ 125, quindi lo pubblicherò qui GRATUITAMENTE ho la sensazione che l'hack di Rons Shortfuse lo farà di nuovo
Aiutiamoci tutti a vicenda
Donato
Link to post
  • 3 weeks later...
  • 1 month later...
On 8/9/2021 at 9:21 PM, brunowillis said:
Will this work with the F700BT or is this model too old? The last update I installed was this Russian AvicNet hack from 2014 which allowed to use iGo Primo. If this one here doesn't work but there's another new version I should use, then I'm thankful for a hint. Thanks!
You cant use this on your 700 model brunowillis
Link to post
Hi guys,
Thank you for this post!
I tried to install it on a F40bt but can't go further the password step.
I did the shortfuse and when the update asks me for the password i input PASSWORDPASSWORD and it ask me to insert password again!
1111111111111111 doesn't work either!
Did anyone go through the same issue? How did you manage it?
Regards,
Link to post
  • 2 months later...
Thanks, working like a charm on my f930bt. Before i found this, i had a higher software installed. The hack caused my system to downgrade to 8.000. Now i have everything installed, can i safely update my system again to 8.6 though the official site? Or can this harm the system since i used the hack?
cheers!
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
