BorisM Posted March 10, 2009 Author Report Share Posted March 10, 2009 Hey Boris, Any chance you have this zip file? I click on the link and it takes you to a russian site that you seem to need to register on. I tried google translate and still couldn't work it out! Thanks Matt Sorry... forgot that it requires registratoin. Fixed... Quote Link to post Share on other sites
dumpystig Posted March 10, 2009 Report Share Posted March 10, 2009 Can anyone direct me to the Pause and Resume buttons that Toxit used in his Simulation mod? Cheers Quote Link to post Share on other sites
ill.die.trying Posted March 10, 2009 Report Share Posted March 10, 2009 Can anyone direct me to the Pause and Resume buttons that Toxit used in his Simulation mod? Cheers i too had a really hard time figuring everything out, what i did is i used his ui files and then edited everything for my mods to reflect. Quote Link to post Share on other sites
dumpystig Posted March 10, 2009 Report Share Posted March 10, 2009 Sorry my bad! I meant the actual button bmp images, realise now I didn't make that clear Quote Link to post Share on other sites
ill.die.trying Posted March 10, 2009 Report Share Posted March 10, 2009 Sorry my bad! I meant the actual button bmp images, realise now I didn't make that clear i don't think he included the buttons, what i suggest is download my zip then just copy the pause/resume, slower, faster buttons. Quote Link to post Share on other sites
dumpystig Posted March 10, 2009 Report Share Posted March 10, 2009 Thanks bud, I'm off back a few pages right now............ Quote Link to post Share on other sites
dumpystig Posted March 10, 2009 Report Share Posted March 10, 2009 i-d-t, Rapid won't let me d/l, says the limit has been reached....... Quote Link to post Share on other sites
ill.die.trying Posted March 10, 2009 Report Share Posted March 10, 2009 i already uploaded it on the ftp site Quote Link to post Share on other sites
ill.die.trying Posted March 10, 2009 Report Share Posted March 10, 2009 http://66.59.250.9:8000/ Quote Link to post Share on other sites
GTIMatt Posted March 11, 2009 Report Share Posted March 11, 2009 Hey Boris, Any chance you have this zip file? I click on the link and it takes you to a russian site that you seem to need to register on. I tried google translate and still couldn't work it out! Thanks Matt Sorry... forgot that it requires registratoin. Fixed... Thanks Boris, Are these the files used in the scripts? When I looked at speedcam.ui I can see the following script for example: The files I downloaded from the link are all called something like Fixed_Camera.ogg speed_limit_010_mph.ogg etc If I need to go in and change the sound called to the ones I downloaded then that's fine but I just wanted to check as this is the first time I have ventured into the audio side so was a little confused. Thanks Matt Quote Link to post Share on other sites
BorisM Posted March 11, 2009 Author Report Share Posted March 11, 2009 Thanks Boris, Are these the files used in the scripts? When I looked at speedcam.ui I can see the following script for example: The files I downloaded from the link are all called something like Fixed_Camera.ogg speed_limit_010_mph.ogg etc If I need to go in and change the sound called to the ones I downloaded then that's fine but I just wanted to check as this is the first time I have ventured into the audio side so was a little confused. Thanks Matt Huh? Just downloaded the file back. Inside ZIP audio files are named EN_20_MPH_2.ogg etc., so they should be all good to go... Did you D/L from Depositfiles or from some other link? Your file names look more like ULTRA-style voice warnings. Mine are based on iGO 2006 scheme... Quote Link to post Share on other sites
GTIMatt Posted March 11, 2009 Report Share Posted March 11, 2009 Huh? Just downloaded the file back. Inside ZIP audio files are named EN_20_MPH_2.ogg etc., so they should be all good to go... Did you D/L from Depositfiles or from some other link? Your file names look more like ULTRA-style voice warnings. Mine are based on iGO 2006 scheme... Sorry, my fault! I downloaded these from somewhere else and for some reason thought I got them from your link. I used your link and of course the files are what's used in the scripts. Sorry. Quote Link to post Share on other sites
BorisM Posted March 11, 2009 Author Report Share Posted March 11, 2009 Huh? Just downloaded the file back. Inside ZIP audio files are named EN_20_MPH_2.ogg etc., so they should be all good to go... Did you D/L from Depositfiles or from some other link? Your file names look more like ULTRA-style voice warnings. Mine are based on iGO 2006 scheme... Sorry, my fault! I downloaded these from somewhere else and for some reason thought I got them from your link. I used your link and of course the files are what's used in the scripts. Sorry. No problem. Have fun with them. Quote Link to post Share on other sites
Paladin Posted March 11, 2009 Report Share Posted March 11, 2009 Since I am in the USA can I just copy the MPH ones? I figured I would save space since I will never use KMH. They won't ever play anyway right? Also where do the AUDIO files go? Is it the APL2\VBT\AUDIO folder? Quote Link to post Share on other sites
BorisM Posted March 11, 2009 Author Report Share Posted March 11, 2009 Since I am in the USA can I just copy the MPH ones? I figured I would save space since I will never use KMH. They won't ever play anyway right? Also where do the AUDIO files go? Is it the APL2\VBT\AUDIO folder? No, APL2\iGO\AUDIO You can use whatever sub-set of files you want, as long as scripts do not call ones you do not have... Quote Link to post Share on other sites
