EnoKt Posted July 17, 2019 Report Share Posted July 17, 2019 On 7/11/2019 at 6:47 PM, Eder said: Tengo el mismo problema en mi mrz09 pero no he hecho una copia de seguridad .... porfavor de agradecería que me pases los archivos que están en USER y me indiques los pasos que hiciste para que la radio vuelva a su normalidad porfavor On page 19 this member here posted a link to access mrz09 backup. i hope it will help you if the unit can paste those files in USER folder. I am not sure of the outcome. So do it at your own risk. manio112 Member Members 22 posts Report post Posted October 15, 2017 HI TO ALL AND THANKS DZO FOR HIS JOB I HAVE BACKUP OF MRZ09 MAYBE SOMEBODY NEED LINK FOR IT https://mega.nz/#F!nUwjVLxZ!1soULiYcJRyf1W3ANrSFZg Quote Quote Link to post Share on other sites
yoppi2010 Posted July 23, 2019 Report Share Posted July 23, 2019 On 2019/7/12 at 11:42 AM, dzo said: That .DAT file looks fine (the subaru logo), though it might be upside down. Looks like you are close, seems like the checksum in the VER file is not correct. The other VER files in your zip seem to use a different checksum method, (crc32b). Try the attached makever.c instead. You might also want to try creating an OPN100 folder with the .DAT file in it and copying the ver file to OPN.VER . When it worked, my folder structure looked like this: AVICMRZ90/ --NA090OPN.DAT --NA090OPN.VER --OPN.VER --OPN090/ ----NA090OPN.DAT makever.c Thank you for your support. Not all are perfect, but some opening boot images were modifiable. I wrote a way to apply the opening image with the help of Mr. dzo. [How to change the opening image of Raku Navi] 1. In the test mode on the navigation side, select "Start writing data(プログラム強制書換)" from "Opening Image data write(起動データ書き込み)", and check the *** characters of ***.OPN (Example:NA090.OPN) 2.Edit the image you want to display with GIMP etc.Make a mirror image and upside down the image Save it as bmp 800x480 in size. 3.Display the .bmp image saved earlier with the binary editor Copy the character string from [00 00 00 00 00] (00008A) to the end, and 00000000 a5 5a 5a a5 00 b8 0b 00 bc ea cd 15 00 00 00 01 |.ZZ.............| 00000010 01 00 00 00 00 00 00 00 4e 41 30 39 30 4f 50 4e |........NA090OPN| 00000020 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| 000001F0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| After that, paste the binary data from 00000008A copied earlier and save it with the number .dat confirmed in 1.(Example:NA090OPN.DAT) ※ At this time, confirm that it is 768, 512 bytes. 4.Download [makever.c] from https://github.com/dzo/mrz99 Open makever.c with a text editor (NA090) and change the three listed to the numbers confirmed in 1. 5.Compile [gcc makever.c -o makever] with the C language compiler (Msys2 or ubuntu for Windows) installed with gcc, and create makever.exe. 6.Put the created .dat in the same folder as makever.exe, and execute [./makever NA090OPN.DAT NA090BOT.VER] from the C language compiler. 7.Create a folder called [AVIC ****] in the SD root folder. Put it in the folder where you made .VER (eg NA090OPN.VER) that came out in 6. (* Indicates the model name of Navi. If you do not know, it is written that you look at the .HTM file of Navi. Example: AVICMRZ90, AVICMRZ0047, etc.) 8.Create a folder called OPN *** in the folder created in 7. (Example: OPN090) Put DAT made in 3 in it (example: NA090OPN. DAT) SD -AVICMRZ090 -NA090OPN.VER -OPN090 -NA090OPN.DAT 9. Insert the SD card into the navigation and open the test mode 10. Open [Forced program write(プログラム強制書換)] → [Opening Image data write(起動データ書き込み)] from the test mode and confirm that the version is displayed in the SD and execute However, I will display a custom image for 5 seconds after launching this way. The remaining 5 seconds is the image before the change. After that, the custom image was displayed for only one second. I'm happy with this because I like it [custom images 5 seconds + original images 5 seconds]. Thank you very much. https://mega.nz/#!wz4wQACR!dy3ddJLRu-uvmKYuAD7pXopShD2U6n8wR7aOTDkNjZ0 Quote Link to post Share on other sites
