BorisM Posted March 17, 2009 Author Report Share Posted March 17, 2009 Thank you Boris so basically copy that file onto my sd card copy that file i need into the other folder on my computer then stick that into the folder on the avic in testmode correct.. Kevin Copy DATA.ZIP to SD card. On PC: if using WInZIP, unzip the whole thing preserving directory structure copy cursor_places where it should go ZIP the whole thing back up, preserving exact same structure. If using WinRAR or 7ZIP, you could just drag the file out, then back to the new location. Copy the fil back to the headunit. Quote Link to post Share on other sites
mikehenya Posted March 17, 2009 Report Share Posted March 17, 2009 I am having the same problem as Sandpro, no matter what scheme I select the map colors stay the same, the only change I see is the route line color changes. I went in to the save folder and deleted everything as well but still no luck. Any possibility something else is over riding the scheme files? I guess the problem for me is all the surrounding area is green/blue. Do the schemes change the terrain colors too, or am looking at it all wrong? Quote Link to post Share on other sites
gnasr74 Posted March 17, 2009 Report Share Posted March 17, 2009 there are a total of 4 zip files with multiple zip files and .png files. Do you unzip the 4 original files and add each zip within those files 1 by 1 or just add the 4 zip files to the directory. Please help. Thank you Quote Link to post Share on other sites
mikehenya Posted March 17, 2009 Report Share Posted March 17, 2009 I unzipped the "main" zip file and put the "little" zip files in. They then showed up fine in the menu. Quote Link to post Share on other sites
gnasr74 Posted March 17, 2009 Report Share Posted March 17, 2009 I unzipped the "main" zip file and put the "little" zip files in. They then showed up fine in the menu. For Xerses.rar, scheme.rar, RealViewV6.rar no problem. But in Schemes.rar, there are a bunch of .png files and a text file. What do we do with those? Thanks a lot for your help. Quote Link to post Share on other sites
mikehenya Posted March 18, 2009 Report Share Posted March 18, 2009 Hmm, I didn't test those yet. Not sure. Try them the same way, if they don't work, just delete them. Quote Link to post Share on other sites
jmqrsq Posted March 18, 2009 Report Share Posted March 18, 2009 You still need, in DATA.ZIP, to copy cursor_places.spr from common to common/night folder. Sorry fo rthe noob question but where can i find this file to download? i see people talking about Mavericks mod DATA.zip but I cant find it to download. Any help pointing me to the thread with the DATA.zip downloads by forum members would be greatly appreciated. Quote Link to post Share on other sites
kevin1488 Posted March 18, 2009 Report Share Posted March 18, 2009 viewtopic.php?f=34&t=19864 Mav's mods are the best i think.... Kevin Quote Link to post Share on other sites
jmqrsq Posted March 18, 2009 Report Share Posted March 18, 2009 http://www.avic411.com/forum/viewtopic.php?f=34&t=19864 Mav's mods are the best i think.... Kevin thansk for that info. so is the data.zip on the first post the latest? Quote Link to post Share on other sites
kevin1488 Posted March 18, 2009 Report Share Posted March 18, 2009 Yes Quote Link to post Share on other sites
swankydank2001 Posted March 18, 2009 Report Share Posted March 18, 2009 Question now. I downloaded the schemes, its has a color.ini, color3d.ini and content .nng. inside, to i just drop the zip file as is or do i have to separate them please help tired of looking at this boring map. thanks Quote Link to post Share on other sites
mikehenya Posted March 20, 2009 Report Share Posted March 20, 2009 Yep, just drop in the individual zips. I didn't see much of a change, but then I tried realviews, they are great! The color changes I was looking for. Quote Link to post Share on other sites
swankydank2001 Posted March 20, 2009 Report Share Posted March 20, 2009 OK maybe im not seeing or doing something right here, how come i dont have the sky on mines, Quote Link to post Share on other sites
kevin1488 Posted March 20, 2009 Report Share Posted March 20, 2009 you might not be seeing skies cause you have to mess with the tilt view in the view you want and if you cant tilt down as much as you want there is a post that i will find for you just let me know or pm me.. Kevin Quote Link to post Share on other sites
aharper Posted March 26, 2009 Report Share Posted March 26, 2009 So apparently I'm struggling here. I have made change after change but am probably doing something fundamentally wrong. I took one of the theme .zip files and copied it to something else... MyTheme.zip. I then modified the colors in the file to be basically the same thing that you see in the Pioneer Blue Day theme but with a light tan/kahki ground background that is something similar to the Xersus Summer theme. Change after change, same results... nada. Once I change the color.ini and color3d.ini files I put them back into the zip file which also contains a "content.nng" file and "dayheightcolormap.bmp". So clearly I'm doing something wrong. Can someone help point me in the right direction? Also, here is some reference material... this site will allow you to put in RGB values and see what the color is. This is helpful when trying to figure out what color the .ini files are referencing. http://webdeveloper.earthweb.com/reposi ... 1/hex.html this site will allow you to look at a color and see the value (basically the opposite of what is above). http://web.njit.edu/~kevin/rgb.txt.html Thanks in advance for your help. This is starting to drive me nuts. Quote Link to post Share on other sites
