diaftia Posted October 8, 2009 Author Report Share Posted October 8, 2009 10/8/09 Added a no GPS Signal Icon for when GPS is turned off or no signal is detected. Made the text larger for distance to destination and time to destination/waypoint toggle. Made it so that distance to destination brings up itinerary Cleaned up the text in the settings to hopefully better reflect what the secondary direction distance settings do. FIxed the full screen cockpit to show an alternate view for people that do not like a lot of information on the navigation screen. Changed the house numbers to follow suit with the theme of the mods. Fixed a problem where the mute icon was not showing on the speedo screen when navigation was muted. Fixed an issue where when the signpost was very large it would overlap a the your speed sign slightly. Quote Link to post Share on other sites
69sixpackbee Posted October 8, 2009 Report Share Posted October 8, 2009 Is there no background "box" behind the next maneuver now? Thanx, Bud Quote Link to post Share on other sites
diaftia Posted October 8, 2009 Author Report Share Posted October 8, 2009 Is there no background "box" behind the next maneuver now? Thanx, Bud There is. When you switch full screen cockpit on (off by default) it goes away to open up the navigation screen. So to recap: If you leave Full Screen Cockpit off it looks the same, if you switch it on you get the new view. Think of it as two different navigational views based on preference in one set of mods. Added an extra screen cap at the top so you can see the two to hopefully avoid confusion. Quote Link to post Share on other sites
shawnmos Posted October 8, 2009 Report Share Posted October 8, 2009 I just noticed that the GPS knows what side of the street house numbers are on. Is there anyway to make it announce which side of the street the destination is? Quote Link to post Share on other sites
diaftia Posted October 8, 2009 Author Report Share Posted October 8, 2009 I just noticed that the GPS knows what side of the street house numbers are on. Is there anyway to make it announce which side of the street the destination is? That is supposedly done separately in a voice file. I don't think its in the data.zip. There was a thread on here about it but from what I read nothing conclusive that the voicefile posted on the forums actually solved the problem. I have no problem bundling it in if someone can actually locate a file that for sure has been tested to work. Quote Link to post Share on other sites
shawnmos Posted October 8, 2009 Report Share Posted October 8, 2009 I just came across this: http://avic411.com/forum/viewtopic.php?f=34&t=25147&p=188481&hilit=destination+on+left#p187103 I downloaded the voice file but haven't tested it yet. Quote Link to post Share on other sites
diaftia Posted October 8, 2009 Author Report Share Posted October 8, 2009 I just came across this: http://avic411.com/forum/viewtopic.php?f=34&t=25147&p=188481&hilit=destination+on+left#p187103 I downloaded the voice file but haven't tested it yet. Exactly, and the last post in that thread is N-S-E-W saying he lost the feature. Add it in and let me know how it goes. Quote Link to post Share on other sites
moneysh08 Posted October 8, 2009 Report Share Posted October 8, 2009 what mode are you in with the green buttons? Quote Link to post Share on other sites
diaftia Posted October 8, 2009 Author Report Share Posted October 8, 2009 what mode are you in with the green buttons? Flyover or Simulate route. Quote Link to post Share on other sites
shawnmos Posted October 8, 2009 Report Share Posted October 8, 2009 Well it doesn't work with a simulated route. Quote Link to post Share on other sites
diaftia Posted October 8, 2009 Author Report Share Posted October 8, 2009 Well it doesn't work with a simulated route. Spoken directions? If so, I figured. I think one of those older threads might need to be revived. It doesn't seem as easy as just changing the voice file. Quote Link to post Share on other sites
ovalball Posted October 8, 2009 Report Share Posted October 8, 2009 Hi.Can you please tell me what the car symbol is for on the lower right of the Nav screen?Thanks. Quote Link to post Share on other sites
shawnmos Posted October 8, 2009 Report Share Posted October 8, 2009 It appears when you move the map. It recenters the map to the position of your car. Quote Link to post Share on other sites
ovalball Posted October 8, 2009 Report Share Posted October 8, 2009 It appears when you move the map. It recenters the map to the position of your car. OK Thank you. Quote Link to post Share on other sites
Pioneer4x4 Posted October 8, 2009 Report Share Posted October 8, 2009 I noticed that almost everything has some transparency to it except for the next turn, and destination time/distance boxes and the other buttons below them, can they be made transparent also? Quote Link to post Share on other sites
