Kirby692 Posted March 4, 2010 Report Share Posted March 4, 2010 So, either one of two things, Either it is just on your machine (which I doubt), or it is because me and IDT are Canadians and we use KM/M instead of MPH/FT, which may not show the units Is there somewhere else that units get changed besides in the UI on the Regional settings page? I tried all 3 settings there (KM/M, Mi/Y, and Mi/Ft) and each time I got units displayed (M, Y, or ft). Let me ask this, a particular scheme wouldnt affect that would it? I really dont know what else to look for. Quote Link to post Share on other sites
abb1 Posted March 4, 2010 Report Share Posted March 4, 2010 So, either one of two things, Either it is just on your machine (which I doubt), or it is because me and IDT are Canadians and we use KM/M instead of MPH/FT, which may not show the units Is there somewhere else that units get changed besides in the UI on the Regional settings page? I tried all 3 settings there (KM/M, Mi/Y, and Mi/Ft) and each time I got units displayed (M, Y, or ft). Let me ask this, a particular scheme wouldnt affect that would it? I really dont know what else to look for. Wow, that is weird, you can try to change the scheme, but I dont think it should make any difference, but that DOES seem to be the only difference Quote Link to post Share on other sites
ill.die.trying Posted March 4, 2010 Author Report Share Posted March 4, 2010 So, either one of two things, Either it is just on your machine (which I doubt), or it is because me and IDT are Canadians and we use KM/M instead of MPH/FT, which may not show the units Is there somewhere else that units get changed besides in the UI on the Regional settings page? I tried all 3 settings there (KM/M, Mi/Y, and Mi/Ft) and each time I got units displayed (M, Y, or ft). Let me ask this, a particular scheme wouldnt affect that would it? I really dont know what else to look for. Wow, that is weird, you can try to change the scheme, but I dont think it should make any difference, but that DOES seem to be the only difference i think it has something to do with the textmodel being used, when not navigating it's using navigation.current_altitude.number_text and when navigating it uses gps.elevation as you can see, the first one has .number_text, not sure if you could add that at the end of gps.elevation Quote Link to post Share on other sites
Kirby692 Posted March 4, 2010 Report Share Posted March 4, 2010 i think it has something to do with the textmodel being used, when not navigating it's using navigation.current_altitude.number_text and when navigating it uses gps.elevation as you can see, the first one has .number_text, not sure if you could add that at the end of gps.elevation Adding .number_text to the end of gps.elevation makes it disappear completely, so I guess that means it doesnt like it. I guess for now I will just reduce the size, and try and position it inside the sign borders until a different solution is found (if one is). To rule out one other thing, I am using the EZRIDER from this post: viewtopic.php?f=34&t=27989 (ezrider_alt_mod.zip). Thats the correct one right? Quote Link to post Share on other sites
figueroaw Posted March 5, 2010 Report Share Posted March 5, 2010 So, either one of two things, Either it is just on your machine (which I doubt), or it is because me and IDT are Canadians and we use KM/M instead of MPH/FT, which may not show the units. Therefore, the fix would be in the unit switch and NOT in the elevation reading I live in the US and i have never see that "ft" on mine. So a suggestion would be deleting the igo folder and start fresh again. Just do one mod at a time! (Do a Backup just in case) Quote Link to post Share on other sites
Kirby692 Posted March 5, 2010 Report Share Posted March 5, 2010 I did some more testing. Went back to a clean data.zip and did not change the elevation to gps.elevation. In KM/M mode, it displayed in meters, without an "m". The same held true for Mi/Yards, it did not show a "y". With Miles/Feet selected, it would display the number of feet without "ft" up to around 820, at which point it would switch over to 0.2 (miles) with no units. Then I tried it with the gps.elevation in the file, and it would display feet digits just fine, never switching to 0.2 miles or whatever, but "ft" was always there. So I am thinking its something to do with the altered ezrider.zip maybe? As that was altered to display feet for elevation always (or at least up to several thousand feet). I will note, that when the system was showing 0.2 miles, if you view the GPS status page, the elevation there was displayed in feet. Quote Link to post Share on other sites
