MyITGuy Posted January 28, 2010 Report Share Posted January 28, 2010 If not where can i find the files to restore my unit to 2.0 with working bluetooth Backup files can be found on the SD card you used to create them Third sentence from the OP Please make sure you have a back-up copy of your unit before you start. With this way below you will lose everything on your radio, Settings, Address, Radio Station..... ETC. You get the point. Anyhow, have you tried updating the Bluetooth Firmware found on the Pioneer page: http://www.pioneerelectronics.com/PUSA/ ... 00BT?tab=F Quote Link to post Share on other sites
Major_Malfunction Posted January 28, 2010 Report Share Posted January 28, 2010 Actually got it all working at last Heres what i did downloaded the F700BT restore files from the ftp site Did a restore per instructions i found Then re ran the 3.0 install and WHAM everything worked I know my bad for not making a backup of my original files MM Quote Link to post Share on other sites
jootz Posted January 28, 2010 Report Share Posted January 28, 2010 can someone please explain how to create backup files for your unit? Quote Link to post Share on other sites
flatman Posted January 29, 2010 Report Share Posted January 29, 2010 Ok so here's my dilema, I've upgraded everything I need too with some help from SootyLad on this forum... He's using a 710BT and the updates and UK work fine on his unit. I have taken an exact copy of his install and mods etc, however on my unit, my GPS can see 6 satellites, but they're red, and the when I click the map button, the map is pitch black. It seems the GPS is failing to locate me and change the map etc? Anyone got any ideas? Quote Link to post Share on other sites
eGo Posted January 30, 2010 Report Share Posted January 30, 2010 can someone please explain how to create backup files for your unit? I'm going to second this one.. I did a search but didn't come up with much.. I may be hacking my X910BT this weekend and would like to know how to back it up before I get started.. TIA! eGo Quote Link to post Share on other sites
crilleym Posted January 30, 2010 Report Share Posted January 30, 2010 can someone please explain how to create backup files for your unit? I'm going to second this one.. I did a search but didn't come up with much.. I may be hacking my X910BT this weekend and would like to know how to back it up before I get started.. TIA! eGo First post in this thread tells you how. Use testmode provided there and copy your entire myflashdisk Quote Link to post Share on other sites
sajin Posted February 3, 2010 Report Share Posted February 3, 2010 this worked like a charm on my f900bt with a single 8 gig sd card. i've noticed one problem though, i have no street names in 3d mode on the gps. I do have them in 2d and static north modes. just not in 3d.. anyone else have this problem? Quote Link to post Share on other sites
sajin Posted February 5, 2010 Report Share Posted February 5, 2010 bump... or solution? Quote Link to post Share on other sites
Roland Posted February 11, 2010 Report Share Posted February 11, 2010 When I go to system info to see what versions I have, I see something that says 2.000000ect How do I know that I have the latest maps and system files? Can someone share the numbers or a screen shot? x910BT Quote Link to post Share on other sites
Woods-Rider Posted February 12, 2010 Report Share Posted February 12, 2010 I did the install with the files from megaupload that were linked on a previous page. The install worked but the "system startup" window does not dissappear. I can still use the unit and have verified that it is now version 3.0. How do I get the startup window to go away? I know I probably need to reinstall 3.0, but what do I need to do differently? I have tried it 3 times with the same result. Quote Link to post Share on other sites
tdrood Posted February 24, 2010 Report Share Posted February 24, 2010 I also just noticed i have no working voice commands When i press the large button in map mode i hear the normal beep but the voice command screen doesnt come up Oddly, I am having the exact same issue and thought it worth posting here. I did the upgrade to 3, then 3.0.1 and all seemed to be fine, but the voice command button does not do anything; as I said, however, everything else seems to be working fine. I am planning to restore and re-install and will report back my findings. I would like to sincerely thank everyone on this forum for all of the amazing work! Ok, so the plot thickens: I restored back to 2.06 - or tried to anyway. When I restored the old files, the unit then refused to get past the system startup screen. Since there was nothing else I could do, I reinstalled 3.0 but did not do the 3.01 update and, viola, it works. Should I bother to try to do the 3.01 update or just leave well enough alone. In other words, is it worth my time to try that upgrade and risk having to go back and un/re-do it? Thanks again to all of you on this forum, for everything you have done and continue to do! Oh, and by the way, I have an F700bt. Quote Link to post Share on other sites
knorrr Posted March 5, 2010 Report Share Posted March 5, 2010 Hello, I am new and from Holland (that is the reason for my bad English ). The F900BT Europ is built in in my mobil home (camper) and is connected to a camera (rear-view) and TV. I have try to day my European F900Bt upgrade to 3.0xxxx so I have reed in this item. The firmware was 2.9 and CE give 5.0 But after "upgrading"start my 900 only with the pioneer screen and do not anything more/else?!?! After a few minutes he restart automatic. I can put a CD in it and that is playing but you can stop and eject don't work!! I have try to do al steps again but nothing Have anyone a idea what I can do?? I have also see there ar USA maps loaded ?!?! Please help me. Ron ============================ one day later!! The problem is bigger I am afraid When I start up the system with the reset (reset, eject,map,menu) he coming with the blue choice menu After a few seconds he reset (??) himself and come back with only a black screen. When I am fast I can make the chose update CE and Update SD format. He starts but by 47% (+/_) he give the black screen. I have format the SD card and use also a another one. Nothing helps !?!? Please help me. Ron ======================================== Update. I am a very little bit happy He starts up. Coming with "Top menu" and then "System start-up in progress. Please wait" If I will I can use the radio BUT after a few minits he restart automatic. I can not see check the configuration. I have the "ping" but he did't open. Maybe are the reason from the US maps??? The problem for update CE en than stop after a few second and go black is also still there. Please help me. Greetings and regards Ron =============================== 8mrt2010 He is working !!!! http://avic411.com/forum/viewtopic.php?f=34&t=29761 Only the updute winCE I don't have try. But hy is working now. Now I have looking for the Europ cards 2009/2010 Thinks to this forum. Quote Link to post Share on other sites
eak Posted March 8, 2010 Report Share Posted March 8, 2010 I really am trying to use search. Search finds noting with "3.01". Is there a 3.01 Install HOWTO with the firmware download somewhere? I also keep seeing both "3.01" and 3.1" and apparently 3.02 just came out, so my assumption is that everyone talking about "3.1" really means "3.01"? Could someone please confirm? Thank you! Quote Link to post Share on other sites
Oldsmokey Posted March 10, 2010 Report Share Posted March 10, 2010 Does anyone have a different place to get 3.0. The link in page one doesnt work any more. Thanks Quote Link to post Share on other sites
MyITGuy Posted March 11, 2010 Report Share Posted March 11, 2010 Does anyone have a different place to get 3.0. The link in page one doesnt work any more. Thanks Might want to try reading through the rest of the thread then...new links are in there somewhere =D I spent days looking for these files to upgrade my unit, yet people can't spend a few minutes to read through the rest of a thread? Quote Link to post Share on other sites
