fraalan Posted September 30, 2009 Report Share Posted September 30, 2009 edited, dumb question needed to be deleted. Quote Link to post Share on other sites
CaptainInsaneO Posted September 30, 2009 Report Share Posted September 30, 2009 You could, but garrettoomey has put together a great guide on how to retain your music if your drive was already unlocked. If you are using the stock drive and have to unlock, you will lose all data on the drive unless you use the unlocking service which, last time I checked, was about 45 bucks. If you unlock it yourself, you will lose all your data. The guide is around here somewhere, I'm working on some stuff or else I'd go find you a link but I know it's not hard to find. Quote Link to post Share on other sites
fraalan Posted September 30, 2009 Report Share Posted September 30, 2009 thanks, drive is already unlocked from last time. hmmm $45 or burn 40+ cds again...... Quote Link to post Share on other sites
garrettoomey Posted September 30, 2009 Report Share Posted September 30, 2009 thanks, drive is already unlocked from last time. hmmm $45 or burn 40+ cds again...... If the drive is already unlocked, then you don't have to spend anything. Just restore the LDAT and SDAT partitions from the image and you music, addressbook, etc will still be intact. Quote Link to post Share on other sites
CaptainInsaneO Posted September 30, 2009 Report Share Posted September 30, 2009 If the drive is already unlocked from last time then you're in luck. All you need to do is follow garrettoomey's guide and replace the map partitions. You can leave the partitions with all your user data (music, contacts, etc) alone. Quote Link to post Share on other sites
sir Posted October 1, 2009 Report Share Posted October 1, 2009 I remember that when we did the Z1 to Z2/3 upgrade we had to copy or override some files under SDATA folder to bypass the unit. Is that necessary again now with the new 2009 img ? Thanks Quote Link to post Share on other sites
G35 Mass Posted October 1, 2009 Report Share Posted October 1, 2009 Which bypass do you have? I have a Z2 upgraded w/ Garrets Z3 drive and had the two wire bypass. After the update, that bypass was still effective. I did not have to copy any individual files. Quote Link to post Share on other sites
sir Posted October 1, 2009 Report Share Posted October 1, 2009 Which bypass do you have? I have a Z2 upgraded w/ Garrets Z3 drive and had the two wire bypass. After the update, that bypass was still effective. I did not have to copy any individual files. I have the 2 wires bypass and imaged the hd with the img posted on the forum at that time. The 2009 img posted on torrent is the same with the one posted on rapidshare right? Thx. Quote Link to post Share on other sites
garrettoomey Posted October 1, 2009 Report Share Posted October 1, 2009 Which bypass do you have? I have a Z2 upgraded w/ Garrets Z3 drive and had the two wire bypass. After the update, that bypass was still effective. I did not have to copy any individual files. I have the 2 wires bypass and imaged the hd with the img posted on the forum at that time. The 2009 img posted on torrent is the same with the one posted on rapidshare right? Thx. Yes, it is the same, just repackaged with rar. Quote Link to post Share on other sites
sir Posted October 1, 2009 Report Share Posted October 1, 2009 Which bypass do you have? I have a Z2 upgraded w/ Garrets Z3 drive and had the two wire bypass. After the update, that bypass was still effective. I did not have to copy any individual files. I have the 2 wires bypass and imaged the hd with the img posted on the forum at that time. The 2009 img posted on torrent is the same with the one posted on rapidshare right? Thx. Yes, it is the same, just repackaged with rar. Thx and Thx again. Quote Link to post Share on other sites
Yacdogg Posted October 3, 2009 Report Share Posted October 3, 2009 Mine just got done downloading over night, will be seeding for a while, can't wait ! ! ! !, btw, I am using my usb to ide to update it, I won't need a password, correct ? btw I have a 60GB drive from garrett. Quote Link to post Share on other sites
garrettoomey Posted October 3, 2009 Report Share Posted October 3, 2009 Mine just got done downloading over night, will be seeding for a while, can't wait ! ! ! !, btw, I am using my usb to ide to update it, I won't need a password, correct ? btw I have a 60GB drive from garrett. No, you will not need a password. Your drive is already permenantly unlocked. Quote Link to post Share on other sites
fireman603 Posted October 3, 2009 Report Share Posted October 3, 2009 I know this is kind of a silly question and I am pretty sure I know the answer already, but I would like for someone to confirm. When restoring just the LDATA and SDATA partitions Acronis asks you which is the primary, active, or logical. I made the LDAT the primary and the SDATA logical. I chose not to assign a drive letter as I assume the avic unit will assign it. Thanks for your help in advance. fireman603 Quote Link to post Share on other sites
loy Posted October 4, 2009 Report Share Posted October 4, 2009 Anyone want this upped on newsgroups? Quote Link to post Share on other sites
garrettoomey Posted October 4, 2009 Report Share Posted October 4, 2009 I know this is kind of a silly question and I am pretty sure I know the answer already, but I would like for someone to confirm. When restoring just the LDATA and SDATA partitions Acronis asks you which is the primary, active, or logical. I made the LDAT the primary and the SDATA logical. I chose not to assign a drive letter as I assume the avic unit will assign it. Thanks for your help in advance. fireman603 LDAT can be ACTIVE/PRIMARY (or just Primary works) and SDAT will be PRIMARY Quote Link to post Share on other sites
