fanourio Posted October 19, 2017 Report Share Posted October 19, 2017 Does anybody know where we can find the MAP file on the MRZ? I think that if we locate the map file, which is a map of Japan, somebody can edit that and transform it into map of Europe or country or whatever.... Otherwise i need to know how to install IGO or any other navigator on my MRZ 09. Any ideas? Quote Link to post Share on other sites
Ilnur Posted October 19, 2017 Report Share Posted October 19, 2017 Можно и Европу и РоÑÑии еÑли внедрить в mrz android Quote Link to post Share on other sites
serg_nestor1985 Posted October 19, 2017 Report Share Posted October 19, 2017 It's a C program that takes 2 parameters, the filename of an input bitmap and the filename for an output bitmap. Compile it and from a command line do: fixbmpheader b1853.bmp b1853a.bmp b1853a should then be the correct size. Ðе получаетÑÑ, поÑле Ñтого файл не открываетÑÑ. Ðо Ñ Ð½Ð°ÑˆÐµÐ» онлайн конвертер, и выÑÑнил, что правильно конвертировать в 16 бит (5:5:5:1 Hi Color). ПолучаетÑÑ Ð²ÑÑ‘ Ñразу. Проверил. It does not work, after that the file does not open. But I found an online converter, and found out that it's correct to convert to 16 bits (5: 5: 5: 1 Hi Color). It turns out all at once. Checked. Quote Link to post Share on other sites
yachur1982 Posted October 19, 2017 Report Share Posted October 19, 2017 ЗдравÑтвуйте. Ð¡ÐµÐ³Ð¾Ð´Ð½Ñ Ñделал backup папки USER Ñвоей MRZ06. ПыталÑÑ Ð¿ÐµÑ€ÐµÐ²ÐµÑти на английÑкий, но ничего не получилоÑÑŒ. Пробовал и в ручную и Ñкриптом, вÑÑ‘ равно ЯпонÑкий Ñзык. ПоÑмотрите пожалуйÑта мой backup, в чем может быть дело? https://drive.google.com/open?id=0B4xXGSg6VKf0YUtCX0lZUTdNTlE Quote Link to post Share on other sites
Gladma Posted October 21, 2017 Report Share Posted October 21, 2017 Mr Dzo let me thank you for giving my radio MRZ0047 some life. I used the file that you shareon page 7 if am not wrong NA090jp....it worked on my radio that I posted in another forum as MRZ30047zy or nmdp-w59. There are few threads remaining with Japanese. The CD menu and other few.Do you have the final translation for this. Mine is build 06. Quote Link to post Share on other sites
Gladma Posted October 21, 2017 Report Share Posted October 21, 2017 It is version 1.000500 Quote Link to post Share on other sites
EnoKt Posted October 24, 2017 Report Share Posted October 24, 2017 Hi Mr. Dzo. I am new in this forum, so bear with me. My Pioneer Carrozzeria AVIC Mrz09 now reads mostly in English, after following the latest zip file except areas where the Japanese GPS map is involved. One thing though: Is there a way of correcting time zone to +3 GMT. I am in East Africa. Is any able to do so anyway anyhow?. How about changing FM frequencies to read up to 108 Mhz.? Many thanks to all of you here in advance. Quote Link to post Share on other sites
Gladma Posted October 25, 2017 Report Share Posted October 25, 2017 https://drive.google.com/file/d/0B_-EgSnaB4FvLTFndENpQmEtVnM/view?usp=sharing This is the link of my files. Or how to I use the edits done in post #162 Quote Link to post Share on other sites
4L6QC Posted October 29, 2017 Report Share Posted October 29, 2017 Дорогой Дзо! Я дошел до Ñтого шага: delete PF090JPJPN.LNG go to /SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA where the old one was. Ðо Ñкопированный Ñ SD файл невозможно Ñделать PASTE в папку LANGDATA (не подÑвечиваетÑÑ PASTE) Помогите пожалуйÑта Quote Link to post Share on other sites
4L6QC Posted October 29, 2017 Report Share Posted October 29, 2017 Dear Dzo! I reached this step for MRZ99: "remove PF090JPJPN.LNG go to / SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA, where was the old one. " But copied from SD file it is impossible to make PASTE in the folder LANGDATA (not highlighted by PASTE) help me please Quote Link to post Share on other sites
Ilnur Posted October 29, 2017 Report Share Posted October 29, 2017 Dear Dzo! I reached this step for MRZ99: "remove PF090JPJPN.LNG go to / SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA, where was the old one. " But copied from SD file it is impossible to make PASTE in the folder LANGDATA (not highlighted by PASTE) help me please Входит в ÑервиÑное меню Ñ Ð¿Ð¾Ð¼Ð¾Ñ‰ÑŒÑŽ testmode и Ñти иконки будут активными Quote Link to post Share on other sites
4L6QC Posted October 29, 2017 Report Share Posted October 29, 2017 именно иконка paste не активна Quote Link to post Share on other sites
Ilnur Posted October 29, 2017 Report Share Posted October 29, 2017 Значит вы не правильно делаете copy Quote Link to post Share on other sites
4L6QC Posted October 29, 2017 Report Share Posted October 29, 2017 Ñ Ð²Ñ‹Ð´ÐµÐ»ÑÑŽ файл на СД карте, делаю Ñелект, копирую, потом выхожу через меню в LANGDATA, но уже там иконка паÑте - Ð¼Ñ‘Ñ€Ñ‚Ð²Ð°Ñ Quote Link to post Share on other sites
