cmh928 Posted May 31, 2009 Author Report Share Posted May 31, 2009 Superman, you will need to at least grab nm.ui, nm8x4.ui, setting8x4.ui and advmenu.ui from my new versions or just drop your graphics onto my new data.zip. Quote Link to post Share on other sites
fivehundred Posted May 31, 2009 Report Share Posted May 31, 2009 Awesome Mod Unzipped it to my sd card put it in the stereo turned the key on , and it all went great , thank you for your time creating it and posting it Quote Link to post Share on other sites
DonMac21 Posted May 31, 2009 Report Share Posted May 31, 2009 Thanks for posting your mod. Loaded today with no problems. Looks GREAT and a lot of work went into it. Thanks again. Quote Link to post Share on other sites
CyberDad Posted May 31, 2009 Report Share Posted May 31, 2009 Thanks for the update, Cmh928! As always, it works like a charm! Quote Link to post Share on other sites
diaftia Posted May 31, 2009 Report Share Posted May 31, 2009 Diaftia, make sure you delete any current route and leave the nav screen for a menu or source screen before you shutdown. Then install the AIO again. I found a few bugs in Guga's theme and fixed the BMPs. This is included in the new all-in-one. Fresh copies of all are uploading now. Give them 20 minutes or so to finish.  If you are happy with what you currently have, then leave it alone. Don't get upgrade happy just because I'm a perfectionist and keep playing with the files.  hey cmh928-  I will give that a shot... thanks. I had a piece together of some of previous mods loaded and did that by hand. It was quite a while ago. I see yours now and i like it much better. I am always down for a good tweak to make this thing better. Quote Link to post Share on other sites
diaftia Posted May 31, 2009 Report Share Posted May 31, 2009 Diaftia, make sure you delete any current route and leave the nav screen for a menu or source screen before you shutdown. Then install the AIO again. I found a few bugs in Guga's theme and fixed the BMPs. This is included in the new all-in-one. Fresh copies of all are uploading now. Give them 20 minutes or so to finish.  If you are happy with what you currently have, then leave it alone. Don't get upgrade happy just because I'm a perfectionist and keep playing with the files.   whoa whoa whoa... did you just updated your file like twice today? because i just zipped up the red theme to yours at the request of a few people. now im not sure if i zipped the latest file or not.  Hey Superman- Where can we get your red version of the cmh mods package? I have an Audi with Red dash lights and I think it might go nicely. Quote Link to post Share on other sites
landmark Posted May 31, 2009 Report Share Posted May 31, 2009 I just load the mod. Very nice. I like when you want to change from day to night ( press the compass) .nice clock size ,lot of colour map, menu button very easy to read and use,I need to play with it a bit more but so far very good. Thank you Cmh928. Quote Link to post Share on other sites
superman8262 Posted May 31, 2009 Report Share Posted May 31, 2009 Superman, you will need to at least grab nm.ui, nm8x4.ui, setting8x4.ui and advmenu.ui from my new versions or just drop your graphics onto my new data.zip. Â i just went ahead and rezipped it with your latest zip (10pm). so i got the red theme of your settings all done and reorganized posted it up already thanks. its been asked by several members here so i did it. Quote Link to post Share on other sites
jasher Posted May 31, 2009 Report Share Posted May 31, 2009 helloo guys...a newbie here...just wanted to ask if i can just add this on my f500 SamHybridTTS-Auto.zip and not all the mods...just wanted to change samantha Quote Link to post Share on other sites
jasher Posted May 31, 2009 Report Share Posted May 31, 2009 and...how and where to i put it Quote Link to post Share on other sites
diaftia Posted May 31, 2009 Report Share Posted May 31, 2009 hey cmh- I hate to be one of "those" people needing troubleshoot assistance; but do you happen to know what its doing when it says system starting and reboots? I wonder if there are some files that I had modded in the past that are not agreeing with your setup. It seems most everyone is loading this fine. I have even done a system reset to make sure everything should be in a good state and I am still getting the reboots. I *believe* (its been quite a while) the mods that I had done in the past were based on Mavericksters data.zip but I would assume that you would be overwriting most of the mods that I had done. I think I have the backup somplace but like I said your restore to OEM setup works great. I am confused. Quote Link to post Share on other sites
cmh928 Posted May 31, 2009 Author Report Share Posted May 31, 2009 Daftia, you don't say what unit you are using or which region. Try just the data.zip by itself if you are having problems loading the AIO. Otherwise, try the standard list of reboot issue steps. delete user\userdata\ folder and the 4 gpsparaxx.bin files in the root of myflashdisk. Quote Link to post Share on other sites
diaftia Posted May 31, 2009 Report Share Posted May 31, 2009 Daftia, you don't say what unit you are using or which region. Try just the data.zip by itself if you are having problems loading the AIO. Otherwise, try the standard list of reboot issue steps. delete user\userdata\ folder and the 4 gpsparaxx.bin files in the root of myflashdisk. Â Hey chm... good point. F90BT in the US. Â I will try the tips you mentioned as well. Did not know those. Quote Link to post Share on other sites
cmh928 Posted May 31, 2009 Author Report Share Posted May 31, 2009 helloo guys...a newbie here...just wanted to ask if i can just add this on my f500 SamHybridTTS-Auto.zip and not all the mods...just wanted to change samantha Jasher, the Lord helps those who read !readme! files and use the forum search engine. If it is covered in the first post or the readme files on the FTP, it won't be answered again in the thread. Quote Link to post Share on other sites
crilleym Posted May 31, 2009 Report Share Posted May 31, 2009 cmh, take a look at my pic in supermans red theme thread. I changed my POI's a little bit. Can you see a change? Quote Link to post Share on other sites
Join the conversation
