Toxit Posted March 5, 2009 Report Share Posted March 5, 2009 Guys, I have finally found the solution to hide the custom simulation/flyover buttons when the simulation/flyover finishes without pressing the stop button. There are three scripts that need to hide the simulation/flyover buttons: In start.ui: In setting.ui: state after simulation end In advmenu.ui: state after flyover end In "start.ui" file, place the code to hide the buttons under the "btnNMB_Cursor.y 210" line in "sc_ShowTopMenu" script. In "setting.ui" file. place the code to hide the buttons under the "headericon.bmp "746_32K_MN-783_32b.bmp"" line in "st_navisettings" state. In "advmenu.ui" file, place the code to hide the buttons under the "headericon.bmp "746_32K_MN-781_32b.bmp"" line in "st_AdvRouteMenu" state. Example code for "setting.ui" file: Quote Link to post Share on other sites
BorisM Posted March 5, 2009 Author Report Share Posted March 5, 2009 Great! Quote Link to post Share on other sites
ill.die.trying Posted March 5, 2009 Report Share Posted March 5, 2009 could you post those three files, Quote Link to post Share on other sites
ill.die.trying Posted March 5, 2009 Report Share Posted March 5, 2009 tried it and it did not work for me, i can't get past the startup message,anyone else tried it? Quote Link to post Share on other sites
Toxit Posted March 5, 2009 Report Share Posted March 5, 2009 You need to make sure that u use the same button names as you have used in "navigatemap.ui". I have included all my script files so that you can compare them with yours. It works on my unit. When simulation or flyover finishes, al the buttons get hidden. Also when you press the menu key during simulation or flyover, the simulation or flyover stops and the buttons get hidden. ui_pioneer.rar Quote Link to post Share on other sites
ill.die.trying Posted March 5, 2009 Report Share Posted March 5, 2009 so tell me if i get it right, i only have the faster.slower button, so does that mean that i only have to put btnNMB_Faster.Hide btnNMB_Slower.Hide on the three files? Quote Link to post Share on other sites
BorisM Posted March 5, 2009 Author Report Share Posted March 5, 2009 so tell me if i get it right, i only have the faster.slower button, so does that mean that i only have to put btnNMB_Faster.Hide btnNMB_Slower.Hide on the three files? Yes... if you try to hide a button that does not exist, it will throw an error and quit (probably rebooting the unit)... Quote Link to post Share on other sites
Toxit Posted March 5, 2009 Report Share Posted March 5, 2009 I think that would be your problem. I think that when the unit boots, the sc_ShowTopMenu script in the start.ui file gets executed. If you refer to undefined objects in your scripts, the unit hangs or gives an unknown object error message. If you have only those two buttons defined, you should only use those buttons in the code. To be sure, you should check if those buttons are named exactly like that in your navigate_800_480.ui file. Otherwise you will still be referring to undefined buttons. You can check my files in my previous post to see what I mean or you can try them all on your unit first to verify that they work if you're still not sure. Quote Link to post Share on other sites
ill.die.trying Posted March 6, 2009 Report Share Posted March 6, 2009 damn, still can't get it to work, Quote Link to post Share on other sites
ill.die.trying Posted March 6, 2009 Report Share Posted March 6, 2009 finally, had to go through all the ui files, here's what i got, no route route active simulate buttons thank for all the help Quote Link to post Share on other sites
FourG Posted March 6, 2009 Report Share Posted March 6, 2009 Mind posting your data.zip somewhere? Quote Link to post Share on other sites
ill.die.trying Posted March 6, 2009 Report Share Posted March 6, 2009 here's my data.zip if anyones interested http://rapidshare.com/files/206168761/DATA.zip.html Quote Link to post Share on other sites
dumpystig Posted March 8, 2009 Report Share Posted March 8, 2009 Toxit, Your modded speed warning/route info box is great, thanks for the details. I'm now looking at your route simulation mod, but need your buttons: Pause.bmp#3 Resume.bmp#3 I've had no luck finding them, what folder are they in? And any chance of some pics of the simulation screen? Thanks Quote Link to post Share on other sites
imBasketCase Posted March 8, 2009 Report Share Posted March 8, 2009 i rather like that... good job man Quote Link to post Share on other sites
imBasketCase Posted March 8, 2009 Report Share Posted March 8, 2009 ill.die.trying PostPosted: Fri Mar 06, 2009 8:45 pm Post subject: here's my data.zip if anyones interested http://rapidshare.com/files/206168761/DATA.zip.html this crashes me when i try to open my gps... anyone else have this problem? am i missing something besides just the data.zip like fonts or something? Quote Link to post Share on other sites
