Jump to content
AVIC411.com
Progress Report
Hey Boris, Any chance you have this zip file? I click on the link and it takes you to a russian site that you seem to need to register on. I tried google translate and still couldn't work it out!
Matt
Sorry... forgot that it requires registratoin. Fixed...
Link to post
Share on other sites
  • Replies 360
  • Created
  • Last Reply
Top Posters In This Topic
Matt
Thanks Boris, Are these the files used in the scripts? When I looked at speedcam.ui I can see the following script for example:
The files I downloaded from the link are all called something like
Fixed_Camera.ogg
speed_limit_010_mph.ogg etc
If I need to go in and change the sound called to the ones I downloaded then that's fine but I just wanted to check as this is the first time I have ventured into the audio side so was a little confused.
Matt
Link to post
Fixed_Camera.ogg
Matt
Huh? Just downloaded the file back. Inside ZIP audio files are named EN_20_MPH_2.ogg etc., so they should be all good to go...
Did you D/L from Depositfiles or from some other link? Your file names look more like ULTRA-style voice warnings. Mine are based on iGO 2006 scheme...
Link to post
Sorry, my fault! I downloaded these from somewhere else and for some reason thought I got them from your link. I used your link and of course the files are what's used in the scripts.
Sorry.
Link to post
Sorry.
No problem. Have fun with them.
Link to post
Since I am in the USA can I just copy the MPH ones? I figured I would save space since I will never use KMH. They won't ever play anyway right? :)
Also where do the AUDIO files go?
Is it the APL2\VBT\AUDIO folder?
No, APL2\iGO\AUDIO
You can use whatever sub-set of files you want, as long as scripts do not call ones you do not have...
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
