is300b0y Posted April 20, 2010 Report Share Posted April 20, 2010 garrettoomey: can you pm me on how to contact you. I live in DFW and need to have my z1 upgrade to z3. thanks Quote Link to post Share on other sites
shane.carlson Posted May 10, 2010 Report Share Posted May 10, 2010 Does anyone have a direct link (FTP, Dropbox, etc.) to the file? I have been trying to download the torrent for 4 days. There were originally 3-4 seeders, but they have all dropped off. Any help is appreciated. If someone has the file and is willing to upload it, I have an ftp site I can give you access to. Thanks. Quote Link to post Share on other sites
CaptainInsaneO Posted May 10, 2010 Report Share Posted May 10, 2010 You can try the torrent again, I'm seeding it right now. Quote Link to post Share on other sites
shane.carlson Posted May 10, 2010 Report Share Posted May 10, 2010 Thanks, I see the new seed (and it's fast too ) Quote Link to post Share on other sites
CaptainInsaneO Posted May 10, 2010 Report Share Posted May 10, 2010 Thanks, I see the new seed (and it's fast too ) My pleasure. Garret and I both seeded this thing for months (as far as I know). There are actually 12 seeds in the swarm right now, I'm surprised that you weren't getting data from any of them... Right now I'm only uploading to two people at a time so it's splitting the 200kB/s between those. If you think that's fast right now, I'm in the process of buying a house in a Verizon FiOS area, how does 25mb/s upload sound? Anyway, right now I have a 3mb upload speed, I'm not completely sure why my seedbox isn't saturating that so I will investigate and see if I can get the speed bumped a little for you. If it doesn't change in the next hour it should speed up tonight when the peak usage is down. Quote Link to post Share on other sites
treymsms Posted May 11, 2010 Report Share Posted May 11, 2010 Somebody please HELP! I upgraded from the 310bt to the Z110BT and 8 out of 10 people say i sound muffled. Any suggestions. I have a HTC Hero android os phone. Quote Link to post Share on other sites
CaptainInsaneO Posted May 11, 2010 Report Share Posted May 11, 2010 Somebody please HELP! I upgraded from the 310bt to the Z110BT and 8 out of 10 people say i sound muffled. Any suggestions. I have a HTC Hero android os phone. Make a new thread (and make it in the correct forum). Quote Link to post Share on other sites
shane.carlson Posted May 11, 2010 Report Share Posted May 11, 2010 Thanks, I see the new seed (and it's fast too ) My pleasure. Garret and I both seeded this thing for months (as far as I know). There are actually 12 seeds in the swarm right now, I'm surprised that you weren't getting data from any of them... Right now I'm only uploading to two people at a time so it's splitting the 200kB/s between those. If you think that's fast right now, I'm in the process of buying a house in a Verizon FiOS area, how does 25mb/s upload sound? Anyway, right now I have a 3mb upload speed, I'm not completely sure why my seedbox isn't saturating that so I will investigate and see if I can get the speed bumped a little for you. If it doesn't change in the next hour it should speed up tonight when the peak usage is down. Thanks again, I am getting about 200k download now from 2 peers. I have 15mb/s down and 10 up. I will keep seeding for the foreseeable future even once I have the file. Quote Link to post Share on other sites
royalh Posted May 12, 2010 Report Share Posted May 12, 2010 Question: Is it possible to update the Z2/Z3 (Z2 upgraded with Z3 HDD) firmware to the latest version (3.100400) without any issues? I was able to update the gracenote db on my unit without a problem, but since there's an update out there (even though I don't need it) I wanted to apply it... Yes, I understand that I don't "NEED" it... I just want it! Quote Link to post Share on other sites
CaptainInsaneO Posted May 12, 2010 Report Share Posted May 12, 2010 Is the drive unlocked? If so you should be able to write new maps and everything to it. I know Garret has described the process for keeping music and everything intact during this process as well. I can't say you won't run into issues but if you've already updated the drive once, should be as easy as pie a second go-around. Quote Link to post Share on other sites
royalh Posted May 12, 2010 Report Share Posted May 12, 2010 Is the drive unlocked? If so you should be able to write new maps and everything to it. I know Garret has described the process for keeping music and everything intact during this process as well. I can't say you won't run into issues but if you've already updated the drive once, should be as easy as pie a second go-around. Yes, drive is unlocked. The reason I ask is because in the firmware upgrade instructions, http://www.pioneerelectronics.com/ephox ... VIC-Z3.pdf , it specifically says not to use this update on Z1's or Z2's because "this firmware update could damage those models" I'm wondering if a Z2 upgraded to Z3 would still be susceptible to this possible damage...? Or since I'm using a Z3 HDD image, is it ok to apply the Z3 only firmware upgrade? Quote Link to post Share on other sites
CaptainInsaneO Posted May 12, 2010 Report Share Posted May 12, 2010 If the drive is already upgraded to a Z3 drive, you have all the firmware updates as well. Don't try to apply firmware that isn't meant for the Z3 specifically. Quote Link to post Share on other sites
royalh Posted May 12, 2010 Report Share Posted May 12, 2010 If the drive is already upgraded to a Z3 drive, you have all the firmware updates as well. Don't try to apply firmware that isn't meant for the Z3 specifically. When I look at my 'info' screen, it shows something like 3.100200 as the version, instead of the 3.100400.... But I was able to upgrade the gracenote db successfully... Guess I'll leave it alone then....thanks for the responses! Quote Link to post Share on other sites
shane.carlson Posted May 13, 2010 Report Share Posted May 13, 2010 Thanks again, I am getting about 200k download now from 2 peers. I have 15mb/s down and 10 up. I will keep seeding for the foreseeable future even once I have the file. Damn....sitting at 51% and all the seeds went away.... Quote Link to post Share on other sites
ilvona Posted May 17, 2010 Report Share Posted May 17, 2010 just to be sure... these maps are for america only or also for europe? Quote Link to post Share on other sites
Join the conversation
