steveat484 Posted May 3, 2013 Report Share Posted May 3, 2013 Does anyone could help me , about my last post just up here Quote Link to post Share on other sites
RonS Posted May 3, 2013 Report Share Posted May 3, 2013 Does anyone could help me , about my last post just up here If TestMode doesn't load, you own a brick. Send it back for service, expect to pay about $150-$200. YOu didn't say what went wrong. Please tell so others can avoid that mistake. Quote Link to post Share on other sites
steveat484 Posted May 3, 2013 Report Share Posted May 3, 2013 Hello RONS Well you mean tha the test mode should load by it self ? if yes it's dead... i stop too hearly the update and it turn off.... steven before it cost me €€€€ if someone as an idea .... sincerly steven Quote Link to post Share on other sites
RonS Posted May 3, 2013 Report Share Posted May 3, 2013 I didn't want to get into Testmode details (because they are covered elseware), but just to be clear and simple: Dowload the supertestmode file If necessary, extract testmode.key from the compressed archive Put testmode.key in the root of your FAT32 formated SD Insert SD If nothing happens, try cycling your ignition key to reboot the AVIC If nothing happens, you are dead - no one here can help you. Quote Link to post Share on other sites
Thumper88 Posted May 4, 2013 Report Share Posted May 4, 2013 Pionara, thanks for this supereasymethod, worked great on my Z120 Quote Link to post Share on other sites
robiaman Posted May 4, 2013 Report Share Posted May 4, 2013 I have loaded the new maps 2012 as per fist post, everything loaded fine however once I took it out for a test run I noticed that my deck , z130bt, would map the road correctly but not give voice direction. instead it told me insufficient data for this area... I read other having the same issue but no answer to the problem. If you could help I would be grateful and to make clear I have read all post thus far. If I missed a solution your direction would be great. thanks all and great site. by the way I used the auto method for the update as per this thread. Quote Link to post Share on other sites
RonS Posted May 4, 2013 Report Share Posted May 4, 2013 I have loaded the new maps 2012 as per fist post, everything loaded fine however once I took it out for a test run I noticed that my deck , z130bt, would map the road correctly but not give voice direction. instead it told me insufficient data for this area... I read other having the same issue but no answer to the problem. If you could help I would be grateful and to make clear I have read all post thus far. If I missed a solution your direction would be great. thanks all and great site. by the way I used the auto method for the update as per this thread. First, I'd do a factory reset. One way is to disconnect your car battery for 30 seconds. Then next time you boot-up the unit, it will prompt for some things. Make sure the voice/lanuage you select is TTS (like US English Samantha TTS). It is in the Regional Settings. Quote Link to post Share on other sites
steveat484 Posted May 4, 2013 Report Share Posted May 4, 2013 I didn't want to get into Testmode details (because they are covered elseware), but just to be clear and simple: Dowload the supertestmode file If necessary, extract testmode.key from the compressed archive Put testmode.key in the root of your FAT32 formated SD Insert SD If nothing happens, try cycling your ignition key to reboot the AVIC If nothing happens, you are dead - no one here can help you. TX ROMS what's the ' cycling your ignition key to reboot the AVIC'? Quote Link to post Share on other sites
RonS Posted May 4, 2013 Report Share Posted May 4, 2013 TX ROMS what's the ' cycling your ignition key to reboot the AVIC'? It means, turn it OFF and ON. That should re-boot the unit. Quote Link to post Share on other sites
steveat484 Posted May 6, 2013 Report Share Posted May 6, 2013 It means, turn it OFF and ON. That should re-boot the unit. Hi Well , it 's unplug since fewday , i took radio home . so i test on the 12vDC i plug lead on 1 jack and the 2 positive in same jack (red and Yellow) i think when i switch on nothing happened , do i have a button to press ? (on F930bt) Quote Link to post Share on other sites
Coldheat06 Posted May 12, 2013 Report Share Posted May 12, 2013 Upgrade worked like a charm!! Thanks guys. Just have one dumb question...... Now I can not get my map to stay in the North postion when I'm driving..... has anyone figured out how to do that yet Quote Link to post Share on other sites
Paul1965 Posted May 12, 2013 Report Share Posted May 12, 2013 Upgrade worked like a charm!! Thanks guys. Just have one dumb question...... Now I can not get my map to stay in the North postion when I'm driving..... has anyone figured out how to do that yet I thought you just have to touch the white and red direction indicator to switch to always North, but I just tried and it doesn't change. Quote Link to post Share on other sites
robiaman Posted May 12, 2013 Report Share Posted May 12, 2013 Thanks Ron for the reply...."do to limited data guidance can not be provided in your area" is still proving to be a problem, ive tried diconecting the battery over night but it did not reset the avic z130bt like a wrote in a previous post the map shows up with the route highlited but there are no diretions....no arrows with voice. Thanks for your support. Quote Link to post Share on other sites
RonS Posted May 12, 2013 Report Share Posted May 12, 2013 .... ive tried diconecting the battery over night but it did not reset the avic z130btt. Are you saying that disconnecting the battery did not reset the unit??? Or that the reset didn't fix your problem??? By reset, I mean that it will go through the initial setup prompts - like language. Just one other thing to be clear. Are you in the US/Can and running the US/Ca version of the CNSD-310FM? You might of installed the one for the wrong region. That would explain the lack of map detail. I just remembered that on my boat's GPS (where you have to buy detailed maps for your area) there is a world-wide coarse detail map built-in to the unit. It's useless for navigation but it will show you roughly where you are in the world. Quote Link to post Share on other sites
robiaman Posted May 12, 2013 Report Share Posted May 12, 2013 I disconected the battery and the unit did not reset, it kept all values and setting this after leaving the battery disconnected over night Quote Link to post Share on other sites
Join the conversation
