Hyperite Posted July 8, 2008 Author Report Share Posted July 8, 2008 I have a Z1 with the Z3 drive from Garrett Tommey. Is the bypass at the link below still the correct one for me? http://www.sminntech.com/z1flash.html#newbypass Thanks yes Quote Link to post Share on other sites
Hyperite Posted July 8, 2008 Author Report Share Posted July 8, 2008 Hi all, Just registered. I bought the Z2 a few days ago. I was wondering if someone can confirm that Hyperite's "Method 2" from original post will still work? If so, looks like all I have to do is download the ISO file, correct? Thanks, Paul yes...and you might not even need it. install and do the 2-wire bypass and see if it works. if not, grab the iso. Quote Link to post Share on other sites
paulpop72 Posted July 8, 2008 Report Share Posted July 8, 2008 Hey Hyper, First off, thanks for creating this thread and for your hard work. Best Buy actually installed this for me. So I'd rather not take the dash apart as I am not well-schooled in installation. So the ISO appears to be the way to go for me, right? Also...I have Sonic CD burner on my PC but I believe that is Windows-based. So I guess I should download another burner program? Thanks again! Quote Link to post Share on other sites
Hyperite Posted July 8, 2008 Author Report Share Posted July 8, 2008 Hey Hyper, First off, thanks for creating this thread and for your hard work. Best Buy actually installed this for me. So I'd rather not take the dash apart as I am not well-schooled in installation. So the ISO appears to be the way to go for me, right? Also...I have Sonic CD burner on my PC but I believe that is Windows-based. So I guess I should download another burner program? Thanks again! Well, if you didn't specifically have them do the 2-wire bypass, the ISO won't help you. Quote Link to post Share on other sites
paulpop72 Posted July 8, 2008 Report Share Posted July 8, 2008 Hey Hyper, First off, thanks for creating this thread and for your hard work. Best Buy actually installed this for me. So I'd rather not take the dash apart as I am not well-schooled in installation. So the ISO appears to be the way to go for me, right? Also...I have Sonic CD burner on my PC but I believe that is Windows-based. So I guess I should download another burner program? Thanks again! Well, if you didn't specifically have them do the 2-wire bypass, the ISO won't help you. OK. So if i go back to Best Buy...will they know exactly what a 2-wire bypass is? Will I have to show them those specific directions? The DVD was what really made me want this unit. Thanks again. Quote Link to post Share on other sites
Hyperite Posted July 8, 2008 Author Report Share Posted July 8, 2008 OK. So if i go back to Best Buy...will they know exactly what a 2-wire bypass is? Will I have to show them those specific directions? The DVD was what really made me want this unit. Thanks again. No, they won't know what it is, and even if you tell them...they SHOULD refuse to do it, since it violates corporate policy. You gotta do this one yourself. Quote Link to post Share on other sites
paulpop72 Posted July 8, 2008 Report Share Posted July 8, 2008 Looks like I'm screwed. Thanks for your help though. Quote Link to post Share on other sites
big-fokker Posted July 9, 2008 Report Share Posted July 9, 2008 You're not screwed, you're just overwhelmed. Take some time and read through the threads here. Also try to find a forum for your car specific, or get install documents from Crutchfield. Late model cars are getting easier and easier to modify...just take your time I've got an F-150 with a Z1, XM tuner, back up cam, 2 10's, 3 amps and components in all 4 doors...this was my first car install and I did it with the help of the folks here and on the F150 owners forum. Remember Happy Gilmore---> "You can do eeit" Quote Link to post Share on other sites
paulpop72 Posted July 9, 2008 Report Share Posted July 9, 2008 Thanks Big. I will give it a try and a manual from Crutchfield is on its way! I downloaded the update but because I just bought the Z2 I know Hyperite said I may not need it. It wouldn't affect the unit if I tried to download it anyway, will it? I'd rather make sure the update is straightened away before doing the 2-wire bypass. Thanks! Quote Link to post Share on other sites
big-fokker Posted July 10, 2008 Report Share Posted July 10, 2008 If I'm not mistaken, when you put the CD in and if the deck has already been updated, then you'll get a message telling you so. Shouldn't cause any harm. I'm about 95% positive on that one, but someone with a higher post count may want to verify that one Quote Link to post Share on other sites
usosuckc Posted July 10, 2008 Report Share Posted July 10, 2008 I did the mod a few days ago and it worked Fine but now it gets stuck on the Pioneer loading screen when i start up the car. i reset it a few times and it came back, but now its stuck again.anyone have an idea on how to fix this? Quote Link to post Share on other sites
GnatGoSplat Posted July 12, 2008 Report Share Posted July 12, 2008 I haven't installed my Z2 upgraded to Z3 so it's just hooked up to a battery in my house... however, simply grounding the park brake wire seems to work as the bypass. Since it seems to work, does the Z3 need a 2-wire bypass? Is the only reason it works is because I don't have the VSS hooked up? Or could it be the Z3 only needs a 1-wire bypass? Unfortunately, I didn't really play around with it much with the old Z2 software so don't know if it's acting differently with the Z3 software or not. Quote Link to post Share on other sites
Hyperite Posted July 12, 2008 Author Report Share Posted July 12, 2008 I haven't installed my Z2 upgraded to Z3 so it's just hooked up to a battery in my house... however, simply grounding the park brake wire seems to work as the bypass. Since it seems to work, does the Z3 need a 2-wire bypass? Is the only reason it works is because I don't have the VSS hooked up? Or could it be the Z3 only needs a 1-wire bypass? Unfortunately, I didn't really play around with it much with the old Z2 software so don't know if it's acting differently with the Z3 software or not. Uhh... that's the proper function... it's SUPPOSED to play movies when the parking brake is set and you're standing still. Nice job, you're using it as instructed! Quote Link to post Share on other sites
GnatGoSplat Posted July 12, 2008 Report Share Posted July 12, 2008 I haven't installed my Z2 upgraded to Z3 so it's just hooked up to a battery in my house... however, simply grounding the park brake wire seems to work as the bypass. Since it seems to work, does the Z3 need a 2-wire bypass? Is the only reason it works is because I don't have the VSS hooked up? Or could it be the Z3 only needs a 1-wire bypass? Unfortunately, I didn't really play around with it much with the old Z2 software so don't know if it's acting differently with the Z3 software or not. Uhh... that's the proper function... it's SUPPOSED to play movies when the parking brake is set and you're standing still. Nice job, you're using it as instructed! No, I mean it never tells me my parking brake is hooked up incorrectly or complains about anything. It doesn't complain even if I kill 12V constant power to the whole thing. From my understanding, the 2nd wire needs to be hooked up because hooking up just the P-brake wire alone will cause it to complain about the P-brake wire being hooked up incorrectly if it's powered up with ONLY the P-brake wire grounded. However, mine w/Z3 image doesn't do that. Quote Link to post Share on other sites
Hyperite Posted July 12, 2008 Author Report Share Posted July 12, 2008 No, I mean it never tells me my parking brake is hooked up incorrectly or complains about anything. It doesn't complain even if I kill 12V constant power to the whole thing. From my understanding, the 2nd wire needs to be hooked up because hooking up just the P-brake wire alone will cause it to complain about the P-brake wire being hooked up incorrectly if it's powered up with ONLY the P-brake wire grounded. However, mine w/Z3 image doesn't do that. Yes, I understood what you said.... why would it tell you your brake is hooked up incorrectly if it's hooked up correctly? Quote Link to post Share on other sites
Join the conversation
