N-S-E-W Posted May 29, 2009 Report Share Posted May 29, 2009 This line in sys.txt controls size of names and thus how many will show up at a distance:[3d_config] roadsign_lines_per_screen=19 The smaller the number, the larger the font and the fewer names displayed at a time. Stock is 20, 18 is fairly large, 19 is a compromise. Ha, I must be going blind. I have mine set to 15 in sys.txt Quote Link to post Share on other sites
Kirby692 Posted May 29, 2009 Report Share Posted May 29, 2009 Another dumb question here... what (if anything) am I supposed to do with the 'Voices' directory included in this package? Also, regarding the sounds, one of the clicks included in this package does not seem to come through very well. I'm not sure which file it is, it could be either PSG2Hi or PSG5, and when I click the volume knob (up, down or right) to get this sound it sounds mostly like a quick burst of static. Anyone else experience this? I'll try re-copying the files just in case something got corrupted, but they do play a nice click sound on my pc. Quote Link to post Share on other sites
ill.die.trying Posted May 29, 2009 Author Report Share Posted May 29, 2009 Another dumb question here... what (if anything) am I supposed to do with the 'Voices' directory included in this package? Also, regarding the sounds, one of the clicks included in this package does not seem to come through very well. I'm not sure which file it is, it could be either PSG2Hi or PSG5, and when I click the volume knob (up, down or right) to get this sound it sounds mostly like a quick burst of static. Anyone else experience this? I'll try re-copying the files just in case something got corrupted, but they do play a nice click sound on my pc. the voice i think is part of the leetlauncher, regarding the sounds i'll repost it later Quote Link to post Share on other sites
Kirby692 Posted May 29, 2009 Report Share Posted May 29, 2009 Thanks for the reply IDT! I almost copied those voice files into the voices directory on the flash disk, but when I didnt see similar style files there (only the actual voice files were there) I stopped. Glad I did! Quote Link to post Share on other sites
nissanfrontier Posted May 29, 2009 Report Share Posted May 29, 2009 All of the sounds I copied over seem to be fine, I like the new style. BTW, everythign I had trouble with is fixed. Had the tilt option off. Had to turn it on. Quote Link to post Share on other sites
Galadril Posted June 1, 2009 Report Share Posted June 1, 2009 Hi IDT, I have some problems with TMC after installing v3.8. Since I installed it I'm not able to receive any traffic information. Can this be related to your release? or is it something else? Thanks for the effort, Galadril Quote Link to post Share on other sites
ill.die.trying Posted June 1, 2009 Author Report Share Posted June 1, 2009 Hi IDT, I have some problems with TMC after installing v3.8. Since I installed it I'm not able to receive any traffic information. Can this be related to your release? or is it something else? Thanks for the effort, Galadril is this the first time your using my mod, if not have had this problem before? not sure if it's related with my mod as i didn't touch anything that would affect tmc, have you tried doing a soft reset? Quote Link to post Share on other sites
Galadril Posted June 2, 2009 Report Share Posted June 2, 2009 is this the first time your using my mod, if not have had this problem before? not sure if it's related with my mod as i didn't touch anything that would affect tmc, have you tried doing a soft reset? Yes i allready tried a soft reset.. and I used all the versions of you mod. This is the first time I have this problem.. Quote Link to post Share on other sites
ill.die.trying Posted June 2, 2009 Author Report Share Posted June 2, 2009 is this the first time your using my mod, if not have had this problem before? not sure if it's related with my mod as i didn't touch anything that would affect tmc, have you tried doing a soft reset? Yes i allready tried a soft reset.. and I used all the versions of you mod. This is the first time I have this problem.. try reverting back to your original and see if the tmc problem gets fixed, if not then it has nothing to do with the mod, if yes then i'll investigate Quote Link to post Share on other sites
DonMac21 Posted June 2, 2009 Report Share Posted June 2, 2009 ill die trying - your mod looks great. I just downloaded your 3.8 version and will try this weekend. I see you have also helped alot of users to modified it to their needs. It is always nice to see someone put alot of time into helping other users. Looking forward to loading and using your mod. Thanks Quote Link to post Share on other sites
ill.die.trying Posted June 2, 2009 Author Report Share Posted June 2, 2009 ill die trying - your mod looks great.I just downloaded your 3.8 version and will try this weekend. I see you have also helped alot of users to modified it to their needs. It is always nice to see someone put alot of time into helping other users. Looking forward to loading and using your mod. Thanks no prob Quote Link to post Share on other sites
Galadril Posted June 3, 2009 Report Share Posted June 3, 2009 try reverting back to your original and see if the tmc problem gets fixed, if not then it has nothing to do with the mod, if yes then i'll investigate OK im going to try this. I allready read just posted on the forum about a tmc problem: viewtopic.php?f=34&t=24699 Here lays the problem in the sys.txt file. I'm going to try an older on.... Thanks for the reply UPDATE Setting the first line to 'type="PIONEER746EW"' in de sys.txt fixed my tmc problem. Quote Link to post Share on other sites
ill.die.trying Posted June 5, 2009 Author Report Share Posted June 5, 2009 try reverting back to your original and see if the tmc problem gets fixed, if not then it has nothing to do with the mod, if yes then i'll investigate OK im going to try this. I allready read just posted on the forum about a tmc problem: viewtopic.php?f=34&t=24699 Here lays the problem in the sys.txt file. I'm going to try an older on.... Thanks for the reply UPDATE Setting the first line to 'type="PIONEER746EW"' in de sys.txt fixed my tmc problem. glad you got it working Quote Link to post Share on other sites
ill.die.trying Posted June 5, 2009 Author Report Share Posted June 5, 2009 just a screen shot of the new version, download will be up very soon as i am just finishing the destination buttons as i am not satisfied with the one that i just made, Quote Link to post Share on other sites
boots Posted June 5, 2009 Report Share Posted June 5, 2009 That is very nice looking! I think I'm going to have to give this a try once you put up the download! Thanks! -Brian Quote Link to post Share on other sites
Join the conversation
