pyrofallout Posted December 12, 2009 Report Share Posted December 12, 2009 I keep getting an error cannot find gfx/day/cs.bmp then igo crashes. Quote Link to post Share on other sites
ovalball Posted December 12, 2009 Report Share Posted December 12, 2009 I keep getting an error cannot find gfx/day/cs.bmp then igo crashes. Check that you have installed the GFX folder in the correct place. flashdrive/apl2/igo/gfx.Also check that the scheme you are trying to run in the day folder :)Also delete everything in user/userdata/igo/save Also did you install the igo_8 foder into your data.zip...... Quote Link to post Share on other sites
pyrofallout Posted December 12, 2009 Report Share Posted December 12, 2009 I keep getting an error cannot find gfx/day/cs.bmp then igo crashes. Check that you have installed the GFX folder in the correct place. flashdrive/apl2/igo/gfx.Also check that the scheme you are trying to run in the day folder :)Also delete everything in user/userdata/igo/save Also did you install the igo_8 foder into your data.zip...... I figured it out, I needed to change the scheme to something other than the default pioneer schemes, after that everything loaded up perfectly. Thanks for the help! Quote Link to post Share on other sites
dpdurst Posted December 15, 2009 Author Report Share Posted December 15, 2009 Finished up the Dec 2 update with my mods. 1. For some reason I can't get the Route Progress to work correctly. Its there but not sure if its really broke or its me. 2. New route tools button on top left, pressing this causes the original route buttons I have to show up to use, after 5 seconds they disappear again. 3. Fixed the CarpositionCursor that was centered on the screen Will post it shortly. Quote Link to post Share on other sites
pyrofallout Posted December 15, 2009 Report Share Posted December 15, 2009 I gots a question though...can anyone tell me what the icons in the middle-left of the screen that pop up are? Here is a pic of one below, I also get like a "no left turn" or "no right turn" icon randomly, but i know they don't apply to the streets i am on, because they don't necessarily come up at any intersection or turn off and when it does you can def tell it doesn't apply to that intersection (ie: you CAN turn left or right). Also is trip computer supposed to store data between power cycles? When I turn my vehicle off and back on, it seems trip data starts over, but it seems it would be possible to make it preserve the data as speed logs are preserved between power cycles. does anyone know? or maybe mine is messed up and its supposed to? thanks! Quote Link to post Share on other sites
ovalball Posted December 15, 2009 Report Share Posted December 15, 2009 I gots a question though...can anyone tell me what the icons in the middle-left of the screen that pop up are? Here is a pic of one below, I also get like a "no left turn" or "no right turn" icon randomly, but i know they don't apply to the streets i am on, because they don't necessarily come up at any intersection or turn off and when it does you can def tell it doesn't apply to that intersection (ie: you CAN turn left or right). Also is trip computer supposed to store data between power cycles? When I turn my vehicle off and back on, it seems trip data starts over, but it seems it would be possible to make it preserve the data as speed logs are preserved between power cycles. does anyone know? or maybe mine is messed up and its supposed to? thanks! I'm sure the arrows etc are turn restrictions and i think they are provided by the map provider ie Teleatlas or Navteq.Try turning them off in visual settings to see if they go away.. Quote Link to post Share on other sites
BorisM Posted December 15, 2009 Report Share Posted December 15, 2009 I'm sure the arrows etc are turn restrictions and i think they are provided by the map provider ie Teleatlas or Navteq.Try turning them off in visual settings to see if they go away.. They are turn restrictions, and map data is (usually) correct. This particular build of iGO, however, displays them pretty much randomly (there must be some system to it, but we haven't discovered it so far). Quote Link to post Share on other sites
diaftia Posted December 16, 2009 Report Share Posted December 16, 2009 I'm sure the arrows etc are turn restrictions and i think they are provided by the map provider ie Teleatlas or Navteq.Try turning them off in visual settings to see if they go away.. They are turn restrictions, and map data is (usually) correct. This particular build of iGO, however, displays them pretty much randomly (there must be some system to it, but we haven't discovered it so far). I added an option to turn it off on mine and defaulted it to that. You might want to do the same if you haven't. Quote Link to post Share on other sites
speed Posted February 3, 2010 Report Share Posted February 3, 2010 Just wondering what the white circle is for, next to the mph. Is this where the speed limit will display. If so, it does not show up, maybe because I'm using Navteq maps. Thanks Quote Link to post Share on other sites
dpdurst Posted February 3, 2010 Author Report Share Posted February 3, 2010 Just wondering what the white circle is for, next to the mph. Is this where the speed limit will display. If so, it does not show up, maybe because I'm using Navteq maps. Thanks Yep its for the speed limit and if not showing up its due to the maps. Quote Link to post Share on other sites
dpdurst Posted March 15, 2010 Author Report Share Posted March 15, 2010 Updated the data.zip with the Dec 02, 2009 changes from Andr2000. This pretty much is the end of the mods I am doing for the unit. Enjoy. Quote Link to post Share on other sites
pkonar1 Posted March 15, 2010 Report Share Posted March 15, 2010 Hi I apologize for my language .... I'm from Polish. Will you help me change the cursor (arrow) to cursor (car VOLVO S80 (BLACK)) THANK YOU FOR HELP Quote Link to post Share on other sites
abb1 Posted March 15, 2010 Report Share Posted March 15, 2010 HiI apologize for my language .... I'm from Polish. Will you help me change the cursor (arrow) to cursor (car VOLVO S80 (BLACK)) THANK YOU FOR HELP In IDT's mod, on the first page, there are exact instructions. Quote Link to post Share on other sites
pkonar1 Posted March 15, 2010 Report Share Posted March 15, 2010 THANK YOU FOR HELP In IDT's mod, on the first page, there are exact instructions. You can insert a link? thank you Quote Link to post Share on other sites
ovalball Posted March 15, 2010 Report Share Posted March 15, 2010 THANK YOU FOR HELP In IDT's mod, on the first page, there are exact instructions. You can insert a link? thank you -currently this has the subaru impreza rally car as the default 3D car to change the 3D arrow to a car model download the 3DCars.rar file on the download link provided and extract it and you have to edit the sys.txt change the current values of this Code: Select all 3dcarsizemin=2500 3dcarsizemax=5000 3dcarsizemul=15000 to this Code: Select all 3dcarsizemin=5000 3dcarsizemax=8000 3dcarsizemul=30000 and add this part to the [3D] section Code: Select all car_day=hot_rod_red.mdl car_night=hot_rod_red.mdl ghost_day=hot_rod_red.mdl ghost_night=hot_rod_red.mdl you now have to transfer the desired carmodel and tex file to the gfx folder in the data.zip and change the names of the above code to your selected car model name, i haven't tested every car model out as i already like the hot_rod car, but it's just a trial and error thing Quote Link to post Share on other sites
Join the conversation
