Jump to content
AppRadio 2 screen issue/repair
appradio2 appradio 2
  • Please log in to reply
41 replies to this topic
#31 vjaneczko
vjaneczko
    Member
  • Members
  • 55 posts
  • LocationItasca, IL
Posted 14 December 2015 - 06:58 PM
Wondering if anyone has found a solution for the screen issue? Not in the mood to ship it out for repair; has anyone tried the blow dryer tip?
Volvo S60 R Passion Red
Pioneer AppRadio2 - Samsung Note 3
#32 etxxz
etxxz
  • Members
  • 6 posts
Posted 17 December 2015 - 11:47 PM
BLOW DRYER DOESNT WORK.... sigh... as my post said, you have to replace the whole front liquid crystal screen and button panel. Its one part.
#33 blacknanna
blacknanna
  • Members
  • 1 posts
Posted 09 January 2016 - 10:27 AM
Can I get some clarification on the cause of this problem (apart from poor design and construction). Is it a case where the heat inside the car is causing this to happen? Mine didn't start coming apart until early summer and has got progressively worse as summer continues, however other comments in other forums have suggested it has happened to then during cooler periods. In Australia the replacement costs around $150 but I'm not going bother if the problem is just random or age related.
#34 itscervo
itscervo
  • Members
  • 3 posts
Posted 03 February 2016 - 09:43 PM
The problem is caused by a loss of adhesion or delamination of the inner & outer screen, when this happens you usually have a loss of response in the affected area with no physical signs of a defect. The app radio screen issue is really unusual due to the fact you can actually see the affected area.
The last resort repair method only works on resistive touch type screens.
The last resort repair attempt method is to remove the touch screen from the unit & separate it from the lcd screen, then place the glass screen on a perfectly clean flat surface, apply heat over the entire screen with a hair dryer & gently apply slight pressure on the the screen & repeat as necessary, I use a wide rubber roller (block printing type) or you could use a rolling pin with a thin piece of cloth to protect the screen.
#35 Bigsike
Bigsike
    Member
  • Members
  • 52 posts
Posted 08 May 2016 - 07:54 PM
Well add me to this list as mine started about 2 months ago, I take it that no one has a solution for this? I can't seem to find a replacement screen or anything. This is just sickening.
#36 OniKyanAE86
OniKyanAE86
  • Members
  • 1 posts
Posted 01 June 2016 - 04:52 PM
So I live in Arizona where it gets very hot during the summer and you would expect this to happen with extreme heat, funny thing was, it happened to me during the winter with the cold. It started on the right side of the screen and within a week spread all across the screen. Touch was still working, but ended up purchasing a new replacement touchscreen from Pioneer. I'm registered on Pioneer's parts site so having the service manual to be able to order the parts by it's part number came in very handy. I did call Pioneer regarding this and basically was told to kick rocks.... thanks Pioneer....
#37 vjaneczko
vjaneczko
    Member
  • Members
  • 55 posts
Posted 01 June 2016 - 06:46 PM
Care to share the price of the new screen? Might want to get one if its inexpensive.
#38 rockthebeef
rockthebeef
    Member
  • Members
  • 224 posts
Posted 20 June 2016 - 05:07 PM
I just saw a post on another forum with a picture of this happening on an AppRadio4! I guess even if the AR4 screen is made differently than the AR2 (source: Pioneer email), it didn't do much good.
http://appradioworld...1196.html#a1199
#39 dacliber
dacliber
  • Members
  • 8 posts
Posted 24 September 2016 - 08:57 AM
in my opinion, the heating problems arise because the speakers are not compatible with the unit. OEM speakers have 2 ohm and unit drive out minimum 4ohm, if you listen at high volume streaming via Bluetooth result is very hot. I have also a problem with touch, but diferent- not respond at all, after i dont use this unit 1 year. I put it back and no respond.
#40 jones66
jones66
    Member
  • Members
  • 55 posts
  • LocationGenoa,italy
Posted 02 November 2016 - 08:28 PM
now after 2 year the SPHDA 100 have the same problem on the screen!!!!!
#41 sjorge3442
sjorge3442
  • Members
  • 1 posts
Posted 07 November 2016 - 07:42 PM
This is a very interesting thought! Which I never thought about the heat from the actual unit causing the issue. However, I noticed this issue following hot summer days in Philly. Now my Appradio 2 is almost impossible see in the sun, but still works flawlessly.
Who has the links for screen replacement? I wouldnt mind doing this myself if its doable.
#42 Iaceves80
Iaceves80
  • Members
  • 1 posts
Posted 31 July 2017 - 11:07 PM
Do you have the touch screen for sale, I have the same problem, but my screen no longer serves in its entirety
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
