vbtruk Posted May 3, 2010 Report Share Posted May 3, 2010 34by151, i also want to say thanks for all your help and hard work! the maps looks great, just one question with the Lang US, sounds, and speedcam files from your download site, do i need to copy these accross or is that allready done in the R17 map update? and if so is it just a matter off copying those files into he respective folders of the IGO program on the unit? Thanks Again. Quote Link to post Share on other sites
mikzsan Posted May 3, 2010 Report Share Posted May 3, 2010 I have no message other than to also say a big THANKS to 34by151 for all his hard work and help. Quote Link to post Share on other sites
34by151 Posted May 3, 2010 Author Report Share Posted May 3, 2010 34by151, i also want to say thanks for all your help and hard work! the maps looks great, just one question with the Lang US, sounds, and speedcam files from your download site, do i need to copy these accross or is that allready done in the R17 map update? and if so is it just a matter off copying those files into he respective folders of the IGO program on the unit?Thanks Again. Just apply the V3Updates in order, follow the instructions in the thread and all will be ok Cheers 34by151 Quote Link to post Share on other sites
34by151 Posted May 3, 2010 Author Report Share Posted May 3, 2010 I have no message other than to also say a big THANKS to 34by151 for all his hard work and help. Thanks 34by151 Quote Link to post Share on other sites
vbtruk Posted May 3, 2010 Report Share Posted May 3, 2010 I am having a bit of trouble. I had the R17 maps installed from page 40 and was working great, when i installed the V302a and b and then the V303 part 1 and 2 from page 14 the skin came up well but the bluetooth no longer works i read the posts and am not sure what i need to do to fix it as there is conflicting information. their are 2 bluetooth updates on the 4shared site which one and how to apply? also is the R17 map on page 40 and the V303 from page 14 the same as this change is what seems to have done it. thanks. Quote Link to post Share on other sites
34by151 Posted May 3, 2010 Author Report Share Posted May 3, 2010 I am having a bit of trouble. I had the R17 maps installed from page 40 and was working great, when i installed the V302a and b and then the V303 part 1 and 2 from page 14 the skin came up well but the bluetooth no longer works i read the posts and am not sure what i need to do to fix it as there is conflicting information. their are 2 bluetooth updates on the 4shared site which one and how to apply? also is the R17 map on page 40 and the V303 from page 14 the same as this change is what seems to have done it. thanks. I don't know what you mean by page 40 this thread only has 29 pages If you are having bluetooth issues it will be because MSN has been powered up, go into testmode and delete the msnd files from the save directory. Also check you have the correct device in sys.txt Cheers 34by151 Quote Link to post Share on other sites
vbtruk Posted May 3, 2010 Report Share Posted May 3, 2010 thanks 34by151, sorry not page 40 it was page 24, where is the sys.txt located? and am i wanting to change it back to the us model code ening in UC? Quote Link to post Share on other sites
vbtruk Posted May 4, 2010 Report Share Posted May 4, 2010 I deleted the Msn and Msdn files and still no bluetooth, when i try updating the BT software it keeps failing? Quote Link to post Share on other sites
34by151 Posted May 5, 2010 Author Report Share Posted May 5, 2010 I deleted the Msn and Msdn files and still no bluetooth, when i try updating the BT software it keeps failing? If I remember right you have a US version? If that is right don't put a UK or OZ BT patch on it as it does not have the same hardware. If you must patch the BT do so with the correct version IF the BT is not working there are plenty of threads relating the US BT issues, do a search Cheers 34by151 Quote Link to post Share on other sites
vbtruk Posted May 6, 2010 Report Share Posted May 6, 2010 Yes i have the US model, i have downloaded all the different US bluetooth updates for the unit from pioneer and other sources and none of them are working it just says failed, i am thinking this is because of the fact that there is no version of bluetooth listed on the unit to update. can you please help me to copy the bluetooth software files from my original backup to the correct place in the V303 update of yours so that when i install it again it might work. the blue light on the front of the unit comes on at the start and then it stays off. Quote Link to post Share on other sites
vbtruk Posted May 6, 2010 Report Share Posted May 6, 2010 Ok, i have restored the back up from when i first loaded the r17 maps on and the bluetooth has come back and in the bluetooth software menu there is a version of Bluetooth software listed. For some reason the new skin in V302a onwards removes the bluetooth software on my unit. 34by151 can you please explain to me how i can copy the files from my back relating to the Bluetooth into the update with your 3d skin so when i re-install, it also loades the bluetooth software. also there are multiple sys.txt files all with different numbers and endings in the file so do i also need to delete all bar the UC one for me? Thanks Again. Quote Link to post Share on other sites
34by151 Posted May 7, 2010 Author Report Share Posted May 7, 2010 You have a US model the has different hardware to the OZ ones. So putting on Oz or UK bluetooth patches is probally not a good thing, as is trying to downgrade them. Try to put on the patches for your US model. If they wont load there are lots of threads dealing with this where you will you find lots of info. Just search for bluetooth Cheers 34by151 Quote Link to post Share on other sites
vbtruk Posted May 7, 2010 Report Share Posted May 7, 2010 The US patches were not working, at the moment i am running the R17 maps that you posted first without the skin mods and the bluetooth works fine, i just want to know how i can copy accross the relevant files i curently have into the updated Skin map update you created so as it keeps the same bluetooth files when i do the update with your skin. I did a search but it is not answering the problems related to what i have expierenced apart from loading in new BT software which did not work. Quote Link to post Share on other sites
richiey Posted May 7, 2010 Report Share Posted May 7, 2010 Hi 34by151, Just to clarify - if i downloaded and have applied ONLY the files from V3UPDATE03.part1.rar V3UPDATE03.part2.rar from your site and nothing else, do I still need to then go 'backwards' and apply the older files V3UPDATE01.part1.rar V3UPDATE01.part2.rar V3UPDATE02a.rar V3UPDATE02b.rar As you mention Contained in this release: Autoboot Installer Australian Sensis (WhereIs) R17 Map (Released Feb 11 2010) 3D Buildings 3D Petrol Stations Updated POI's Updated Speed Cam Spoken Street Name Corrections (Phoneme.ph file) Map Warning Bypass Updated EzRider Undated Map License files Updated Terrain (more detailed elevations) So i am assuming that the V3UPDATE03.part1.rar V3UPDATE03.part2.rar files is the most upto date package with all past updates? Thanks Quote Link to post Share on other sites
34by151 Posted May 7, 2010 Author Report Share Posted May 7, 2010 Update01 is the V16.1 maps Update 02b is the skin Update03 is the V17.1 maps So if you want V17maps and the skin apply Updates 02b and 03 If you want to do it all in one go download updates 02b and 03 Extract 02b to your hdd Follow the instructions on page 23 up to step 5 Copy the files extracted for 02b to the update dir on the sd card (with the folder structure) Resume instructions on page 23 Cheers 34by151 Quote Link to post Share on other sites
Join the conversation
