jbarn Posted February 15, 2009 Report Share Posted February 15, 2009 New F700BT owner here. I installed the F-series bypass just fine by reading the instructions on this forum. Great info guys. My question is simple. Can I get this mod (mute) by only putting the "navigatemap_800_480.ui" from the zipped download in this thread in the "ui_pioneer\common\ui" location on the unit? If not can someone dumb it down for me and tell me exactly what from the download I need to put exactly where? Quote Link to post Share on other sites
BorisM Posted February 15, 2009 Report Share Posted February 15, 2009 New F700BT owner here. I installed the F-series bypass just fine by reading the instructions on this forum. Great info guys. My question is simple. Can I get this mod (mute) by only putting the "navigatemap_800_480.ui" from the zipped download in this thread in the "ui_pioneer\common\ui" location on the unit? If not can someone dumb it down for me and tell me exactly what from the download I need to put exactly where? navigatemap_800_480.ui will go into ui_pioneer\800_480\ui Quote Link to post Share on other sites
jbarn Posted February 15, 2009 Report Share Posted February 15, 2009 New F700BT owner here. I installed the F-series bypass just fine by reading the instructions on this forum. Great info guys. My question is simple. Can I get this mod (mute) by only putting the "navigatemap_800_480.ui" from the zipped download in this thread in the "ui_pioneer\common\ui" location on the unit? If not can someone dumb it down for me and tell me exactly what from the download I need to put exactly where? navigatemap_800_480.ui will go into ui_pioneer\800_480\ui Yup, got it. 3 mods now working! Thanks! Quote Link to post Share on other sites
JDUB916 Posted February 25, 2009 Report Share Posted February 25, 2009 This worked great, thank you so much!!! I hated the voice guidance interrupting my music every 5 minutes to tell where to go! Quote Link to post Share on other sites
JohnnyMac Posted March 25, 2009 Report Share Posted March 25, 2009 Uhhh... do what? Possibly step-by-step this mod for a guy that doesn't have code skills? I did sucessfully make the bypass speed change in the F500BT 2.0 upgrade, so I can bounce around in the program with a basic understanding... but I'm lost reading through these posts. Any help is greatly appreciated - I NEED that nav voice mute button! Thanks for everything - Johnny Mac Quote Link to post Share on other sites
andythilo Posted April 3, 2009 Report Share Posted April 3, 2009 Hi Will this cure my audio glitching when the sat nav is active? Quote Link to post Share on other sites
andythilo Posted April 3, 2009 Report Share Posted April 3, 2009 Yes can some kind sole please post a how 2 in basic noob language please? Quote Link to post Share on other sites
snork11z Posted July 3, 2009 Report Share Posted July 3, 2009 There are two ways to do it: 1. Take files you want to change from the mod's DATA.ZIP to the same locations. I.e. file.ui goes into ui_pioneer\common\ui anf file_800_480.ui goes to ui_pioneer\800_480\ui folder inside the ZIP file. Using WinRAR or 7ZIP isw very much preferred here because WinZIP is brain dead and won't add files to a subfolder inside an archive. 2. Preferred option for testing out changes: create a folder ui_pioneer on your SD card. inside create 800_480 and common subfolders, and ui folder inside each of those subfolders. Now copy changed files to those ui subfolders, as above, and copy the entire ui_pioneer to APL2\iGO folder on the head unit. This way you can keep a working DATA.ZIP on the unit and test out changes. If they work, you can move them to DATA.ZIP later on. If you don't like them, roll back by deleting ui_pioneer from the head unit. Thanks BorisM and to All, This MOD worked like a charm. Took me while to get it because I was extracting the data.zip folder first then making the changes. I used 7zip like suggested and made the changes without extracting the folder. Quote Link to post Share on other sites
kqtrinh Posted July 12, 2009 Report Share Posted July 12, 2009 hi, my unit is currently loaded with 2.06 firmware. How can I add voice guidance mute button with the plain vanilla firmware without any hack software? I search the whole firmware release directories for the pioneer_ui directory and couldn't find any. Thanks, --Khai Quote Link to post Share on other sites
avic_weo Posted July 13, 2009 Report Share Posted July 13, 2009 All, just wanted to let you know this mod works on the new 3.005 firmware. I just added the 2 lines in the appropriate ui, and added the 2 icons, I did not use the ui in the zip file, because there are some more or less differences with 2.x 3.010 has the same ui, so I am fairly confident this will work too. Weo Quote Link to post Share on other sites
my_black_RS5 Posted July 28, 2009 Report Share Posted July 28, 2009 Nice, I will try this tonight on my AVIC-X710BT running 910BT 3.0 firmware. [EDIT] I was a little busy Tuesday night, but on my lunch break today (Thursday) I successfully added this code the way it was described on page 1 and it worked as expected. The buttons "746_32K_OM-019_32b.bmp" and "746_32K_OM-018_32b.bmp" that the script uses, however, are not the most attractive. They are simply the green and red ones included in the firmware. I liked the buttons included in the zip on page 1 much better and will alter the code to use them when I have the time. I still want to be able to tap the arrow in the top left corner to hear the direction. Does anyone know if I can just alter the code for that button to unmute before and then remute after the direction is announced? I feel like this would interfere with the mute button. Has anyone played with this? [/EDIT] Quote Link to post Share on other sites
nbdew002 Posted July 28, 2009 Report Share Posted July 28, 2009 Anybody else try this? Quote Link to post Share on other sites
Pioneer4x4 Posted September 2, 2009 Report Share Posted September 2, 2009 There are two ways to do it: 1. Take files you want to change from the mod's DATA.ZIP to the same locations. I.e. file.ui goes into ui_pioneer\common\ui anf file_800_480.ui goes to ui_pioneer\800_480\ui folder inside the ZIP file. Using WinRAR or 7ZIP isw very much preferred here because WinZIP is brain dead and won't add files to a subfolder inside an archive. 2. Preferred option for testing out changes: create a folder ui_pioneer on your SD card. inside create 800_480 and common subfolders, and ui folder inside each of those subfolders. Now copy changed files to those ui subfolders, as above, and copy the entire ui_pioneer to APL2\iGO folder on the head unit. This way you can keep a working DATA.ZIP on the unit and test out changes. If they work, you can move them to DATA.ZIP later on. If you don't like them, roll back by deleting ui_pioneer from the head unit. I have tried both ways and it never fully boots it stays at the screen with the "System Startup in Progress... "message . And while I am new to editing my F90bt, I am in no way a noob at windows or CE (I still have a CE 1.1 device!, and CE is the main reason I bought this Pioneer unit) I have a F90BT with 2.000 on it. Also is there a scripting language that you can use in CE? If I get it working I want to make it automated to add/remove it. I have testmode on a SD card, modified files/folders on my USB drive (with backups of originals), then I boot with card in and copy from usb to 'flash drive' either modified files, or the originals to revert. Quote Link to post Share on other sites
Pioneer4x4 Posted September 3, 2009 Report Share Posted September 3, 2009 I REALLY would love to get this working, but every time I try various methods i get the system startup message... I am running 2.0000 should I hold off on any mods until I update to 2.006? Quote Link to post Share on other sites
Pioneer4x4 Posted September 8, 2009 Report Share Posted September 8, 2009 Does anyone have any insight? Should I try again or put the 2.0006 update on first? Quote Link to post Share on other sites
Join the conversation
