maddog hoek Posted February 18, 2010 Report Share Posted February 18, 2010 IDT, try navigating from 7000 tylersviller rd. 45069 to 1623 dalton st. 45214 or anywhere in 45202. thanks, it should take you down I-75 and you should see plenty of exit signs. Quote Link to post Share on other sites
ill.die.trying Posted February 18, 2010 Author Report Share Posted February 18, 2010 IDT, try navigating from 7000 tylersviller rd. 45069 to 1623 dalton st. 45214 or anywhere in 45202. thanks, it should take you down I-75 and you should see plenty of exit signs. i will do a simulation on that when i get home and will let yo u know asap Quote Link to post Share on other sites
azrcnut Posted February 18, 2010 Report Share Posted February 18, 2010 I want to use the subaru for my 3D car but dont know what file it is...it comes up as default but size parameters don't apply....thanks Quote Link to post Share on other sites
ill.die.trying Posted February 18, 2010 Author Report Share Posted February 18, 2010 I want to use the subaru for my 3D car but dont know what file it is...it comes up as default but size parameters don't apply....thanks instructions are in the the first page Quote Link to post Share on other sites
crilleym Posted February 18, 2010 Report Share Posted February 18, 2010 IDT, try navigating from 7000 tylersviller rd. 45069 to 1623 dalton st. 45214 or anywhere in 45202. thanks, it should take you down I-75 and you should see plenty of exit signs. i will do a simulation on that when i get home and will let yo u know asap Maddog, Are you using Navteq or teleatlas maps? I have noticed in the past that Navteq maps will not show road signs but Teleatlas does. I will try a route here in a few and get back to you. Quote Link to post Share on other sites
ill.die.trying Posted February 18, 2010 Author Report Share Posted February 18, 2010 IDT, try navigating from 7000 tylersviller rd. 45069 to 1623 dalton st. 45214 or anywhere in 45202. thanks, it should take you down I-75 and you should see plenty of exit signs. Maddog, Are you using Navteq or teleatlas maps? I have noticed in the past that Navteq maps will not show road signs but Teleatlas does. I will try a route here in a few and get back to you. that is a good point, i have read somewhere's too that there's not much map data on the NAVTEQ maps Quote Link to post Share on other sites
crilleym Posted February 18, 2010 Report Share Posted February 18, 2010 I just confirmed it. Navteq, no road signs. Teleatlas, road signs. I have a mix of maps with both and did a route going through states that have nav and ta. Funny, road signs show up in states that have ta and they don't show up when I enter a navteq state. I could really care less about them, just so I know where I am going. Quote Link to post Share on other sites
ill.die.trying Posted February 18, 2010 Author Report Share Posted February 18, 2010 I just confirmed it. Navteq, no road signs. Teleatlas, road signs. I have a mix of maps with both and did a route going through states that have nav and ta. Funny, road signs show up in states that have ta and they don't show up when I enter a navteq state. I could really care less about them, just so I know where I am going. thanks for investigating Quote Link to post Share on other sites
maddog hoek Posted February 18, 2010 Report Share Posted February 18, 2010 I'm using the Teleatlas maps, I'm going to try the Navteq shortly. The signs where there when I had skin #1. I'm going to try removing the fov=55 value to see if that did it. Quote Link to post Share on other sites
gotti2k7 Posted February 19, 2010 Report Share Posted February 19, 2010 NOTE: If you use this mod and you dont have a navteq map installed go to extension folder and delete map changer before you install the mod. I just had to reload my 3.0 cause i hit this button and it threw my system into a reeboot loop. I just found this out too. The hard way. How do i fix this. I tried going back to my pioneer cards and reinstalling 3.0. Wont read the cards, prolly cause its the current version. Quote Link to post Share on other sites
ill.die.trying Posted February 19, 2010 Author Report Share Posted February 19, 2010 NOTE: If you use this mod and you dont have a navteq map installed go to extension folder and delete map changer before you install the mod. I just had to reload my 3.0 cause i hit this button and it threw my system into a reeboot loop. I just found this out too. The hard way. How do i fix this. I tried going back to my pioneer cards and reinstalling 3.0. Wont read the cards, prolly cause its the current version. just boot to testmode and rename map to map_nt and map_ta to map, dnt forget to delete the contents of save folder Quote Link to post Share on other sites
abb1 Posted February 19, 2010 Report Share Posted February 19, 2010 Well, I hope that you don't mind Julius, but I 'RedBlasted' your mod to suit my 'RedBlast theme'. Tell me what you think. Cockpit w/ bigger car, bigger clock, and modified 'OFF' button to 'Scheme Changer' NEW redesigned Speedometer w/ phone button on the bottom Splitscreen Splitscreen w/ tripcomputer MapChanger CruiseDial Nav Settings Quote Link to post Share on other sites
ill.die.trying Posted February 19, 2010 Author Report Share Posted February 19, 2010 Well, I hope that you don't mind Julius, but I 'RedBlasted' your mod to suit my 'RedBlast theme'. Tell me what you think. Cockpit NEW redesigned Speedometer Splitscreen Splitscreen w/ tripcomputer MapChanger CruiseDial Nav Settings looks good, Quote Link to post Share on other sites
ill.die.trying Posted February 19, 2010 Author Report Share Posted February 19, 2010 I'm using the Teleatlas maps, I'm going to try the Navteq shortly. The signs where there when I had skin #1. I'm going to try removing the fov=55 value to see if that did it. BUG ALERT, just confirmed that the signboard is not showing up, though the lane info works, i'm going to work on a fix and have it by tomorrow or saturday morning Quote Link to post Share on other sites
figueroaw Posted February 19, 2010 Report Share Posted February 19, 2010 BUG ALERT, just confirmed that the signboard is not showing up, though the lane info works, i'm going to work on a fix and have it by tomorrow or saturday morning Great! ... and I though for a moment that I did something wrong when I put the mod on my unit. ...looking foward for the update. Thank you!!! Quote Link to post Share on other sites
