AVIC Z1/Z2/Z3 Upgrade to AVIC Z3 w/2009 Maps
I'm a Comp Sci person so don't tell me this is too complex for me to do ;)
but here is my problem, has anyone did this on a dell system before? All the systems I have are Dell and they all require cable select mode! none work with master/slave you have 2 choices in the BIOS setup for the hard drive controller... OFF or Auto Cable Select... I tried the drive as master on its secondary IDE channel but it didn't detect it at all.. thought wierd... so tried the systems main hard drive in master mode and it wouldn't detect it either... only in Cable select mode would it ever work... so rejumpered the main HDD to CS and went online to look up this toshiba automotive drive's jumper settings... found how to switch it to CS mode... but still doesnt work! not sure if this drive has different jumpers or not... couldnt find specific jumper settings for it only "older models" jumper settings for notebook drives and "newer model" jumper settings... tried them both.. none worked... put it back in my AVIC-Z2 and drive works... so its not the drive itself... kinda think it's dell's IDE controller being stupid with the required cable select mode... so I ordered today a PCI IDE controller for my newer SATA only system to try on there... hopefully this IDE card has master/slave mode and works! if not might be my 2.5 to 3.5 inch IDE adapter thats bad... just bought it though... for a whole $3... IDE card was a whole $9 so, so far not too far money wise into this... anyone else every have this problem with a dell system doing this? i only have one dell system with IDE to test this on the other 2 have SATA only...
I have a Dell too. All I have to do is to plug the drive to an IDE cable by itself and it works. Of cource you have to change the settings in the BIOS.
  • Replies 534
I have a Dell too. All I have to do is to plug the drive to an IDE cable by itself and it works. Of cource you have to change the settings in the BIOS.[/quote
Not that easy on this dell... the dell does not recognize Master/Slave at all... only cable select... which I think is BS... but according to Dell's manual for the comp, the only drives it will recognize are ones set to cableselect mode and after testing it, it's true... what model do you have? The only BIOS settings I have are Off and CableSelect for the type of drive... my comps before that one (which i dont have anymore) had Off Master/Slave and CableSelect
Is it just me or is the voice recognition better on the Z3 firmware? I really feel like it's better, I don't have to spend half an hour saying "AV Operation" now. "Bitchin' Betty", so coined by my gf because of her constant nagging, has not missed a voice command yet, including album titles.
And I'm definitely not a mumbler.
I'm not sure if I'm posting in the right place but let me get to the point.
I am about to purchase a Z-Series AVIC unit, and it seems like I can get a Z2 for under $900 new and just upgrade to a Z3 unit. Fantastic.
Now, a little background info. I am desktop support specialist for a living, so this is definitely very simple for me. I already have all the software I need (we use much of it at work :) ). Anyhow...my questions are as follows:
  • I want to improve the speed as much as possible...do I just need to purchase a 3.5" 7200RPM drive (ATA100/133) or do I need to purchase a laptop (2.5") drive? I assume the RPM speed of the original drive is what can be upgraded to result in a faster overall unit?
  • What are these rebooting issues people are having?
  • Any particular hard drive you guys recommend?
  • To rip MP3's onto the hard drive...will it read a DVD Data Disc with all of my MP3's on it? Or do I need to burn 20 at time onto an 'audio cd"?
  • Is the Z3 image already hacked with all the latest bypasses, etc.?
Thanks for any and all help everyone. I appreciate it.
I downloaded the ginormous Z3 image via BitTorrent and did the procedures as listed here in this thread and in the Z3 drive image thread. Now my Z2 is a Z3! the only downside I see is that it appears to take a bit longer to boot up once you start the car. But hey not that big a deal considering what I paid for the upgrade. :wink:
many thanks to Hyperite, AFMagnum, garrettoomey, and everyone else who's contributed to all the R&D!
I'll keep seeding the image for as long as I can, I think I can probably hold onto it through July.
-Matt
Okay I have bee trying to figure this out for two days now..Someone please help me. I have my drive hooked up to my computer and the unlock software will not unlock it. The magic boot will run but if I enter y to turn off the security it will run the checksum then gives me and device error. if I enter n for the security it will run the checksum then done. Also afte the eid prompt it give the drive info but it says my smart is disabled and my security high is on instead of enabled and off as was stated in the write up given in the post. I need help bad as I said before the drive has been out for two days now and I am going stir crazy........Thanks in advance
It sounds like you may be trying to turn the security off without unlocking the drive first... This is a 2 step process. 1. unlock the drive 2. turn security off with mhdd.
Do you have any more drives? If so how much and what's your approximate delivery time to maryland 20707.
