GnatGoSplat Posted July 13, 2008 Report Share Posted July 13, 2008 No, I mean it never tells me my parking brake is hooked up incorrectly or complains about anything. It doesn't complain even if I kill 12V constant power to the whole thing. From my understanding, the 2nd wire needs to be hooked up because hooking up just the P-brake wire alone will cause it to complain about the P-brake wire being hooked up incorrectly if it's powered up with ONLY the P-brake wire grounded. However, mine w/Z3 image doesn't do that. Yes, I understood what you said.... why would it tell you your brake is hooked up incorrectly if it's hooked up correctly? The way I thought it's supposed to work is it senses a change in state from non-grounded to grounded, and if it detects that wire is constantly grounded, then it will alert you the p-brake wire isn't hooked up correctly like all the other AVICs. If there was never any problem having ONLY the p-brake wire constantly grounded, then what purpose is there to ground that 2nd wire? What I am saying is after the Z3 upgrade it doesn't seem to care whether that 2nd wire is grounded or not. Quote Link to post Share on other sites
Hyperite Posted July 13, 2008 Author Report Share Posted July 13, 2008 The way I thought it's supposed to work is it senses a change in state from non-grounded to grounded, and if it detects that wire is constantly grounded, then it will alert you the p-brake wire isn't hooked up correctly like all the other AVICs. If there was never any problem having ONLY the p-brake wire constantly grounded, then what purpose is there to ground that 2nd wire? What I am saying is after the Z3 upgrade it doesn't seem to care whether that 2nd wire is grounded or not. Right, but you're not moving if you're bench testing. It only claims improper hookup if it detects movement (via gps or accelerometer) while the brake is grounded. Standing still with the parking brake set, you're allowed to watch movies all day. The second wire bypasses the motion lockout. Quote Link to post Share on other sites
GnatGoSplat Posted July 13, 2008 Report Share Posted July 13, 2008 Right, but you're not moving if you're bench testing. It only claims improper hookup if it detects movement (via gps or accelerometer) while the brake is grounded. Standing still with the parking brake set, you're allowed to watch movies all day. The second wire bypasses the motion lockout. Got it, thanks. That's what I trying to find out - whether it monitors anything other than the p-brake wire like VSS, GPS, etc. Sorry I didn't make that clear! Quote Link to post Share on other sites
greenman368 Posted July 22, 2008 Report Share Posted July 22, 2008 Hello i did the update and it works fine but the other day i tried to watch tv in the back seat and there was no video it shows the menu options and the time but no video on the back screens it shows video on the front screen did i do something wrong Quote Link to post Share on other sites
trumpetblaze Posted July 23, 2008 Report Share Posted July 23, 2008 Hey greenman did u find out how to fix the back screens to get them working i can figure it does anyone know how to fix it im have the same problem as greenman did the the update file that i use turn the back screens off so they wont play video please help Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted July 23, 2008 Report Share Posted July 23, 2008 its probably a stupid question but both of you put the yellow rca from the tv's and used a y-adaptor to attach it to video in....and then you changed the settings in the unit, right? Quote Link to post Share on other sites
trumpetblaze Posted July 23, 2008 Report Share Posted July 23, 2008 yes i did that but it shows navigation on the back screens and i have the avicz2 set to mirror front screen to back screens it show ervything on the back screens except for the video it also shows the clock in the upper right hander corner and when i change the tv chanel it also shows the chanel on the rear screans but still no video Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted July 23, 2008 Report Share Posted July 23, 2008 yes i did that but it shows navigation on the back screens and i have the avicz2 set to mirror front screen to back screens it show ervything on the back screens except for the video it also shows the clock in the upper right hander corner and when i change the tv chanel it also shows the chanel on the rear screans but still no video is there a setting for video? and im sorry i meant to write plug it into video out Quote Link to post Share on other sites
trumpetblaze Posted July 23, 2008 Report Share Posted July 23, 2008 no not that i know of it used to just send it all to the back screens but after i did the video bypass the back screens dont play video they show everything else but video Quote Link to post Share on other sites
jmd07fsu Posted July 24, 2008 Report Share Posted July 24, 2008 so i just purchased a Avic z2 off ebay and was attempting to bypass it... I read the post made on the page and grounded the yellow wire with the black stripe and the light green wire first... then i put in the CD with the image, hit map and the cd said that the upgrade was already installed so i just hit reset and it all worked fine for about 10 minutes, the movie that was playing stopped and a message popped up saying something along the lines of "you can not watch videos while the car is in moving" and "the parking lead wire seems to be hooked up incorrectly"... i dont understand what is going wrong... can anybody help me!?!? Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted July 24, 2008 Report Share Posted July 24, 2008 so i just purchased a Avic z2 off ebay and was attempting to bypass it...I read the post made on the page and grounded the yellow wire with the black stripe and the light green wire first... then i put in the CD with the image, hit map and the cd said that the upgrade was already installed so i just hit reset and it all worked fine for about 10 minutes, the movie that was playing stopped and a message popped up saying something along the lines of "you can not watch videos while the car is in moving" and "the parking lead wire seems to be hooked up incorrectly"... i dont understand what is going wrong... can anybody help me!?!? did u take the black and yellow wire of out the harness and relocate it in the empty slot in the other connector? cuz thats half the bypass and you made no mention of that Quote Link to post Share on other sites
trumpetblaze Posted July 24, 2008 Report Share Posted July 24, 2008 Yes i did now here is somethink weird when i put a dvd in it plays the dvd on the back screens like it soposed to but why is my tv tuner not get broadcasted to the back screens Quote Link to post Share on other sites
Ripwire Posted July 24, 2008 Report Share Posted July 24, 2008 Does METHOD 2 work on the z3?... or should i say Z1 with a upgraded Z3 Harddrive? Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted July 24, 2008 Report Share Posted July 24, 2008 Does METHOD 2 work on the z3?... or should i say Z1 with a upgraded Z3 Harddrive? for the z1 all you have to do is the 2 wire bypass. its just z1's and early z2's that need the extra work done. Quote Link to post Share on other sites
Hyperite Posted July 24, 2008 Author Report Share Posted July 24, 2008 Does METHOD 2 work on the z3?... or should i say Z1 with a upgraded Z3 Harddrive? for the z3 all you have to do is the 2 wire bypass. its just non-bluetooth-updated z1's and early z2's that need the extra work done. fixed. Quote Link to post Share on other sites
Join the conversation
