lotust Posted October 1, 2009 Report Share Posted October 1, 2009 Fing sweeeeet I should just leave my GPS out on the coffee table for easy modding Quote Link to post Share on other sites
ovalball Posted October 1, 2009 Report Share Posted October 1, 2009 Hi IDT, Great work,thanks.I seem to have a problem with the schemes which i had from dpdurst.They are still there to be selected but i get the message file not found and the nav part of the avic won't reopen.All i did was copy the new data.zip and sys.txt files over>have i missed something?Thanks again. Quote Link to post Share on other sites
dpdurst Posted October 1, 2009 Report Share Posted October 1, 2009 Hi IDT, Great work,thanks.I seem to have a problem with the schemes which i had from dpdurst.They are still there to be selected but i get the message file not found and the nav part of the avic won't reopen.All i did was copy the new data.zip and sys.txt files over>have i missed something?Thanks again. Â Did you copy the new GFX folder I have as well? Did you copy the ui_igo8\common folder out of my data.zip into the idt data.zip? If they were working before, sounds like the ui_igo8\common folder is the issue as that is where some of the spr files and such would be located. Quote Link to post Share on other sites
misterblue Posted October 1, 2009 Report Share Posted October 1, 2009 Thank you for your great job! Have you corrected the problem of adding mobile camera speed ? Quote Link to post Share on other sites
ovalball Posted October 1, 2009 Report Share Posted October 1, 2009 Hi IDT, Great work,thanks.I seem to have a problem with the schemes which i had from dpdurst.They are still there to be selected but i get the message file not found and the nav part of the avic won't reopen.All i did was copy the new data.zip and sys.txt files over>have i missed something?Thanks again. Â Did you copy the new GFX folder I have as well? Did you copy the ui_igo8\common folder out of my data.zip into the idt data.zip? If they were working before, sounds like the ui_igo8\common folder is the issue as that is where some of the spr files and such would be located. Â Yes that was it.I have now copied the ui igo 8 files over and..happy days!Thanks again for your help. Quote Link to post Share on other sites
69sixpackbee Posted October 1, 2009 Report Share Posted October 1, 2009 What is the diff between the Simple and Full display? No more ability to change the camera warning distance? Â Thanx! Bud Quote Link to post Share on other sites
69sixpackbee Posted October 1, 2009 Report Share Posted October 1, 2009 Youu say add the 3D cars to the IGO8 folder...where is the IGO8 folder? Â Thanx, Bud Quote Link to post Share on other sites
ill.die.trying Posted October 1, 2009 Author Report Share Posted October 1, 2009 Thank you for your great job! Have you corrected the problem of adding mobile camera speed ? Â i have tried and could not get it working, i tried using cmh's and his doesn't work either so i'll just let it be, Quote Link to post Share on other sites
ill.die.trying Posted October 1, 2009 Author Report Share Posted October 1, 2009 What is the diff between the Simple and Full display?No more ability to change the camera warning distance?  Thanx! Bud  simple is the small one you see just below the time/date area, full is the big box i will look into it, when i was going through the speedcam.ui i noticed a lot of useless commands and stuff that's why i deleted them Quote Link to post Share on other sites
ill.die.trying Posted October 1, 2009 Author Report Share Posted October 1, 2009 Youu say add the 3D cars to the IGO8 folder...where is the IGO8 folder?  Thanx, Bud  just add the car model that you want to the gfx folder and then follow the instruction on page 78 Quote Link to post Share on other sites
ill.die.trying Posted October 1, 2009 Author Report Share Posted October 1, 2009 69sixpackbee  thanks for the donation bro Quote Link to post Share on other sites
jelacf Posted October 1, 2009 Report Share Posted October 1, 2009 Hi IDT, Great work,thanks.I seem to have a problem with the schemes which i had from dpdurst.They are still there to be selected but i get the message file not found and the nav part of the avic won't reopen.All i did was copy the new data.zip and sys.txt files over>have i missed something?Thanks again. Â Did you copy the new GFX folder I have as well? Did you copy the ui_igo8\common folder out of my data.zip into the idt data.zip? If they were working before, sounds like the ui_igo8\common folder is the issue as that is where some of the spr files and such would be located. Â Yes that was it.I have now copied the ui igo 8 files over and..happy days!Thanks again for your help. Hi,did you copy all ui igo8 or just replaced the commom folder Thank's Quote Link to post Share on other sites
misterblue Posted October 2, 2009 Report Share Posted October 2, 2009 Thank you for your great job! Have you corrected the problem of adding mobile camera speed ? Â i have tried and could not get it working, i tried using cmh's and his doesn't work either so i'll just let it be, is this really strange problem? " But it worked well in the CMH's mod. If I could help I will gladly. It should perhaps leave the origin files "speedcam" can resume modifies one after the other to identify the problem? Quote Link to post Share on other sites
dpdurst Posted October 2, 2009 Report Share Posted October 2, 2009  Yes that was it.I have now copied the ui igo 8 files over and..happy days!Thanks again for your help. Hi,did you copy all ui igo8 or just replaced the commom folder Thank's  common folder is inside the ui_igo8 folder, so copy the ui_igo8 folder with the common folder. They go together. Quote Link to post Share on other sites
misterblue Posted October 2, 2009 Report Share Posted October 2, 2009 I have a problem: I moved the buttons "Simulation Control Mod" ;Simulation Control Mod but when I made a simulation, the buttons are invisible except the "stop button". How to solve this problem? Quote Link to post Share on other sites
Join the conversation
