stalls Posted April 9, 2015 Report Share Posted April 9, 2015 Ill be happy to report that I preformed the latest update to my chromecast and it works great with screen resolution! well not perfect. It has a slight hesitation for touch controls and when u turn it a certain way in landscape mode it its the complete opposite for touch controls yet again. But hey its wireless and working somewhat properly! Quote Link to post Share on other sites
dannyz3343 Posted April 9, 2015 Report Share Posted April 9, 2015 Yep I know - I was just making sure everything related to Carplay works fine when doing this, and whether or not there is any improvement to Carplay performance. Audio from the phone does not work in CarPlay with this hack right now. Quote Link to post Share on other sites
Covert_Death Posted April 10, 2015 Author Report Share Posted April 10, 2015 Hey guys update time,  I just bought a 4100NEX to upgrade to but while I have both I'll be comparing the differences physically to see what is happening here.  So far I can boot to 1.08 (4000) on my 4100 and experience similar problems as the other way around so I really am starting to think that they changed some of the hardware and didn't make it clear.  The big difference is the screen. not so much the resolution but the presentation. on the 4100 the screen is actually glass like, not that "film" of plastic on the 4000. Its very dense and gloss like in finish not matte. This is the first thing I noticed right off the bat.  I'll be looking into swapping the internal SD Card out to see what happens when I do that (pulling the 4100 SD card and using it in the 4000). But I think I will have to find the devices password to get this to work so we shall so how that goes. Quote Link to post Share on other sites
stalls Posted April 10, 2015 Report Share Posted April 10, 2015 Can u swap the screens and test? Quote Link to post Share on other sites
EditorDZ Posted April 10, 2015 Report Share Posted April 10, 2015 Thanks Covert for continuing your efforts, especially now that you have both units! Quote Link to post Share on other sites
newtonfb Posted April 10, 2015 Report Share Posted April 10, 2015 Hey guys update time,  I just bought a 4100NEX to upgrade to but while I have both I'll be comparing the differences physically to see what is happening here.  So far I can boot to 1.08 (4000) on my 4100 and experience similar problems as the other way around so I really am starting to think that they changed some of the hardware and didn't make it clear.  The big difference is the screen. not so much the resolution but the presentation. on the 4100 the screen is actually glass like, not that "film" of plastic on the 4000. Its very dense and gloss like in finish not matte. This is the first thing I noticed right off the bat.  I'll be looking into swapping the internal SD Card out to see what happens when I do that (pulling the 4100 SD card and using it in the 4000). But I think I will have to find the devices password to get this to work so we shall so how that goes.   Awesome. Thanks for keeping the hope alive Quote Link to post Share on other sites
Covert_Death Posted April 10, 2015 Author Report Share Posted April 10, 2015 Can u swap the screens and test? Screen swapping won't work, I know this because thats the safety feature of the devices. you take the head unit off when leaving your vehicle and if someone steals your radio, its useless, they can't just buy another and use that, it has to be paired. Quote Link to post Share on other sites
rjoc Posted April 11, 2015 Report Share Posted April 11, 2015 I don't have any skin in the game, I have neither of the HUs but I've done a bunch of reversing on Pioneer's firmware and hardware/SD hacking on my unit APPRADIO 4 which has a common software and hardware base.  What's the goal? What do people actually want from the x100 series?  I took a really quick look at the differences between the 4000 / 4100 and it looks like the hardware is super similar, with a few differences:  CPU Unit  * New flash rom - this could mean the BSP has changed (and the SD passwords are different) but can't tell until inspecting the kernel or dumping the flash. The CPU hasn't changed so I'd be surprised if there were significant differences.  Interface Unit  * HD/DAB tuner change * System uCom change  Monitor Unit  * New multi touch panel  DVD Unit  * a Mirrorlink chip is gone (or moved)   What's the same:  * CPU * LCD + backlight * Bascially everything (hardware version KM500B vs KM506B)   When updating things can be done independantly: * Programs * Bootloader * Boot * Recovery Partition * Platform * Opening Data * System uCom firmware * Bluetooth firmware * GPS firmware  The code for x100 is PJ150 and x000 is PJ140. Once updated, unless some core files are manipulated the unit will assume the new hardware's identity.  Its possible to craft an update that mixes and matches units between updates - or leave some out. It's also possible to redo a whole partition.  What this doesn't take into account is sofware and driver versions and how the harware actually talks to each other. e.g. there might many more software than hardware changes that could lead to significant interop issues. I haven't inspected the update to see (an update probbaly isn't detailed enough)  At this stage I don't see any reason to think that the tty assignments have changed on the UART interfaces though.  