ttorski Posted August 24, 2009 Report Share Posted August 24, 2009 IDT Can you post code fixing dist/time window not showing up in "go home" mode? (I`m running IDT3.0v1) thanks Quote Link to post Share on other sites
ill.die.trying Posted August 24, 2009 Author Report Share Posted August 24, 2009 IDTCan you post code fixing dist/time window not showing up in "go home" mode? (I`m running IDT3.0v1) thanks  go to start.ui, search for sc_ReturnHome and add this line before the end of the script ui_RouteinfoBackground.show Quote Link to post Share on other sites
ttorski Posted August 24, 2009 Report Share Posted August 24, 2009 IDTCan you post code fixing dist/time window not showing up in "go home" mode? (I`m running IDT3.0v1) thanks  go to start.ui, search for sc_ReturnHome and add this line before the end of the script ui_RouteinfoBackground.show  thanks Quote Link to post Share on other sites
Danno Posted August 24, 2009 Report Share Posted August 24, 2009 I had some odd behavior this morning on the ride in to work with 3.1. all was fine until I got on the highway, and then as soon as the first Highway Sign for teh next exit showed up, the map automatically switched to 2D view. and even cycling through with the 3D/2D/2Dn button, I couldn't get 3d mode back until I exited the highway. Â but - I did forget to flush the user data files before I went from IDT v3.0 to v3.1. I flushed them before I got out of the car when I got to work, but that was int he garage with no GPS signal. Â Any idea why it would do that, and should I expect it to keep doing that now that I've cleared the user data? Quote Link to post Share on other sites
ttorski Posted August 24, 2009 Report Share Posted August 24, 2009 IDTCan you post code fixing dist/time window not showing up in "go home" mode? (I`m running IDT3.0v1) thanks  go to start.ui, search for sc_ReturnHome and add this line before the end of the script ui_RouteinfoBackground.show   thanks a lot, I got this working I was trying to put comp trip to v1 from v3 but everytime I got errors, can you help me to get this right, can you take look at my datatrip.zip file and fixed for me or just put comp trip mod in to my last working data.zip ? I would owe you big time here is a link with files http://webpages.charter.net/torez22 Quote Link to post Share on other sites
ill.die.trying Posted August 24, 2009 Author Report Share Posted August 24, 2009 I had some odd behavior this morning on the ride in to work with 3.1. all was fine until I got on the highway, and then as soon as the first Highway Sign for teh next exit showed up, the map automatically switched to 2D view. and even cycling through with the 3D/2D/2Dn button, I couldn't get 3d mode back until I exited the highway. Â but - I did forget to flush the user data files before I went from IDT v3.0 to v3.1. I flushed them before I got out of the car when I got to work, but that was int he garage with no GPS signal. Â Any idea why it would do that, and should I expect it to keep doing that now that I've cleared the user data? Â that shouldn't be doing that, check if that happens again and let me know Quote Link to post Share on other sites
ill.die.trying Posted August 24, 2009 Author Report Share Posted August 24, 2009 IDTCan you post code fixing dist/time window not showing up in "go home" mode? (I`m running IDT3.0v1) thanks  go to start.ui, search for sc_ReturnHome and add this line before the end of the script ui_RouteinfoBackground.show   thanks a lot, I got this working I was trying to put comp trip to v1 from v3 but everytime I got errors, can you help me to get this right, can you take look at my datatrip.zip file and fixed for me or just put comp trip mod in to my last working data.zip ? I would owe you big time here is a link with files http://webpages.charter.net/torez22  i'll take a look at it Quote Link to post Share on other sites
ttorski Posted August 24, 2009 Report Share Posted August 24, 2009   thanks a lot, I got this working I was trying to put comp trip to v1 from v3 but everytime I got errors, can you help me to get this right, can you take look at my datatrip.zip file and fixed for me or just put comp trip mod in to my last working data.zip ? I would owe you big time here is a link with files http://webpages.charter.net/torez22  i'll take a look at it  great one more thing I wanna get to trip comp by pressing curent street Quote Link to post Share on other sites
ttorski Posted August 24, 2009 Report Share Posted August 24, 2009 I have no problems download from http://webpages.charter.net/torez22/ Â but if so go to ftp://webpages.charter.net/ Â user name: torez22 pass: ironmaiden Quote Link to post Share on other sites
sponge Posted August 24, 2009 Report Share Posted August 24, 2009 I also can not get the trip computer to start - the only field that updates is the speed. Immediately after installing the mod, I went to the trip computers and all 3 had data, so I reset them. Now I can't get them to start. Any ideas? Â Jim Quote Link to post Share on other sites
ill.die.trying Posted August 24, 2009 Author Report Share Posted August 24, 2009 I also can not get the trip computer to start - the only field that updates is the speed. Immediately after installing the mod, I went to the trip computers and all 3 had data, so I reset them. Now I can't get them to start. Any ideas? Jim  did you delete the save folder? also, could you check your gps signal, not sure why it's acting up but i never had any problems with mine, Quote Link to post Share on other sites
sponge Posted August 24, 2009 Report Share Posted August 24, 2009 I deleted all the files in the iGo\Save directory and my GPS signal strength is high. The Trip Computer worked immediately after install, but nothing after I reset them. Also, when you go to the Trip Computer screen, there is text that you can see behind the main text at the top of the screen. Not sure exactly but I could go take a look if you like. I have not tried a reset. Â Jim Quote Link to post Share on other sites
ill.die.trying Posted August 24, 2009 Author Report Share Posted August 24, 2009 I deleted all the files in the iGo\Save directory and my GPS signal strength is high. The Trip Computer worked immediately after install, but nothing after I reset them. Also, when you go to the Trip Computer screen, there is text that you can see behind the main text at the top of the screen. Not sure exactly but I could go take a look if you like. I have not tried a reset. Jim  if you could post a picture that would be great Quote Link to post Share on other sites
diaftia Posted August 24, 2009 Report Share Posted August 24, 2009 I deleted all the files in the iGo\Save directory and my GPS signal strength is high. The Trip Computer worked immediately after install, but nothing after I reset them. Also, when you go to the Trip Computer screen, there is text that you can see behind the main text at the top of the screen. Not sure exactly but I could go take a look if you like. I have not tried a reset. Jim  if you could post a picture that would be great  FYI- I can see this on mine too. There is something back there that is really faint. May not show up in a photo. Its something that is part of the original trip computer IMO. Quote Link to post Share on other sites
sponge Posted August 25, 2009 Report Share Posted August 25, 2009 Well I went out to take the pix, and noticed my trip timer running. Took a drive around the block and it worked o-k. Weird. I will keep an eye on it. I did take some pix and sent them to your e-mail IDT. You can see the word "settings" in the background on the Trip Computer screen. My phone doesn't take great pix, but I think you'll see what I mean. Also, the camera icon is missing a horizontal row of pixels. You should see that in the pic. I like the mod, and will send a little beer money your way. Â Jim Quote Link to post Share on other sites
