Pioneer4x4 Posted May 23, 2010 Report Share Posted May 23, 2010 Also, I have yet so see if anyone mentioned if this worked on an F90BT. I dowloaded AVIC_F900 v322 nowarn.rar and used testmode to replace the 3 existing files with the ones in the "rar" AFTER backing them up! Also if you read peoples signatures a lot put the equipment they have in it, like me, I have a F90BT Quote Link to post Share on other sites
m5james Posted May 31, 2010 Report Share Posted May 31, 2010 Would it be possible if you took that example of a step-by-step writeup and copy and pasted the directions on how to do this in that format? I'm sure myself and future users will take some of the fear out of doing this mod. Also, are the hiccups gone or does it still randomly show the screen...starting up in certain modes beforehand, pausing, etc. like others have mentioned. Quote Link to post Share on other sites
Guest x5james Posted July 1, 2010 Report Share Posted July 1, 2010 Installed FX3.1 and that automatically got rid of the navi nag screen...now to only be able to get rid of the two others. Quote Link to post Share on other sites
sr0x Posted July 9, 2010 Report Share Posted July 9, 2010 Hi guys, I am not a native english speaker so it was not very easy to get all your posts, but when I understand it correct, the Software Hack doesnt work as "stand alone" - u still need to bypass the handbrake wire. Right? I got a F9110BT for VW. I m not sure if the other models use the CanBus the same way (would be nice, if u could explain it to me), but yesterday I installed this "no warning" mod and now I can access the whole menu while driving I did not do the wire bypassing. Am I to stupid to understand, what u wrote? Is this finally working in the newest version, or why do so many ppl have problems with it? The nag scrren is gone and I dont have issues with anything. Thanks for this mod!!! I backed up my complete Flashdrive folder. Is it possible to copy back all files on the unit, or will this crash while copying because some files are "used" while in Testmode? I think i need to do this in order to send my unit to a service. THX 4 your help... bb sr0x Quote Link to post Share on other sites
jeegnesh Posted July 12, 2010 Report Share Posted July 12, 2010 I guess I can't use this for 3.010100? Quote Link to post Share on other sites
Chuck88 Posted July 15, 2010 Report Share Posted July 15, 2010 I guess I can't use this for 3.010100? This hack is used for 3.01xx and up. Mine is 3.0102 and works fine. Just to make sure, backup the 3 files before replacing them with the hack. Quote Link to post Share on other sites
jeegnesh Posted July 16, 2010 Report Share Posted July 16, 2010 I guess I can't use this for 3.010100? This hack is used for 3.01xx and up. Mine is 3.0102 and works fine. Just to make sure, backup the 3 files before replacing them with the hack. Thanks for the confirmation, added the hack works perfectly. Now onto the next one Quote Link to post Share on other sites
hwegener Posted August 4, 2010 Report Share Posted August 4, 2010 I am not a programer, but are you not going about this wrong? The Nag screens shows typically only once everytime the unit is started. This tells me that there must be a "System Variable" some where that gets triggered saying the nag screen was shown and OK'd. Is it not easier to have the system variable set at boot up to say the nag screen was seen and approved? Again, I am not a programmer, but obviously no matter the approach, if a sub-app says it is time to show the nag screen, it would check the settings to see if that was already done, then display or not display it. Quote Link to post Share on other sites
69sixpackbee Posted August 4, 2010 Report Share Posted August 4, 2010 It works no matter what... Quote Link to post Share on other sites
The airman Posted December 14, 2010 Report Share Posted December 14, 2010 Worked perfect for me. Thanks for the hard work. Quote Link to post Share on other sites
casemods Posted December 29, 2010 Report Share Posted December 29, 2010 I don't understand which file to download or where to put it... f700bt here also if anyone knows how to bypass the handbrake, that would be great as well Quote Link to post Share on other sites
VBLUE42 Posted December 29, 2010 Report Share Posted December 29, 2010 For the last time the bypass instructions are well documented. Info on hacks and mods and how to install files are also documented. Quote Link to post Share on other sites
hedehede81 Posted December 29, 2010 Report Share Posted December 29, 2010 is there any solution to map not following the arrow issue? you know, in morning when you first start your car, it takes time to lock on to satellites and the map stays in poi mode with a crosshair as if you touched the screen. I have to press Map button to make it follow the car. otherwise it just stays there. Quote Link to post Share on other sites
carver Posted December 29, 2010 Author Report Share Posted December 29, 2010 upd 29.12.2010 update for 3.020200 version, UC or EW with a new phone call - AVIC always switch to MAP screen. in first post i attach modified \My Flash Disk\APL\Tel.exe, after his replacement, when an incoming call on AVIC remains an old window. This is a test version, since I do not use the phone with AVIC. please leave feedback about problems. thanks Quote Link to post Share on other sites
hedehede81 Posted December 30, 2010 Report Share Posted December 30, 2010 upd 29.12.2010 update for 3.020200 version, UC or EW with a new phone call - AVIC always switch to MAP screen. in first post i attach modified \My Flash Disk\APL\Tel.exe, after his replacement, when an incoming call on AVIC remains an old window. This is a test version, since I do not use the phone with AVIC. please leave feedback about problems. thanks hey carver, any chance you can take a look on "map not following the car at first start issue"? I gave the details on my post right above yours. Thanks a lot for your efforts. Quote Link to post Share on other sites
Join the conversation
