ill.die.trying Posted August 7, 2009 Author Report Share Posted August 7, 2009 Hey IDT do you know if it is possible to put a shortcut for contacts on the nav screen? it's possible but no one has hacked the part of the unit that handles that, Quote Link to post Share on other sites
hanibal Posted August 7, 2009 Report Share Posted August 7, 2009 wht do the screnn shots show blue arrow but still get red after install? it's because of the scheme i'm using, go to the ftp site and on the main level you'll find schemes that you can download What exactly am i looking for? Quote Link to post Share on other sites
touche6784 Posted August 7, 2009 Report Share Posted August 7, 2009 was the software bypass implemented on the data.zip file? It does not seem so as I get the error message telling me to check my wiring. Other than that it all seems to work well. sorry i forgot to add that part, v2 will be up soon, if you're comfortable with changing it please do so Not a problem. I thought I would put that out there incant someone else was having problems. Quote Link to post Share on other sites
crilleym Posted August 7, 2009 Report Share Posted August 7, 2009 IDT, Just loaded it with a fresh reload of my unit again. Works good. All we need now is a favorites shortcut. Thanks for your time. Quote Link to post Share on other sites
ill.die.trying Posted August 7, 2009 Author Report Share Posted August 7, 2009 IDT, Just loaded it with a fresh reload of my unit again. Works good. All we need now is a favorites shortcut. Thanks for your time. i'll make a shortcut menu option in the nav setting so that you can select what you see on the nav screen, it might not be on the second release but for sure i'll add that some time next week, Quote Link to post Share on other sites
wenigwiser Posted August 7, 2009 Report Share Posted August 7, 2009 Is this Modding only for IGO 8.3 or can be used with 8.0? info: my USA unit is uptodate but APL2 is with hacked ezrider+Europe maps does it have the hacked 3.0 update? It runs with 3.01... But APL2 folder is from fw 2.xxx with IGO 8.0 Quote Link to post Share on other sites
rkmoray Posted August 7, 2009 Report Share Posted August 7, 2009 Why is it the brake setting is set to 16, instead of the 256 requested by many. For some reason, every time I make a change, my system does notting but reboot, so I must leave the data.zip file as I get it. Quote Link to post Share on other sites
eppler Posted August 7, 2009 Report Share Posted August 7, 2009 Hey IDT love the mod and thank you for the work you do. I used the fly over and now my 2d/3d button is gone. I tried to recopy the data file and it is still not showing up any ideas? Quote Link to post Share on other sites
ill.die.trying Posted August 7, 2009 Author Report Share Posted August 7, 2009 Why is it the brake setting is set to 16, instead of the 256 requested by many.For some reason, every time I make a change, my system does notting but reboot, so I must leave the data.zip file as I get it. leave it alone for now, i'll have an update later in the afternoon with the software bypass Quote Link to post Share on other sites
spiceditup Posted August 7, 2009 Report Share Posted August 7, 2009 IDT, I installed the mod as instructed but when i turn on the speedcam in the Warning Option, i do not see the speedcam icons on the map nor a voice warning (which is also turned on in the options). Are we missing any of the speedcam files? Quote Link to post Share on other sites
ill.die.trying Posted August 7, 2009 Author Report Share Posted August 7, 2009 IDT, I installed the mod as instructed but when i turn on the speedcam in the Warning Option, i do not see the speedcam icons on the map nor a voice warning (which is also turned on in the options). Are we missing any of the speedcam files? do you have a speedcam text file? if not then you have to add that to myflashdisk/apl2/igo/content/speedcam Quote Link to post Share on other sites
spiceditup Posted August 7, 2009 Report Share Posted August 7, 2009 IDT, I installed the mod as instructed but when i turn on the speedcam in the Warning Option, i do not see the speedcam icons on the map nor a voice warning (which is also turned on in the options). Are we missing any of the speedcam files? do you have a speedcam text file? if not then you have to add that to myflashdisk/apl2/igo/content/speedcam That's prob the problem, i'll just have to load the speedcam.spud file from CMH's mod. Thanks for the reminder. Quote Link to post Share on other sites
ill.die.trying Posted August 7, 2009 Author Report Share Posted August 7, 2009 IDT, I installed the mod as instructed but when i turn on the speedcam in the Warning Option, i do not see the speedcam icons on the map nor a voice warning (which is also turned on in the options). Are we missing any of the speedcam files? do you have a speedcam text file? if not then you have to add that to myflashdisk/apl2/igo/content/speedcam That's prob the problem, i'll just have to load the speedcam.spud file from CMH's mod. Thanks for the reminder. no prob, also, it may take a while to boot after you put the speedcam file as the unit converts the file to spud Quote Link to post Share on other sites
69sixpackbee Posted August 7, 2009 Report Share Posted August 7, 2009 Just an FYI, I deleted the entire "Speedcams" folder in "My Flash Disk\APL2\iGo\CONTENT..." and replaced it with the files and the .spud files from my last saved V2.0 setup and now everything seems to be well. No more re-boots I changed the slider bar increments in the "speedcam_800_480.ui" file from this: To this: I also had to uncomment this line of text in the "Speedcam.ui" file: SETFORMATTED_UNIT_TEXT txtSC_SpeedUnit "km/h" Now it displays the correct units and the speed selected jives with the correct spoken alert. But still, the smaller "SpeedUnitMI" value , that is the 20 Font, directly below the larger text that is displayed for the appropriate speed now does not jive as they are now both displaying "MPH" units so I am trying to remove it from the slider bar display entirely. I have commented it out in a few places but it just hangs the system up so I will keep working. It is just one of those annoyances I want to delete. All in all very good! Any suggestions? Thanx for the hard work, bro., Bud Quote Link to post Share on other sites
ill.die.trying Posted August 7, 2009 Author Report Share Posted August 7, 2009 Just an FYI, I deleted the entire "Speedcams" folder in "My Flash Disk\APL2\iGo\CONTENT..." and replaced it with the files and the .spud files from my last saved V2.0 setup and now everything seems to be well. No more re-boots I changed the slider bar increments in the "speedcam_800_480.ui" file from this: To this: I also had to uncomment this line of text in the "Speedcam.ui" file: SETFORMATTED_UNIT_TEXT txtSC_SpeedUnit "km/h" Now it displays the correct units and the speed selected jives with the correct spoken alert. But still, the smaller "SpeedUnitMI" value , that is the 20 Font, directly below the larger text that is displayed for the appropriate speed now does not jive as they are now both displaying "MPH" units so I am trying to remove it from the slider bar display entirely. I have commented it out in a few places but it just hangs the system up so I will keep working. It is just one of those annoyances I want to delete. All in all very good! Any suggestions? Thanx for the hard work, bro., Bud i'll try to have a fix for this, some like hiding the kmh and showing MPH/MPY depending on the unit setting, glad you had fixed the reboot problem Quote Link to post Share on other sites
