MrAutoPilot Posted September 11, 2010 Report Share Posted September 11, 2010 Okay, I received my CNSD-200FM Update from Pioneer (got here surprisingly fast). I updated my F710BT to the latest. I decided to install this Mod today and I have to say HOW COOL!!! I totally love it!!! You people are awesome!!! Thanks a million, everyone! I can't wait to try some other stuff! Quote Link to post Share on other sites
dlane2155 Posted September 13, 2010 Report Share Posted September 13, 2010 I am new to this forum. I installed this mod yesterday and it is fabulous. I read 55 pages of this forum trying to find answers to the few questions I have and found nothing. 1. Is there a way to completely remove the sky mod from this? 2. I know the compass changes the view, however is there a way to make the "button" bigger? I can never hit the button unless I am using a stylus. I have no problems hitting the back button on other screens. Would it be too much trouble to make the button footprint the same size as the back button on the other screens? 3. I have noticed that sometimes it likes to switch to 2D mode on its own. I have not used this long enough to figure out when it does it, but just thought I would bring it up, and maybe someone knows why? Thanks and great work!!! Quote Link to post Share on other sites
Chuck88 Posted September 13, 2010 Report Share Posted September 13, 2010 As the title suggests, this mod was not updated since a long time (8 months now). You will have better chance to ask Abb for his Chrome mod V3.25, that is based on this one. Good luck. Quote Link to post Share on other sites
dlane2155 Posted September 13, 2010 Report Share Posted September 13, 2010 As the title suggests, this mod was not updated since a long time (8 months now). You will have better chance to ask Abb for his Chrome mod V3.25, that is based on this one. Good luck. Yea I was wondering if someone could help me do it myself. Oh well I suppose I will live with it. Thanks though. Quote Link to post Share on other sites
Harvey_Gordon Posted September 14, 2010 Report Share Posted September 14, 2010 "3. I have noticed that sometimes it likes to switch to 2D mode on its own. I have not used this long enough to figure out when it does it, but just thought I would bring it up, and maybe someone knows why?" Just a thought. Have you checked your zoom settings? The map will switch to 2d when the next instruction is a distance greater than you have it set for. I have mine at 3 miles. When you are within the range set, it goes back to 3d. I also have mine set at a 5 mile overview. You can go up to 20 I think. it's your choice. If this is not it, then another guess will have to be put forth. Good luck. Quote Link to post Share on other sites
Chuck88 Posted September 14, 2010 Report Share Posted September 14, 2010 I am new to this forum. I installed this mod yesterday and it is fabulous. 1. Is there a way to completely remove the sky mod from this? Could you clarify what you want to achieve? Remove the sky to see more real-estate of the map? You can play with smartzoom settings to do that. 3. I have noticed that sometimes it likes to switch to 2D mode on its own. I have not used this long enough to figure out when it does it, but just thought I would bring it up, and maybe someone knows why? As Harvey_Gordon suggested, this is the Overview mode, you have likely set it to ON (or by default ON). Try to turn it OFF under navigation settings. Quote Link to post Share on other sites
dlane2155 Posted September 14, 2010 Report Share Posted September 14, 2010 I am new to this forum. I installed this mod yesterday and it is fabulous. 1. Is there a way to completely remove the sky mod from this? Could you clarify what you want to achieve? Remove the sky to see more real-estate of the map? You can play with smartzoom settings to do that. 3. I have noticed that sometimes it likes to switch to 2D mode on its own. I have not used this long enough to figure out when it does it, but just thought I would bring it up, and maybe someone knows why? As Harvey_Gordon suggested, this is the Overview mode, you have likely set it to ON (or by default ON). Try to turn it OFF under navigation settings. I want to make it so it is not possible to see the sky at all and revert this portion of the mod. I live in the middle of nowhere and it looks pretty dumb seeing skyscrapers in the background. Overview mode is OFF. Turned it off because I do not know what it is. I will double check the settings again tomorrow just to double check, but I'm pretty sure its off. I'm a little confused on the Smartzoom thing too I guess. I would not think that would switch it to 2D mode? I thought it only zoomed in on the turn when you were getting close to it? I never used the navigation feature that much on this, before this mod, as I cant stand the voice. Quote Link to post Share on other sites
