SubyJeff Posted December 25, 2012 Report Share Posted December 25, 2012 New to AppRadio - have an Iphone 4 32GB w/ IOS 6.01 and planning on doing the tethered jailbreak later this evening. To get the AppRadio Extensions working all I need to do is download this and Backgrounder via Cydia? Also - have the TR7 + relay bypass in place - I'm assuming this is a prerequisite for AppRadio extensions? Thanks. step 1 it says: Instructions: Uninstall backgrounder if it is already installed (check Cydia). It is not compatible. Link to post Share on other sites
tommyb9999 Posted December 27, 2012 Report Share Posted December 27, 2012 step 1 it says: Instructions: Uninstall backgrounder if it is already installed (check Cydia). It is not compatible. thanks - I must have misread this - Link to post Share on other sites
dubulup Posted December 29, 2012 Report Share Posted December 29, 2012 is a jail broken iPhone and app radio 2 less buggy? random things seem to set off my head unit...also is there a way to use iOS 6 turn by turn navigation via "maps"? Or does the phone have to be jailbroken? All I want is iPod access (via iTunes match would be awesome), Pandora, and turn by turn nav using iOS 6...as I've installed my radio in a 40 year old vehicle. Link to post Share on other sites
sylver Posted December 29, 2012 Report Share Posted December 29, 2012 Today is new version on Cydia Link to post Share on other sites
bennetski Posted December 30, 2012 Report Share Posted December 30, 2012 Only a bug fix then. nothing exciting Will Appextensions ever work with ios 6 ??? Link to post Share on other sites
Boullie Posted January 1, 2013 Report Share Posted January 1, 2013 Is there an option somewhere to disable the screen of the iPhone with unsupported apps? I have the phone in plain view, and it's quite annoying to have the screens display exactly the same Except for that, the app is working perfectly on my 8400bt! Link to post Share on other sites
mxgaza33 Posted January 1, 2013 Report Share Posted January 1, 2013 I've got the same issue (also on the 8400bt), I tried a way around it using a 'dim to black screen' tweak that turns off the screen instead of autolocking the iphone. Problem is that when it is connected with the AppRadio app running, autolock seems to be disabled so it never dims to black. I'm still looking for a solution if anyone has any ideas! Link to post Share on other sites
dannn Posted January 2, 2013 Report Share Posted January 2, 2013 also keen to find out away around that! Link to post Share on other sites
mikedecaro Posted January 2, 2013 Author Report Share Posted January 2, 2013 Will Appextensions ever work with ios 6 ??? I'm porting over all of the features, minus touch for unsupported apps. You will be able to see them but not control them. No time frame yet but I am working on it. Is there an option somewhere to disable the screen of the iPhone with unsupported apps? I have the phone in plain view, and it's quite annoying to have the screens display exactly the same I tried a bunch of different ways to turn off the screen while using the radio but couldn't get it to work well. The closest I got was dimming the phone while mirroring. Link to post Share on other sites
dannn Posted January 2, 2013 Report Share Posted January 2, 2013 ^^^ looking foward to the new app radio extensions realease keep up the good work! Link to post Share on other sites
mxgaza33 Posted January 2, 2013 Report Share Posted January 2, 2013 I tried a bunch of different ways to turn off the screen while using the radio but couldn't get it to work well. The closest I got was dimming the phone while mirroring. How did you manage that? Was it a seperate tweak? Link to post Share on other sites
mikedecaro Posted January 2, 2013 Author Report Share Posted January 2, 2013 How did you manage that? Was it a seperate tweak? I temporarily added it to AppEx before I released 2.0. Took it out for the final release because it had a minor issue with undimming. Link to post Share on other sites
CarToyz Posted January 2, 2013 Report Share Posted January 2, 2013 I have an AppRadio to an iPhone five. When use HDMI input on AppRadio in the new lightning to HDMI adapter everything displays on the AppRadio And you get audio. But none of the controls work. Link to post Share on other sites
jakeschu7 Posted January 3, 2013 Report Share Posted January 3, 2013 Mike, thanks for all the hard work I really appreciate it. I am waiting on that IOS 6 update! Can't wait thanks again! Link to post Share on other sites
squidboy Posted January 5, 2013 Report Share Posted January 5, 2013 I'm porting over all of the features, minus touch for unsupported apps. You will be able to see them but not control them. No time frame yet but I am working on it. Hey Mike - I'm new to this forum, but i recently purchased a AR2 mostly because i was amazed at your work with the AR extensions. Great work dude. Keep on rolling! I thought i read somewhere that you were using the veency mouse code (i.e. jp.ashikase.mousesupport ? ) as the basis for providing mouse/touch input from external means for your work in IOS 5.1.1. What are the issues with IOS6? i also vaguely recall you mentioning all the backgrounding support going away in IOS 6 Does that mean the processing of system-wide touch/input events are completely different now? yuck... Anyways, i ask this because i'm hoping you make your AR extension source code available soon (i keep checking your github site weekly to see if its true...haha) so that others can weigh in on the problem and possibly provide some secondary set of eyes to help you with some alternatives for this amazing work you are doing. You provided the foundation dude. You are the man! All we would be doing is adding only incremental help to expedite this thing that you started, but that we ALL want! Later Link to post Share on other sites
