humblehyper Posted April 6, 2010 Report Share Posted April 6, 2010 Is it still necessary to hook up the parking brake wire even if you're doing a bypass? Thanks. Quote Link to post Share on other sites
CaptainInsaneO Posted April 6, 2010 Report Share Posted April 6, 2010 The parking break wire gets grounded to the vehicle. Quote Link to post Share on other sites
humblehyper Posted April 6, 2010 Report Share Posted April 6, 2010 The parking break wire gets grounded to the vehicle. Â So no need to tap the parking break wire to the parking brake power because I'm grounding it anyway right? Quote Link to post Share on other sites
CamelTowing Posted April 7, 2010 Report Share Posted April 7, 2010 Green parking brake wire goes to ground (black) Quote Link to post Share on other sites
humblehyper Posted April 7, 2010 Report Share Posted April 7, 2010 Cool thanks! One more question, since I'm bypassing the amp and sub temporarily for my setup, I tapped the new set of speaker wires directly to the pioneer harness. The other end of the speaker wire goes to the harness on the rockford amp right? Just tap into it? Quote Link to post Share on other sites
rrolff Posted April 22, 2010 Report Share Posted April 22, 2010 I'll just throw in my $.02 on the mod. There is a picture of the side of the connector (the wire you are moving). It shows a small square 'cutout' that was pushed in. After pushing this in, a staple at the base works great to lossen the wire. That was the key for me - then move the wire, and follow the instructions... Quote Link to post Share on other sites
sthompson11 Posted April 23, 2010 Report Share Posted April 23, 2010 ... and for those of you like me that just couldn't get the right leverage with a staple without it bending, try a safety pin with the pin side bent out. It's small enough to insert into the front of the harness & strong enough to push the wire catch down. The rest of the safety pin can be used as a handle to apply leverage. After spending way to much time trying recommendations of this forum, the safety pin made easy work of it for me. Good Luck. Quote Link to post Share on other sites
nosaJ-11C7 Posted April 27, 2010 Report Share Posted April 27, 2010 Well, I was going to try to remove the mute wire/pin and move it to each of the empty pin-out locations, and ground it with the parking brake. I'm sure it is probably something this simple--and just a process of elimination.  However!!! I can't figure out how to get the stupid pin to come out? The plug is not like the old series, or the F/X where you can just lift up a little clip and slide the pin out. This one is much smaller, and I can't figure it out.  If someone can tell me how to do it, I'll test each of the 7 empy slots and see if any of them give us the result we're looking for.  -B-  Thanks for your effort on figuring this out. How on earth did you come up with this idea of tying random unused pins to ground? Did this used to be an official procedure from Pioneer on older units, or do we have an "insider" at Pioneer who relayed this information?  ...me thinks to myself, hmm, I'd really like to reassign the voice control button on my X920BT to immediately play Rick Astley's "Never Gonna Give You Up". I know! I'll just start grounding unused pins on the back of the unit until I find the one that enables this feature! (it turns out you just move the mute wire down one position ) Quote Link to post Share on other sites
hanokgeorge Posted April 28, 2010 Report Share Posted April 28, 2010 Hello All: Thank you for all the help. This forum has be absolutely great. Got the bypass to work flawlessly WITHOUT having to cut anything. A paperclip and staple is all that is necessary. I broke off a staple in there however, and almost pooped my pants . I shook it for a while and got it out though. Somehow it got stuck behind the pin. Thank again, cheers! Quote Link to post Share on other sites
ELFJ Posted May 6, 2010 Report Share Posted May 6, 2010 hey guys check in youtube avic z110bt bypass it's so simple good luck Quote Link to post Share on other sites
VBLUE42 Posted May 6, 2010 Report Share Posted May 6, 2010 And why do we need to check youtube when we posted the bypass first, over a year ago? Quote Link to post Share on other sites
wahben70 Posted May 27, 2010 Report Share Posted May 27, 2010 Hey guys I need help I moved the mute wire one position and ground it with the PB and ground It works fine until I hit the 20mph mark, than I get this message " it is strictly prohibited to view the video while driving" how do I solve this problem?? Quote Link to post Share on other sites
rtonerii Posted May 27, 2010 Report Share Posted May 27, 2010 Hey guys I need helpI moved the mute wire one position and ground it with the PB and ground It works fine until I hit the 20mph mark, than I get this message " it is strictly prohibited to view the video while driving" how do I solve this problem?? Â Make sure you have a good ground! I had the same issue and I had to re-do the wires a few times to get it right. Quote Link to post Share on other sites
wahben70 Posted May 27, 2010 Report Share Posted May 27, 2010 are u sure? because if its not grounded you want have picture at all but I guess I have to try different ground, right? Quote Link to post Share on other sites
VBLUE42 Posted May 27, 2010 Report Share Posted May 27, 2010 If its not working its not done correctly or the connections are faulty. Quote Link to post Share on other sites
