don_her Posted April 4, 2013 Report Share Posted April 4, 2013 Ok... Does anybody have the europe maps available for download? Quote Link to post Share on other sites
zainbadri Posted April 25, 2013 Report Share Posted April 25, 2013 Hi, i am new to this form, can someone PM me the link where i can download the entire 2012 map TOMTOM for AVICZ-3 Thanks Zain Quote Link to post Share on other sites
HeavyD2000 Posted May 2, 2013 Report Share Posted May 2, 2013 Hi, i am new to this form, can someone PM me the link where i can download the entire 2012 map TOMTOM for AVICZ-3 Thanks Zain It's in post #67 of this thread..Link below. http://avic411.com/i...eased/?p=254446 Quote Link to post Share on other sites
trey112274 Posted May 11, 2013 Report Share Posted May 11, 2013 Thank you whoever is seeding! I cant wait to try this. Will post my results and of course I will continue to seed as well! Quote Link to post Share on other sites
kwinders Posted May 16, 2013 Report Share Posted May 16, 2013 It's in post #67 in this thread... Thanks Gerrett, I sent my drive to you the last two times and was actually looking to see if there were new maps yet to send you my drive again when I stumbled on this thread. I was able to get everything going on the new maps, it was a bit of a pain, couldn't get any of my Windows7 laptops to work with Acronis10, even in XP mode on my Win7Pro laptop. I ended up getting one of my old laptops out that was still running XPsp3 and used a USB-IDE adapter and it worked great. I created a backup of my drive before i did it. Could I simply retore that image to a larger drive if I wanted to go bigger or would it still need to be unlocked before install? Thanks again. Quote Link to post Share on other sites
garrettoomey Posted May 16, 2013 Report Share Posted May 16, 2013 The larger drive has to be Toshiba and you would have to increase the size of the MSV partition if you wanted the extra space for music. You would want to disable the security feature on the new drive using a program called MHDD. Quote Link to post Share on other sites
H4sh Posted May 23, 2013 Report Share Posted May 23, 2013 Or seed this one, that would be even better! I posted in the 2010 thread before finding this one. I can go from stock z1 to this correct? Quote Link to post Share on other sites
kiuk_k Posted June 5, 2013 Report Share Posted June 5, 2013 hello I have some questionsi have downloaded file 2012-1100HD HDD IMAGE cndv also have created a hdd following the steps according to the manual that was inside. The problem is that when we shove hdd car system recognizes it not as hdd.So first I need to do an update of the pioneer firmwire then to put the hdd with the new image that you recognize?Second, this hdd has already received a password which is the way to delete this password?If is possible can tell me how to do that hdd not receive the password and you can send a manual in pm to explain the procedure to create the image Thank you Undo edits Alpha Quote Link to post Share on other sites
Dohnerd1 Posted June 27, 2013 Report Share Posted June 27, 2013 Does anybody have a link for european version ? Quote Link to post Share on other sites
dluisao Posted July 17, 2013 Report Share Posted July 17, 2013 you find EU version? Quote Link to post Share on other sites
tac-paintball Posted July 24, 2013 Report Share Posted July 24, 2013 am downloading and will seed indefinitely have a 50 mbit landline so will not be a problem for you guys to take it BUT if you download you MUST seed minimum of 2 times the incoming data that way there will be more seeders and others will have a faster download Quote Link to post Share on other sites
latechsupport Posted July 28, 2013 Report Share Posted July 28, 2013 Could some others please seed this; only have 1 at the moment and shows about 3 Days Thanks! Quote Link to post Share on other sites
oldpapa49 Posted August 15, 2013 Report Share Posted August 15, 2013 Hello Garretoomey, I got a hard drive from you way back when with updated maps.. You supplied the HD and all.. What do I need to check to see if I can do an update with out a lot of hassle.. I like to update before my Vacation.. BTW, last time I was here was 2009.. Its a Z2 Old Quote Link to post Share on other sites
oldpapa49 Posted August 16, 2013 Report Share Posted August 16, 2013 A Little note of what I have: Platform Version: 3.000100 GPS Program Version: 1.200000 HDD Application Version: 3.100200 Version: 03.0000 CDDB Version: 08-01-0010 I skipped the Device #.. Off screen of Z2 It is a drive I got fro you Garretoomey way back, poss 2009 I wonder if the drive is unlocked.. If not I will use the CD to unlock. Old Quote Link to post Share on other sites
oldpapa49 Posted August 17, 2013 Report Share Posted August 17, 2013 All updated. Was my USB to IDE adapter. I used an older computer with Arconis True Image 2013 and did the upgrade. Works fine. TY you all. Old Quote Link to post Share on other sites
