69sixpackbee Posted February 28, 2011 Report Share Posted February 28, 2011 Last I checked it worked fine. I will try again today on my way home. I think it might be carvers stuff. It must of been a fluke...all is well for now Go figure Quote Link to post Share on other sites
recce93 Posted March 1, 2011 Report Share Posted March 1, 2011 Great mod, install was super simple and up and running in minutes. BOOT TIME has been greatly reduced. I was running your older version (about a year old) and is seemed to boot longer and longer over time. This one is super fast about what i remember when I loaded the older version. How do I keep it booting that fast? Or, what maintenance do I have to do to keep it in top shape? Thanks for all the great work. Quote Link to post Share on other sites
Spursmaddave Posted March 2, 2011 Report Share Posted March 2, 2011 Is it possible to have one of the sub screens as the main Map screen... I would like the split nav screen as the default...  Also if I wanted to try different maps where exactly on the disc should I save them  Thanks  Dave Quote Link to post Share on other sites
ovalball Posted March 3, 2011 Report Share Posted March 3, 2011 Is it possible to have one of the sub screens as the main Map screen... I would like the split nav screen as the default...  Also if I wanted to try different maps where exactly on the disc should I save them  Thanks  Dave  In APL2/IGO/CONTENT you should have a folder called map_nt and also one called map_ta.Put your tele atlas maps in map_ta and your navteq maps in maps_nt. Quote Link to post Share on other sites
palexr Posted March 3, 2011 Report Share Posted March 3, 2011 Will this work on v4 software? Sorry for the noob question. Quote Link to post Share on other sites
SeattleTT Posted March 3, 2011 Report Share Posted March 3, 2011 I need to look at the ext progs interface. I think the scripts have some issues. I have noticed as well that things don't seem to execute correctly. Â EDIT FOR CORRECT INFO: You need to use the start application command and put it in the st_start script in start.ui. That will run it each time the unit starts. Â Like this: Â run 'START_APPLICATION "\My Flash Disk\System\autorun.exe" ""' Â Diaftia, thanks for the info - I put it in start.ui and it works great! I also added a button on the map to pull up the program anytime needed. Â Is there a command to "activate" a running program to bring an existing window to the front? Also, is there a ref for this script language somewhere? Quote Link to post Share on other sites
palexr Posted March 4, 2011 Report Share Posted March 4, 2011 Will this work on v4 software? Sorry for the noob question. I can answer that - Yes it does, and very nice it is too. Thanks Diafta. Quote Link to post Share on other sites
Dozer.hh Posted March 4, 2011 Report Share Posted March 4, 2011 Will this work on v4 software? Sorry for the noob question. Â v4?? Did I miss something?? Quote Link to post Share on other sites
palexr Posted March 4, 2011 Report Share Posted March 4, 2011 v4?? Did I miss something?? The latest update takes the software to 4.0. I don't think it changes anything functionality wise from 3, but I don't really know as I upgraded the unit immediately. I think it is just new maps. Quote Link to post Share on other sites
muRte Posted March 4, 2011 Report Share Posted March 4, 2011 Diaftia, could you please give me the arrow file that should be in 3D mode instead of the 3d car that I have (from other mod)? Thank you! Quote Link to post Share on other sites
Dozer.hh Posted March 5, 2011 Report Share Posted March 5, 2011 The latest update takes the software to 4.0. I don't think it changes anything functionality wise from 3, but I don't really know as I upgraded the unit immediately. I think it is just new maps. We don't have that update in germany!? Last official one is 3.020200 from 03-12-2009. Can you upload it here, please? Quote Link to post Share on other sites
Segler1963 Posted March 5, 2011 Report Share Posted March 5, 2011 We don't have that update in germany!? Last official one is 3.020200 from 03-12-2009. Can you upload it here, please?  Be careful, as you know the devices are different from region to region. Never change a running system  Jörg Quote Link to post Share on other sites
Chuck88 Posted March 5, 2011 Report Share Posted March 5, 2011 We don't have that update in germany!? Last official one is 3.020200 from 03-12-2009. Can you upload it here, please? Â You already got the latest FW for Europe! Â As far as I know, there is no such thing as FW 4.0 at this moment. The V4.0 that you see is only for applications in the ALP folder. Quote Link to post Share on other sites
Dozer.hh Posted March 5, 2011 Report Share Posted March 5, 2011 Ok, I guess you are right, guys!! Quote Link to post Share on other sites
Yazon Posted March 6, 2011 Report Share Posted March 6, 2011 Tried to install this mod on a fully updated F500BT that runs Pioneer's release without issues - and after loading the mod the system will not boot - says not enough memory. Quote Link to post Share on other sites