Eder Posted July 30, 2019 Report Share Posted July 30, 2019 On 17/7/2019 at 11:35, EnoKt said: En la página 19, este miembro publicó aquí un enlace para acceder a la copia de seguridad mrz09. Espero que te ayude si la unidad puede pegar esos archivos en la carpeta USER. No estoy seguro del resultado. Hazlo bajo tu propio riesgo. manio112 Miembro Miembros 22 publicaciones Reportar publicacion Posted octubre 15, 2017 HOLA A TODOS Y GRACIAS DZO POR SU TRABAJO. TENGO RESPALDO DE MRZ09. ALGUIEN PUEDE ALGUIEN NECESITA ENLACE PARA TI https://mega.nz/#F!nUwjVLxZ!1soULiYcJRyf1W3ANrSFZg Citar Me funcionó de maravilla muchas gracias mi radio mrz09 funciona de maravilla...Tengo un primo que también tiene la radio mrz99 y borro también toda las carpeta USER sin hacer copia de seguridad les agradecería que alguien me pueda pasar todo el contenido de la carpeta USER por favor Quote Link to post Share on other sites
Jay8992 Posted August 7, 2019 Report Share Posted August 7, 2019 Good day I have the Avic MRZ05... i cant get it play videos whether from cd nor sd card. is there a way to do so? @dzo @javed akhtar Quote Link to post Share on other sites
Eder Posted August 10, 2019 Report Share Posted August 10, 2019 Alguien que tenga una copia de seguridad de mrz99 porfavor que lo pase Quote Link to post Share on other sites
Jay8992 Posted August 12, 2019 Report Share Posted August 12, 2019 Hey! Is there method in here to change the MRZ90 to english?? @dzo @javed akhtar Quote Link to post Share on other sites
Alex197087 Posted August 13, 2019 Report Share Posted August 13, 2019 Добрый день. Если у вас есть файл обновления для AVIC-Mrz02, отправьте его. Или копия флешки, которая установлена в магнитофон, все функции не работают, на дисплее нет дисплея. Заранее спасибо. Quote Link to post Share on other sites
Eder Posted August 18, 2019 Report Share Posted August 18, 2019 Porfavor si alguien tuviera la copia de seguridad de la radio mrz 99 que sube el Link de descarga porfavor Quote Link to post Share on other sites
javed akhtar Posted August 19, 2019 Report Share Posted August 19, 2019 On 8/8/2019 at 2:30 AM, Jay8992 said: Good day I have the Avic MRZ05... i cant get it play videos whether from cd nor sd card. is there a way to do so? @dzo @javed akhtar you cannot play all video formats, however some common formats like mp4 and others can be played while the car is stop. if you start driving, the video will be hidden. Quote Link to post Share on other sites
St25rus Posted August 26, 2019 Report Share Posted August 26, 2019 (edited) Вопрос о AVIC-MRZ009, как будто и нет этого вопроса, именно вопрос об этой магнитоле как будто игнорируют . КАК Перевести в тестовый режим, по шагам желательно и можно ли вообще перевести на английский ??? Пожалуйста, отпишитесь кто смог это удачно сделать ИМЕННО ДЛЯ AVIC-MRZ009 @DZO еще вопрос какой размер памяти нужен на SD card для резервной копии, чтоб быть уверенным что резервная копия скачалась полностью Edited August 26, 2019 by St25rus не расскрыл весь вопрос Quote Link to post Share on other sites
St25rus Posted August 26, 2019 Report Share Posted August 26, 2019 (edited) 26 минут назад Ст25рус сказал: Вопрос об AVIC-MRZ009, как будто и нет этого вопроса . КАК Перевести в тестовом режиме, по шагам желательно и можно ли вообще перевести на английском ??? Пожалуйста, отпишитесь смог кто это удачно сделать ИМЕННО ДЛЯ AVIC-MRZ009 еще вопрос какой размер памяти нужен на SD карты для резервной копии, чтоб быть уверенным что резервная копия скачалась полностью @Джавед Ахтар Edited August 26, 2019 by St25rus не расскрыл весь вопрос Quote Link to post Share on other sites
St25rus Posted August 28, 2019 Report Share Posted August 28, 2019 On 26.08.2019 at 18:26, St25rus said: Dear Dzo, welcome! Question about the AVIC-MRZ009, why no one can answer it? It is the question of this radio that seems to be ignored. How to translate it into test mode, it’s desirable in steps and is it possible to change it into English at all ??? Please, unsubscribe who could successfully do this. EXACTLY FOR AVIC-MRZ009 !!! There is still a question what memory size is needed on an SD card to create a backup, to be sure that the backup has been downloaded completely ??? @DZO@Джавед Ахтар Quote Link to post Share on other sites
alex3236 Posted August 29, 2019 Report Share Posted August 29, 2019 https://drive.google.com/drive/folders/19xxj6xGvNqBdrTdjGH5-cpUy9ZcoWRNV?usp=sharing user mrz77 english bekup Quote Link to post Share on other sites
Eder Posted September 2, 2019 Report Share Posted September 2, 2019 El 29/8/2019 a las 0:53, alex3236 dijo: https://drive.google.com/drive/folders/19xxj6xGvNqBdrTdjGH5-cpUy9ZcoWRNV?usp=sharing usuario mrz77 inglés bekup Alguien sabe si compatible con el mrz99 ??por favor respondan Quote Link to post Share on other sites
alex3236 Posted September 2, 2019 Report Share Posted September 2, 2019 Yus Quote Link to post Share on other sites
