cigga24 Posted December 19, 2008 Report Share Posted December 19, 2008 Here is lilengineers data.zip plus original fonts http://www.mediafire.com/?sharekey=f020 ... b9a8902bda Never used this site before so get it while you can. Quote Link to post Share on other sites
weaponofchoice Posted December 23, 2008 Report Share Posted December 23, 2008 Hey Keeper, I'm using your zip and looks great but I have a couple problems I'd like to figure out. 1.) My arrow has dissapeared after uploading your files. (edit: oops, read back in the thread a bit and found this fix) 2.) My map is perma zoomed out and auto zoom is not working. Can you (or anyone) help me out with this? Thanks, and awesome work on the ui mod. Quote Link to post Share on other sites
weaponofchoice Posted December 23, 2008 Report Share Posted December 23, 2008 Ok zoom problem seems to be resolved, must have been a glitch as it's now working ok. Quote Link to post Share on other sites
afareca Posted January 16, 2009 Report Share Posted January 16, 2009 Alright now I am having some trouble getting it working on the avic. Everything works fine untill I hit the map button then the unit just keeps rebooting. I noticed there were other files besides the data.zip do I need to do anything with those. I just copied your data.zip file to my sd card then replaced the data.zip file on the avic with yours, is this the right way to do it? Any help would be greatly appreciated. Thanks in advance. yea you need all the files... copy them all to the same DIR! This is from Pg 2, I've read this post over and over and still have this same problem, with all the Data.zip posted so it must be something I'm doing wrong. What other files do I need to copy??? I've seen the SYS file mentioned here somewere, is it a modified SYS???? where do I get it???? sorry if this are all dumb questions I really want to get this mod working on my 700BT. Help will be apreciated. Quote Link to post Share on other sites
afareca Posted January 17, 2009 Report Share Posted January 17, 2009 Bump Quote Link to post Share on other sites
bryvale Posted January 17, 2009 Report Share Posted January 17, 2009 O sorry about that windows error, I will get rid of that. I removed someone else's mod from earlier that showed longitude and latitude when you press the current street. I never used it... But I forgot to get rid of the button's action. It is a quick fix and I will repost the data file when I do it. What do we need to add if we want the LAT/LONG to show? Quote Link to post Share on other sites
eurotuner29 Posted January 17, 2009 Report Share Posted January 17, 2009 Add this: run 'MSC_Lat.x 200, MSC_Long.x 200' run 'MSC_Lat.x 1200, MSC_Long.x 1200' add this to "scripts_800_480.ui" file Quote Link to post Share on other sites
bryvale Posted January 18, 2009 Report Share Posted January 18, 2009 I did that but I am getting the error message: FFUI Error: unknown object identifier Identifier=[sc_msc_showPOS] script "[unnamed]" commandO Thanks for your help! Quote Link to post Share on other sites
N-S-E-W Posted January 18, 2009 Report Share Posted January 18, 2009 Add this: run 'MSC_Lat.x 200, MSC_Long.x 200' run 'MSC_Lat.x 1200, MSC_Long.x 1200' add this to "scripts_800_480.ui" file Plus you'll need to add this to your navigatemap800_480 file. You''ll need to adjust the "Y" position to your liking though. and add the onrelease part of this script to the button bmp Quote Link to post Share on other sites
bryvale Posted January 18, 2009 Report Share Posted January 18, 2009 That did the trick. Thanks for your help! Quote Link to post Share on other sites
N-S-E-W Posted January 18, 2009 Report Share Posted January 18, 2009 That did the trick. Thanks for your help! You're welcome. Glad I was able to help. Quote Link to post Share on other sites
69sixpackbee Posted March 26, 2009 Report Share Posted March 26, 2009 Okay, I did this mod and I am getting an FFUI Error box when I touch the house numbers. It reads" Unknown Object Identifier [uI_housenumbers] script (unamed) command 4" . Also, in the lower left selectable boxes, if I change one of them to "speed" it reads Km/hr but a couple of screens back and forth and goofing with it it will come back as MPH. What is this and how do I correct them?? Thanx, Bud Quote Link to post Share on other sites
Join the conversation