Kirby692 Posted March 5, 2010 Report Share Posted March 5, 2010 I live in the US and i have never see that "ft" on mine. So a suggestion would be deleting the igo folder and start fresh again. Just do one mod at a time! (Do a Backup just in case) See my post above this one. If you didnt change your navigatemap.ui file to have the gps.elevation field instead of navigation.current_altitude.number_text then you wont have "ft". My guess is that you are either seeing 0.2 (or above) miles, or live at an elevation below 820 feet or so which will correctly show the number of feet, without "ft". I'm trying to get it to show something like "3240" (if I should drive to that elevation). Quote Link to post Share on other sites
N-S-E-W Posted March 5, 2010 Report Share Posted March 5, 2010 With the standard hacked ezrider using gps.elevation as the text model, the elevation will display in feet up to 5279 feet. It then switches to 1 mile XXX ft. Any text model using altitude the unit will display feet up to 879 then it will switch to tenths of miles, ie 0.2, and so forth. Quote Link to post Share on other sites
figueroaw Posted March 5, 2010 Report Share Posted March 5, 2010 IDT or anyone, On sys.txt, I have it to read map from Sd card. Everything else has to be on the HU for it to work. How Can I have igo read the entire content from sd? (POI, Building, Dem, Scheme, etcc) Should I stated on the sys.txt? something like: [POI] 1=",POI, \Storage Card\iGO,\My Flash Disk\APL2\iGo," Quote Link to post Share on other sites
ill.die.trying Posted March 5, 2010 Author Report Share Posted March 5, 2010 IDT or anyone, On sys.txt, I have it to read map from Sd card. Everything else has to be on the HU for it to work. How Can I have igo read the entire content from sd? (POI, Building, Dem, Scheme, etcc) Should I stated on the sys.txt? something like: [POI] 1=",POI, \Storage Card\iGO,\My Flash Disk\APL2\iGo," please see quote from BORISM Another thing, mostly for fun... If you put content="Storage Card\IGO\Content" in the [folders] section of sys.txt and copy content folder form th? flash disk, you can run iGO with data off of the storage card... rather handy if you want to experiment with different maps, schemes etc. Quote Link to post Share on other sites
Kirby692 Posted March 5, 2010 Report Share Posted March 5, 2010 With the standard hacked ezrider using gps.elevation as the text model, the elevation will display in feet up to 5279 feet. It then switches to 1 mile XXX ft. Any text model using altitude the unit will display feet up to 879 then it will switch to tenths of miles, ie 0.2, and so forth. So then there is no way to get what I want it seems. That sucks. I just want feet to show between 880 - 5279, without the text "ft". Quote Link to post Share on other sites
ill.die.trying Posted March 5, 2010 Author Report Share Posted March 5, 2010 With the standard hacked ezrider using gps.elevation as the text model, the elevation will display in feet up to 5279 feet. It then switches to 1 mile XXX ft. Any text model using altitude the unit will display feet up to 879 then it will switch to tenths of miles, ie 0.2, and so forth. So then there is no way to get what I want it seems. That sucks. I just want feet to show between 880 - 5279, without the text "ft". what you could do is make the elevation background wider or make the text smaller, Quote Link to post Share on other sites
abb1 Posted March 5, 2010 Report Share Posted March 5, 2010 what you could do is make the elevation background wider or make the text smaller, Yup, just change the size of the elevation sign from '60 x 40' to '80 x 53' Quote Link to post Share on other sites
figueroaw Posted March 5, 2010 Report Share Posted March 5, 2010 . Quote Link to post Share on other sites
Segler1963 Posted March 6, 2010 Report Share Posted March 6, 2010 Which lines are these, maybe that is the solution for the forum members with trip computer not working Thanks Jörg Quote Link to post Share on other sites
Join the conversation
