WherezMyBallz Posted April 22, 2008 Report Share Posted April 22, 2008 Uhh...this isn't really related to the bypass, is it... Is your VSS wire connected properly? If so, try resetting all the gyro functions and letting it learn again. Sorry about that....Yea,the wires properly connected using a crimp nut and fully crimped...I'll try resetting the gyros...It's already in 3D Hybrid mode.. Quote Link to post Share on other sites
GoombaJebboMT Posted April 22, 2008 Report Share Posted April 22, 2008 Ok I hit a snag. Whenever I insert the disc then hit map it says something to the effect that the update disc inserted is an older version. Please try with new version. But after I took the disc out and drove around it seemed as though the bypass would work fine....for a few hours...then it would go right back to having that disclaimer pop up, and would prevent me from watching while in motion. I then have to RE-install the bypass software and it starts working again, but then the same thing happens. What am I doing wrong? Quote Link to post Share on other sites
WherezMyBallz Posted April 23, 2008 Report Share Posted April 23, 2008 Ok I hit a snag. Whenever I insert the disc then hit map it says something to the effect that the update disc inserted is an older version. Please try with new version. But after I took the disc out and drove around it seemed as though the bypass would work fine....for a few hours...then it would go right back to having that disclaimer pop up, and would prevent me from watching while in motion. I then have to RE-install the bypass software and it starts working again, but then the same thing happens. What am I doing wrong? After installing the software,did you reset your unit?If no,try that....If that doesn't work,try checking your 2-wire bypass to see if it's properly grounded... Quote Link to post Share on other sites
disco-hog Posted April 23, 2008 Report Share Posted April 23, 2008 I am having a shop install my Z2 in my 08 Honda Element next week & from reading the previous posts it looks like I just need to ground the 2 wires per the photos. Then install the file I downloaded to a cd then press the reset button. The shop is telling me they have tried this before & the Z2 has functions not available after this was done,more so then before the bypass. I have 2 other vehicles with Z1's & the bypass worked fine, the old type bypass. Thanks, Brian Quote Link to post Share on other sites
inferno999 Posted April 23, 2008 Report Share Posted April 23, 2008 The shop is telling me they have tried this before & the Z2 has functions not available after this was done,more so then before the bypass. LOL. SOOOOOOOO not true. Quote Link to post Share on other sites
Hyperite Posted April 23, 2008 Author Report Share Posted April 23, 2008 The shop is telling me they have tried this before & the Z2 has functions not available after this was done,more so then before the bypass. LOL. SOOOOOOOO not true. werd, find a different shop. Quote Link to post Share on other sites
GoombaJebboMT Posted April 24, 2008 Report Share Posted April 24, 2008 Yes I reset the unit and it behaved like I never installed the bypass Quote Link to post Share on other sites
Hyperite Posted April 24, 2008 Author Report Share Posted April 24, 2008 Yes I reset the unit and it behaved like I never installed the bypass right, so the 2-wire bypass wasn't done right. Quote Link to post Share on other sites
GoombaJebboMT Posted April 24, 2008 Report Share Posted April 24, 2008 can you give me a link or post pictures and instructions then on the 2 wire bypass? Quote Link to post Share on other sites
whtcrxghst Posted April 24, 2008 Report Share Posted April 24, 2008 Did you happen to read the first post of this thread? can you give me a link or post pictures and instructions then on the 2 wire bypass? Quote Link to post Share on other sites
GoombaJebboMT Posted April 24, 2008 Report Share Posted April 24, 2008 DOH!....thanks man. Quote Link to post Share on other sites
Hyperite Posted April 24, 2008 Author Report Share Posted April 24, 2008 goddamn i'm tempted to delete this thread Quote Link to post Share on other sites
disco-hog Posted April 25, 2008 Report Share Posted April 25, 2008 Excuse my ignorance but what do you loose on the Z2 without the bypass done? Is it just movies in motion ? Or something more ? Thanks, Brian Quote Link to post Share on other sites
whtcrxghst Posted April 25, 2008 Report Share Posted April 25, 2008 Changing routes and settings while in motion Excuse my ignorance but what do you loose on the Z2 without the bypass done?Is it just movies in motion ? Or something more ? Thanks, Brian Quote Link to post Share on other sites
disco-hog Posted April 25, 2008 Report Share Posted April 25, 2008 Thanks for the clarification Brian Quote Link to post Share on other sites
Join the conversation
