All Activity
- Today
Davidprisp joined the community
What is the history of this unit? Did you buy it used and install it yourself, or maybe bought a car with it already installed? The grayed settings indicate it isn't properly installed. There's lots of info on how to do the parking brake bypass, sounds like you need to read-up or watch YouTube vids. Btw, the x910bt has Bluetooth (that's what "bt" stands for in the model name). So don't blame Pioneer. If yours isn't working after fixing the parking brake issue, then your unit is defective.
Guyshere574 joined the community
Why can't I get into my settings menu? It's all grayed out and the only thing that works is the radio? I can't get into settings and I believe the parking wire is missing when it was bought is there anything I can do to fox this? Do I jus move the mute wire over to the other spot that everyone's mentioning? Someone please help? And the fact that it doesn't have Bluetooth is pretty crappy.. Why would pioneer do such a thing?
- Yesterday
shayan_996 joined the community
- Last week
josh54545 joined the community
[HELP] - Apple iPad 10th Generation has been locked
Annetta replied to Annetta's topic in iPod/iPhone/iPad
Finally I have unlocked my iPad. After posting the thread here when I did not get any response then I searched on Google and came across this useful guide. The task which I followed to unlock my iPad, first I pressed & hold the top button until see the power off slider. Then dragged the slider for turning of and waited for a while for it to shut down completely. It was a painful experienced I never forget. But now I feel relax to solve the issue. -
tomek3232 joined the community
w4500nex [FIX] SDCard Failed? Software Error on your w4500nex? Look here!
Datsun replied to slackwaredragon's topic in NEX Series
Once the sd card is placed in a unit and turned on the card becomes password protected. There are people here who say they know that password but I do not. Even if I did, I do not know how to unlock the card. Maybe others can help. -
I need a serious help friends. I have forgotten my Apple iPad 10th generation password. After trying a several attempts, my iPad has been locked. Can anyone please help me how to unlock my iPad?
Double checking my F90BT map and license install is correct.
TimboZero replied to TimboZero's topic in Hacks/Mods
No one able to assist please? -
I have a working W4500NEX SDcard. How can we go about test booting the W4500NEX unit to make a good a backup copy that can be applied to a higher quality SD card?
Tekem replied to slackwaredragon's topic in NEX Series
I have two W4500NEX headunits. the SD card failed on one of them. How do I backup the other one on the unit that is still working? I easily removed the SD card, but I cannot read it in Windows to backup up or make an image. I merely want to make a block level copy so I can use a reputable SD Card brand to mitigate this issue. -
Pen3 replied to RonS's topic in Hacks/Mods
Thank you, it worked immediately. -
RonS replied to RonS's topic in Hacks/Mods
Download the attached file and unzip. Then replace the Cardinfo.cif file on the update SD with the unzipped one. Z110Z120X920CARDINFO.zip -
AVIC-Z110BT. How do i go about getting the correct cardinfo? -
TimboZero changed their profile photo
Apologies for a ‘newb’ topic, but has been 4 years since I last updated my AViC F90BT system. I have so far updated (using HERE maps, seem to be popular now) my maps (only the 2 main files so far the fbl and fpa (and my regions hnr files), but intend to add the fda and fsp in the morning all in maps folder. Are there any other ‘map’ files that work on my system? And finally, licenses came with the maps but the system seems to work as it is this evening. Do I need these ‘extra’ licenses and if so where do they go? Many thanks in advance, Timbo
What model are you trying to update? It is likely you don't have the correct cardinfo file. -
I need some help. After i installed the shortfuse and it says i am ready to update the map. I remove the sd card and restart the unit. I inset the sd card with the map update, but nothing happens. Is it possible to use the supertest mode and force install the update? - Earlier
RonS changed their profile photo
Is your parking brake set (or has it been bypassed)? Maybe it was never wired. Many settings can only be changed when the parking brake is set. In fact, this is controlled by the "Safe Mode" set to On. Is this a newly installed unit, possibly a used one? "Safe Mode" defaults to On. So it sounds like someone had previously turned it Off Disclaimer: mine is a US unit (Z110-BT), and we don't have a "Safe Mode" option. So I'm guessing about the behavior of "Safe Mode" based on looking in the F-9xx series user manual.
It's possible that the headunit needs power to boot up fully and access the bootloader via UART. Try connecting it to power and then retrying the UART connection. Ensure the baud rate matches and check for any hardware or wiring issues.
- 720 replies
https://mega.nz/folder/PNhjXCyZ#i27AkYewqDz9y5I1EW8ywQ/file/CEgyyQSJ European model (EW):AVIC-Fx60_EU5_FW_Ver_120.Zip
Sooo, should I download test mode and that way try to instal older firmware version ? But in this mega there is only 1.14 for eu and image I put on SD is 1.15
https://mega.nz/folder/PNhjXCyZ#i27AkYewqDz9y5I1EW8ywQ/folder/CApgnQIK
tim wood started following F930bt stuck in safe mode
Help please, stupidly clicked on safe mode. Now can't even enter password. Tried positive direct from battery to yellow and red wires but still get greyed out keyboard. Thanks in advance
Can You explain to me like I'm dumb ?
It is necessary to check what updates from 1.15 to 1.21 ... and set them in order
This ! Exactly what I mean. It would be really nice if one skilled developer could make some kind of an app or website with all files, scripts, apps and instructions that are needed to keep those devices up and running or resurecting if failed already. And explain it with words simple enough that people that are handy with computers and stuff but are not programmers could understand it and make it work. I know that servers, hostings etc costs money, so access to all the knowledge and database could be behind some few dollars paywall.
- 720 replies