If I was starting on this from scratch with a x000 unit I think a good first step would be:  * back up internal SD, just in case * make the minumum manipulations to the update to make it apply (i.e change no data just names and headers) * once updated successfully boot into the service test mode with TESTMODE.KEY and run the hardware diagnostics - these cover basically everything, touchscreen, fans, bluetooth, monitor so should show up any issues easily.  I wouldn't force bluetooth, gps or ucom updates at this point - don't want force the HU to brick those components with an incompatible firmware.  If I had a x100 unit I'd dump the SD card and take a gander at that. (swapping unlocked sd cards would be an interesting experiment, as the firmwares wouldnt be touched just potential driver issues - if it worked it'd be funny to think you could just order the SD spare part from pioneer from a newer model to "upgrade")  Quote Link to post Share on other sites
namiam Posted April 12, 2015 Report Share Posted April 12, 2015 Thanks for the mods everyone. I cannot get the links to work for the 4000/4100NEX in the first post. Any ideas? Quote Link to post Share on other sites
shoban13 Posted April 15, 2015 Report Share Posted April 15, 2015 Covert_Death.....Awesome dedication towards this topic bro. Â I was sooooo pissed when Pioneer had to release a new unit just to update Android Auto. Â I bought my 4000NEX during last September just in hopes that Android Auto will be made available as a FW update. Â Like everybody else here, I am also ranting about less than 1 year old unit purchase which now does not meet my expectations. Â Quote Link to post Share on other sites
Covert_Death Posted April 17, 2015 Author Report Share Posted April 17, 2015 Covert_Death.....Awesome dedication towards this topic bro.  I was sooooo pissed when Pioneer had to release a new unit just to update Android Auto.  I bought my 4000NEX during last September just in hopes that Android Auto will be made available as a FW update.  Like everybody else here, I am also ranting about less than 1 year old unit purchase which now does not meet my expectations.  sorry for the delay, it's been a buys week at work. I found the SD card inside the unit but as I guessed it's PW protected and I don't know how to extrapolate the PW from the new unit / old unit to unlock it. I don't even know if this would resolve the issue but at least it would be 100% 4100 SW on a 4000 instead of a partial upgrade like the FW seems to be.  I need to be able to sell one of my units so I hesitate in destroying them any further haha.  Also I have had no luck getting anyone interested on XDA... Quote Link to post Share on other sites
GonzoRocks Posted April 17, 2015 Report Share Posted April 17, 2015 sorry for the delay, it's been a buys week at work. I found the SD card inside the unit but as I guessed it's PW protected and I don't know how to extrapolate the PW from the new unit / old unit to unlock it. I don't even know if this would resolve the issue but at least it would be 100% 4100 SW on a 4000 instead of a partial upgrade like the FW seems to be.  I need to be able to sell one of my units so I hesitate in destroying them any further haha.  Also I have had no luck getting anyone interested on XDA... https://fail0verflow.com/blog/2014/enhancing-the-avic-5000nex.html  This guy was able to obtain the password Quote Link to post Share on other sites
GonzoRocks Posted April 17, 2015 Report Share Posted April 17, 2015 On a different note, why on 4000 to 4100 is PJ150OPN.PRG named 150 and not 140 like on the stock firmware? Quote Link to post Share on other sites
therooster Posted April 19, 2015 Report Share Posted April 19, 2015 I take it there are different passwords on the 4000 series and the 4100 series? Quote Link to post Share on other sites
douger Posted April 20, 2015 Report Share Posted April 20, 2015 Pioneer right now mediocrity in a sea of garbage. The head unit manufacturers are not innovating. Frankly I'm glad for CarPlay and android auto because my radio will receive updates and new functionality over time from apple instead of from pioneer. Â In the 8.3 beta the album art looks better and once again works with third party apps, the phone no longer needs to be unlocked to use CarPlay,(you just tell the phone to trust this head unit and it auto launches after that) the maps now does this thing where if you don't touch it it hides buttons automatically to dedicate more of the screen to the map, Siri has a new button to let me call the person to reply to a text and I have no doubt in the future there will be a button to send audio messages for iMessage conversations. Â When the interface comes from my phone I don't have to care about the pioneer one. I already have an interface from apple. There may not be a payoff. For most new cars, the infotainment is so integrated with the rest of the car both physically and electronically that the market for aftermarket audio may be shrinking. Quote Link to post Share on other sites
