abb1 Posted October 12, 2009 Report Share Posted October 12, 2009 EXCELLENT MOD!! The only thing that I changed to make it perfect for me, was to incorporate a few of DPHursts schemes, and I made the icons on top a little smaller as I have always found that they were a bit too big, that is just my opinion as I am sure that everyone else likes it the way it is. I really dont think that this MOD can be improved other than that. NICE WORK!! Quote Link to post Share on other sites
maleon Posted October 12, 2009 Report Share Posted October 12, 2009 could someone tell me how to make the voices of radars in Spanish???? thanks Quote Link to post Share on other sites
69sixpackbee Posted October 12, 2009 Report Share Posted October 12, 2009 could someone tell me how to make the voices of radars in Spanish???? thanks The audio files are pre-recorded .ogg files. Someone would have to record their own and replace them or try searching for IGO sound bytes in Spanish. Bud Quote Link to post Share on other sites
pkbristol Posted October 12, 2009 Report Share Posted October 12, 2009 Ok, when i first installed the final mod, tmc version, i had a female speed camera voice, and when i adjusted the volume slider for the female voice i'd get a sample of the volume, however, now i have the male voice again hen i go past a speed camera and when i adjust the volume slider for the speed camera i don't get any sample. I'll end up selling my head unit at this rate. Paul. Quote Link to post Share on other sites
69sixpackbee Posted October 12, 2009 Report Share Posted October 12, 2009 could someone tell me how to make the voices of radars in Spanish???? thanks Here is is: http://www.igo8mods.com/voices/Audio_ES_Spanish.zip Good luck (Buena suerte) Quote Link to post Share on other sites
jojool Posted October 12, 2009 Report Share Posted October 12, 2009 Hi IDT, thanks a lot for your final version. You seem to be a perfectionist. 700 Km with no problems, everything workes fine. Sent you some money. so long Jojool Quote Link to post Share on other sites
maleon Posted October 12, 2009 Report Share Posted October 12, 2009 could someone tell me how to make the voices of radars in Spanish???? thanks Here is is: http://www.igo8mods.com/voices/Audio_ES_Spanish.zip Good luck (Buena suerte) thanks, but I work I have iGO 8 Quote Link to post Share on other sites
69sixpackbee Posted October 12, 2009 Report Share Posted October 12, 2009 The sound files are the same. Just replace the ones you have with the new ones. Make sure you rename them exactly as the old ones and it will work just fine. Quote Link to post Share on other sites
maleon Posted October 12, 2009 Report Share Posted October 12, 2009 The sound files are the same. Just replace the ones you have with the new ones. Make sure you rename them exactly as the old ones and it will work just fine. mean the numbers 0,1,2 ... if that changes now supuese Quote Link to post Share on other sites
ill.die.trying Posted October 12, 2009 Author Report Share Posted October 12, 2009 Hi IDT, thanks a lot for your final version. You seem to be a perfectionist. 700 Km with no problems, everything workes fine. Sent you some money. so long Jojool thanks for the donation bro Quote Link to post Share on other sites
lotust Posted October 12, 2009 Report Share Posted October 12, 2009 sweet update IDT thanks again. Quote Link to post Share on other sites
ill.die.trying Posted October 12, 2009 Author Report Share Posted October 12, 2009 sweet update IDT thanks again. no prob Quote Link to post Share on other sites
ill.die.trying Posted October 12, 2009 Author Report Share Posted October 12, 2009 Ok, when i first installed the final mod, tmc version, i had a female speed camera voice, and when i adjusted the volume slider for the female voice i'd get a sample of the volume, however, now i have the male voice again hen i go past a speed camera and when i adjust the volume slider for the speed camera i don't get any sample. I'll end up selling my head unit at this rate. Paul. could you try adding this on the [debug] part of the sys.txt and see if it helps on the out of memory problem cache=2048 Quote Link to post Share on other sites
whoopidoo2 Posted October 13, 2009 Report Share Posted October 13, 2009 One more question in regards to this mod. What is the purpose of being able to set the day and time from the red-negative button on the map screen? Has every day of the week, and the wrench for setting specific times. Is that to turn speedcams on/off based on the time or day or.....? Sorry I just noticed this one today. Quote Link to post Share on other sites
ill.die.trying Posted October 13, 2009 Author Report Share Posted October 13, 2009 One more question in regards to this mod. What is the purpose of being able to set the day and time from the red-negative button on the map screen? Has every day of the week, and the wrench for setting specific times. Is that to turn speedcams on/off based on the time or day or.....?Sorry I just noticed this one today. i think you're referring to the road blocking feature and not speedcam, that is to block a road depending on your preferences (construction, maybe no left turn on a specific time etc) so that when you have a route it would not use that road as a part of the route, Quote Link to post Share on other sites
