edannan Posted September 26, 2012 Report Share Posted September 26, 2012 A quick question regarding navigating to bue tooth setup. Was the firmware upgrade on the SD card or an upgrade that you did from the unit itself? Quote Link to post Share on other sites
bridge4d Posted September 26, 2012 Report Share Posted September 26, 2012 A quick question regarding navigating to bue tooth setup. Was the firmware upgrade on the SD card or an upgrade that you did from the unit itself? No clue. I did have the SD card in the unit though, so it could have been on the card. Quote Link to post Share on other sites
pionara Posted September 26, 2012 Author Report Share Posted September 26, 2012 the firmware is on the sd card (in the firmware folder), but you must initiate the bt fw update from in the phone menu, after you have done the main unit upgrade Quote Link to post Share on other sites
SvenHoek Posted September 27, 2012 Report Share Posted September 27, 2012 fwiw, and for anyone intersted. I have sucesfully used this update on my Z120. I started with a Z120 with the CNSD-210FM/UC patch (>130). First, I ran the "RenewalIFLib-AUTO-REPLACER v1.1", did a reboot, then put in the SD card with the CNSD-310FM/UC update using the "CARDINFO from CNSD-210FM" file in place of the included in teh upgrade rar. Eveything worked flawlessly. Thanks to all you brilliant minds that made this all possible. Quote Link to post Share on other sites
xpl0sive22 Posted September 27, 2012 Report Share Posted September 27, 2012 again, does anyone know if I can go straight from the Z110 to the Z140 software? or do I have to go to 130 first? Quote Link to post Share on other sites
pionara Posted September 27, 2012 Author Report Share Posted September 27, 2012 xplosive - you can only try I have not tried it, but knowing what i know about these series, i dont think it will hurt. With one caveat: The patched version floating around here is a bit newer, and I'm not sure if it's binary compatible with the earlier version of software. So this means that: 1. use testmode to manually backup your existing, RenewalIFLib.dll. Then deploy the new one floating around here via autoinstaller. 2. If that doesn't work, and the unit doesnt do accept any keycode, then that probably means you need to manually patch your original RenewalIFLib.dll (like in the first thread), and then you can use the autoinstaller script to redeploy that one. I have asked Condi to see if he can automate that first step in his RenewalIFLib auto replacer script. Quote Link to post Share on other sites
RonS Posted September 27, 2012 Report Share Posted September 27, 2012 again, does anyone know if I can go straight from the Z110 to the Z140 software? or do I have to go to 130 first? For a "virgin" Z110 or Z120 (or a Z110 w/CNSD-110FM), you should be able to just install the well known ShortFuse hacked files to the Pioneer patch release (1.001 or 2.001), then install any of the upgrades (CNSD-110FM, CNSD-210FM or CNSD-310FM). See those message threads for instructions and the Shortfuse files. The older Shortfuse hack method overwrote RenewalIFLib.dll with the hacked version (basically same as now) and a patched EUR090APL.VER, which just updates the software version number so the installation will overwrite the existing major version. It is important to get the correct Pioneer update (from Pioneer website or links in the message thread)to match the application version that is currently on your HU, and the correct ShortFuse patched files. All this info has been available here for ages. Once the hacked files are installed (technically, only RenewalIFLib.dll matters), you should be able to upgrade to any higher firmware version using a 16 char (alpha) password. Quote Link to post Share on other sites
edannan Posted September 27, 2012 Report Share Posted September 27, 2012 Thanks for the BT firmware info. I'll put the SD card back in and give it a try. Quote Link to post Share on other sites
xpl0sive22 Posted September 27, 2012 Report Share Posted September 27, 2012 thanks for the replies guys. I'll read through the previous upgrade threads and give it a go Quote Link to post Share on other sites
y22kc Posted September 27, 2012 Report Share Posted September 27, 2012 I have a x920bt and have tried and tried to get this to work. I've even went and bought some new SD cards thinking mine were bad. Here is where I am. I run the Renewal auto installer. Screen gives message it succeeded and reboots. Once it reboots, it hangs on the Pioneer splash screen and never boots beyond. I've tried to have the map sd in place, but it never detects it. I've ran the Renewal auto installer several times to no avail. I'm now stuck with my x920bt not working at all. What should I try? Testmode manual installation? Quote Link to post Share on other sites
garrettoomey Posted September 27, 2012 Report Share Posted September 27, 2012 I have a x920bt and have tried and tried to get this to work. I've even went and bought some new SD cards thinking mine were bad. Here is where I am. I run the Renewal auto installer. Screen gives message it succeeded and reboots. Once it reboots, it hangs on the Pioneer splash screen and never boots beyond. I've tried to have the map sd in place, but it never detects it. I've ran the Renewal auto installer several times to no avail. I'm now stuck with my x920bt not working at all. What should I try? Testmode manual installation? Did you use v1.1 of the auto installer, RenewalIFLib-AUTO-REPLACER v1.1? Did you place the correct RenewalIFLib.dll file on the SD root with RenewalIFLib-AUTO-REPLACER v1.1? Quote Link to post Share on other sites
y22kc Posted September 27, 2012 Report Share Posted September 27, 2012 I did use the 1.1 and the RenewalFLib.dll and forgot to mention I tried the new and the old cardinfo files, it still doesn't recognize the sd card nor boots past the Pioneer splash screen Quote Link to post Share on other sites
y22kc Posted September 27, 2012 Report Share Posted September 27, 2012 I can get the unit into test mode by the home button with up/down sequences. I guess I'm gonna try to manually install the RenewalFLib.dll and see what happens. Quote Link to post Share on other sites
edannan Posted September 27, 2012 Report Share Posted September 27, 2012 Installed the SD card again, went to BT settings selected "firmware" and upgraded without a hitch. Thanks! Quote Link to post Share on other sites
botanikos Posted September 27, 2012 Report Share Posted September 27, 2012 Help Quote Link to post Share on other sites
