paul2sail Posted January 9, 2008 Report Share Posted January 9, 2008 Just a quick question. I am installing the bypass on my d3 and have the bluetooth unit. I am installing on an 03 suburban. Was wondering if moving the mute wire will affect my bluetooth? If so where can i get a new connector with wire to plug into the spot where the mute wire would be moved to? Any help would be great. Quote Link to post Share on other sites
HiFiSi Posted January 9, 2008 Report Share Posted January 9, 2008 Just a quick question. I am installing the bypass on my d3 and have the bluetooth unit. I am installing on an 03 suburban. Was wondering if moving the mute wire will affect my bluetooth? If so where can i get a new connector with wire to plug into the spot where the mute wire would be moved to? Any help would be great. No, the bluetooth unit interacts with the D3 only over the IPBUS cable, It doesn't use the mute wire. Quote Link to post Share on other sites
Turbocoop Posted January 14, 2008 Report Share Posted January 14, 2008 yeah my bluetooth works fine with this bypass done. I dont see why everyone is having problems, it was easy and it works fine with mine. Quote Link to post Share on other sites
joe r Posted January 21, 2008 Report Share Posted January 21, 2008 Thanks,this info helped bypass my wifes D3. joe r Quote Link to post Share on other sites
KRAZYCLAY Posted January 24, 2008 Report Share Posted January 24, 2008 This is probably a very stupid question..but I understand how to move the mute wire...BUT how do you "ground that and the other wire? I know the mute wire is placed into the new hole...but is there some sort of "other" wire that is also placed in that same hole, and then bolted to a screw somewhere???? Can someone explain in detail the "grounding" process? Thanks, Krazy Quote Link to post Share on other sites
whtcrxghst Posted January 24, 2008 Report Share Posted January 24, 2008 The pin goes in the new hole. The other end of the wire, and the green parking brake wire need to get connected to ground. So you can either splice it to a 'ground' wire to a bolt Quote Link to post Share on other sites
cntrylvr79 Posted January 25, 2008 Report Share Posted January 25, 2008 19 pages long for something simple.... Quote Link to post Share on other sites
Tzmn06 Posted February 17, 2008 Report Share Posted February 17, 2008 I was wondering if the bypass is still possible to do after the unit is completely installed? Also would I remove the speed sensor wire and ground that after doing the bypass? Thanks Quote Link to post Share on other sites
whtcrxghst Posted February 17, 2008 Report Share Posted February 17, 2008 Of course its possible, just follow the instructions. And don't ground the speed sense, just follow the instructions like thousands of other people I was wondering if the bypass is still possible to do after the unit is completely installed? Also would I remove the speed sensor wire and ground that after doing the bypass? Thanks Quote Link to post Share on other sites
KRAZYCLAY Posted February 18, 2008 Report Share Posted February 18, 2008 Everyone..I have a D3 with a manufactured date of OCT 2007. I know for a fact that the wiring was done properly, and I have also tried resetting the unit. Any idea what those of us with the more recently producted units, can do about the bypass? Quote Link to post Share on other sites
whtcrxghst Posted February 18, 2008 Report Share Posted February 18, 2008 I know for a fact that you did something wrong. They are all bypassable exactly the same way Everyone..I have a D3 with a manufactured date of OCT 2007. I know for a fact that the wiring was done properly, and I have also tried resetting the unit. Any idea what those of us with the more recently producted units, can do about the bypass? Quote Link to post Share on other sites
cntrylvr79 Posted February 18, 2008 Report Share Posted February 18, 2008 yep, just bypassed a January 08 D3 today the same way as every other d3. Quote Link to post Share on other sites
393stroker Posted February 20, 2008 Report Share Posted February 20, 2008 i just got me an avic D-3 and it was already bypassed from the looks of the pic on 1st page. i'll try it like that to see if it works. i need to know where to hook the pink wire and purple one on a 99 ford expedition? thanks Quote Link to post Share on other sites
seang92 Posted February 23, 2008 Report Share Posted February 23, 2008 I have the D-3 and had the installer install the module that keeps the Onstar and steering wheel buttons working. When I went into try to do the bypass I noticed that the RCA harness isn’t even used. So I skipped the part about moving the mute white since I assumed it wasn’t even an option. So I went ahead and grounded the parking brake, now the menu states that the parking brake is on but after going faster than like 5-10mph the screen goes blank giving me a message about driving while watching is unsafe. What am I missing since there is no option to move the mute wire? Quote Link to post Share on other sites
whtcrxghst Posted February 23, 2008 Report Share Posted February 23, 2008 You're missing the RCA harness. Get it, move the wire, stick it in the D3, ground the wire, you're done. Just like the instructions say I have the D-3 and had the installer install the module that keeps the Onstar and steering wheel buttons working. When I went into try to do the bypass I noticed that the RCA harness isn’t even used. So I skipped the part about moving the mute white since I assumed it wasn’t even an option. So I went ahead and grounded the parking brake, now the menu states that the parking brake is on but after going faster than like 5-10mph the screen goes blank giving me a message about driving while watching is unsafe. What am I missing since there is no option to move the mute wire? Quote Link to post Share on other sites
Join the conversation