Chuck88 Posted September 14, 2010 Report Share Posted September 14, 2010 I want to make it so it is not possible to see the sky at all and revert this portion of the mod. I live in the middle of nowhere and it looks pretty dumb seeing skyscrapers in the background. Replace the [smartzoom] section in your SYS.TXT file (\My Flash Disk\APL2\iGo) with the following and play with minangle and maxangle. The following settings might work for you without modification. [smartzoom] restore_smartzoom_on=1 speedzoom=6 speedangle=8 minzoom=40 ; distance from the car when zoom in maxzoom=80 ; distance from the car when zoom out (normal navigation) minangle=70 ; for Diaftia's mod: <= 70, incline properly at turn; starting with 75, no more inclining; at 80, start to see the sky maxangle=90 ; 90 is the max angle to see the whole sky On the other point, if it is not Overview=enabled, then it might be a bug in Diaftia's mod. Good lucks. Quote Link to post Share on other sites
Redeye Posted September 16, 2010 Report Share Posted September 16, 2010 is this supposed to have 3d buildings? mine doesn't show. please correct me if i'm wrong. Also, how do you get the speedometer to show up. There is only a small box on the map that shows your speed. Does it just read what your actual speedometer is showing or is the speed of the car really accurate?Read the instructions. I think that they are on pg 24 I am having the same problem with the 3D buildings. I have tried all 3 settings from close to far and still see no buildings. I read the directions and didn't find the answer. Am I missing something or is there maybe another setting that needs to be enabled/disabled inorder for the bldgs to show??? Thanks in advance Mike Quote Link to post Share on other sites
ovalball Posted September 16, 2010 Report Share Posted September 16, 2010 is this supposed to have 3d buildings? mine doesn't show. please correct me if i'm wrong. Also, how do you get the speedometer to show up. There is only a small box on the map that shows your speed. Does it just read what your actual speedometer is showing or is the speed of the car really accurate?Read the instructions. I think that they are on pg 24 I am having the same problem with the 3D buildings. I have tried all 3 settings from close to far and still see no buildings. I read the directions and didn't find the answer. Am I missing something or is there maybe another setting that needs to be enabled/disabled inorder for the bldgs to show??? Thanks in advance Mike The 3D buildings only show if they are actually there!In the UK I have yet to come across any,although I am sure if I drive through the centre of London they will be there.I did drive through Paris(by mistake)and some popped up there. Quote Link to post Share on other sites
Chuck88 Posted September 17, 2010 Report Share Posted September 17, 2010 The 3D buildings only show if they are actually there!In the UK I have yet to come across any,although I am sure if I drive through the centre of London they will be there.I did drive through Paris(by mistake)and some popped up there. Guys, You can easily check whether your setup is able to show buildings. Just manually set a Start point and a Destination, which that you know for sure there are buildings surround, such as downtown area of major city, then simulate/flyover a route. Got the picture? Quote Link to post Share on other sites
dlane2155 Posted September 17, 2010 Report Share Posted September 17, 2010 Replace the [smartzoom] section in your SYS.TXT file (\My Flash Disk\APL2\iGo) with the following and play with minangle and maxangle. The following settings might work for you without modification. [smartzoom] restore_smartzoom_on=1 speedzoom=6 speedangle=8 minzoom=40 ; distance from the car when zoom in maxzoom=80 ; distance from the car when zoom out (normal navigation) minangle=70 ; for Diaftia's mod: <= 70, incline properly at turn; starting with 75, no more inclining; at 80, start to see the sky maxangle=90 ; 90 is the max angle to see the whole sky On the other point, if it is not Overview=enabled, then it might be a bug in Diaftia's mod. Good lucks. Thanks, I will give that a shot. I also figured out that it switches to 2D mode when I enter HOME as my destination. If I enter an address manually it does not do that??? Quote Link to post Share on other sites
krasspc Posted October 8, 2010 Report Share Posted October 8, 2010 As the title suggests, this mod was not updated since a long time (8 months now). You will have better chance to ask Abb for his Chrome mod V3.25, that is based on this one. Does anybody use Chrome mod with european units, with european speed signs and so on? And anybody knows how to get POI and speedcams for Germany? Thx Quote Link to post Share on other sites
ovalball Posted October 8, 2010 Report Share Posted October 8, 2010 As the title suggests, this mod was not updated since a long time (8 months now). You will have better chance to ask Abb for his Chrome mod V3.25, that is based on this one. Does anybody use Chrome mod with european units, with european speed signs and so on? And anybody knows how to get POI and speedcams for Germany? Thx I use the chrome mod with European signs etc.You can get German POI'S maps etc from here http://btjunkie.org/torrent/iGO-TeleAtl ... 4042ab816b and speed cams from here http://www.scdb.info/en/ Quote Link to post Share on other sites
krasspc Posted October 8, 2010 Report Share Posted October 8, 2010 I´ve tried, but this happens: Invalid Torrent ID! Try using the search. Torrents are automatically removed from the database when they are no longer active. Any help (please don´t throw any stones in my directions, I know how to deal with torrent links) Quote Link to post Share on other sites
