DonMac21 Posted September 25, 2009 Report Share Posted September 25, 2009 Great Job and thanks for posting. Just woundering where the speed.bmp , your_speed.bmp and elevation.bmp are located now in your data.zip file. I would like to modify them. Thanks again Quote Link to post Share on other sites
diaftia Posted September 25, 2009 Author Report Share Posted September 25, 2009 Great Job and thanks for posting. Just woundering where the speed.bmp , your_speed.bmp and elevation.bmp are located now in your data.zip file. I would like to modify them. Thanks again in the 480_800 directory. Gonna make them bigger? Take a picture of what you come up with if you can. Quote Link to post Share on other sites
Geoff Posted September 25, 2009 Report Share Posted September 25, 2009 I know it's probably a stupid question, but what files do I need to copy to update from the previous 9/15 release in order to move up? Thanks again! Quote Link to post Share on other sites
diesel power Posted September 25, 2009 Report Share Posted September 25, 2009 Hi, I just changed to this release and so far i really like it with one exception. i miss the small icons that appeared when you tapped the transparent drop-down arrow on the upper-left side of the map. the larger buttons aren't as functional for me. the trip computer works and the colors look much better. is it possible to just change the menu items back is what they point to different as well? thanks again. oh and i've turned off the speedcam verbal announc and the beep and so far i haven't had any further reboots. Thank you again Diaftia!!! Quote Link to post Share on other sites
diaftia Posted September 25, 2009 Author Report Share Posted September 25, 2009 I know it's probably a stupid question, but what files do I need to copy to update from the previous 9/15 release in order to move up? Thanks again! Copy the data.zip and the scheme files and you should be set. Quote Link to post Share on other sites
diaftia Posted September 25, 2009 Author Report Share Posted September 25, 2009 Hi, I just changed to this release and so far i really like it with one exception. i miss the small icons that appeared when you tapped the transparent drop-down arrow on the upper-left side of the map. the larger buttons aren't as functional for me. the trip computer works and the colors look much better. is it possible to just change the menu items back is what they point to different as well? thanks again. oh and i've turned off the speedcam verbal announc and the beep and so far i haven't had any further reboots. Thank you again Diaftia!!! Hmmmm, there were a lot of changes to the navigatemap800 file including all the supported images. You are probably just better off running the older version unless you want to reverse engineer it. It could be done but might take some time to remove all the old images and gather the new ones. The all start with "k_but_" IMO I was not too keen on the new system either but it really does grow on you since it is a ton easier to use. Give it a shot and I guarantee you that you wont miss all the fingertip nail presses after a day or two. I am working on the speedcam stuff now. Its a PITA. Quote Link to post Share on other sites
ill.die.trying Posted September 25, 2009 Report Share Posted September 25, 2009 I am working on the speedcam stuff now. Its a PITA. +1, i already changed a whole buch of stuff on mine, already got the mph working flawlessly but whenever i have set on kph it just reboots, Quote Link to post Share on other sites
diaftia Posted September 25, 2009 Author Report Share Posted September 25, 2009 I am working on the speedcam stuff now. Its a PITA. +1, i already changed a whole buch of stuff on mine, already got the mph working flawlessly but whenever i have set on kph it just reboots, DOH! I hate that. Crap like that can be as bad as having a hidden formating problem. Comma out of place etc. I think the only other error I hate just as much is the /layer expected error. I have had to start the mods I was working on all over and just start adding things in a basic manner because of that damn error. Look forward to seeing the MPH fix! It will be nice for the posted speedcam speed not be 58mph. Quote Link to post Share on other sites
vicdic Posted September 25, 2009 Report Share Posted September 25, 2009 Hi all, hi diaftia, I love this mode is a great work. What I must change for the show sky:"If you want to show sky in the 3D map mode then edit out the semicolons in the [map] section of the sys.txt file before copying over to the AVIC." [map] 3d_roads=1 3d_tunnels=1 3d_max_tiltlevel=8300 3d_min_tiltlevel=0 3dcarsizemin=1700 3dcarsizemax=3400 2dheadup=1 zoomfactor=110 ...please help, thanks, sorry for my bad english I am from Italy Quote Link to post Share on other sites
diaftia Posted September 25, 2009 Author Report Share Posted September 25, 2009 Hi all, hi diaftia, I love this mode is a great work. What I must change for the show sky:"If you want to show sky in the 3D map mode then edit out the semicolons in the [map] section of the sys.txt file before copying over to the AVIC." [map] 3d_roads=1 3d_tunnels=1 3d_max_tiltlevel=8300 3d_min_tiltlevel=0 3dcarsizemin=1700 3dcarsizemax=3400 2dheadup=1 zoomfactor=110 ...please help, thanks, sorry for my bad english I am from Italy Try using these settings: 3d_max_tiltlevel=8800 3d_max_zoomlevel=1500 (replace the max_tiltlevel and add the max_zoomlevel.) Quote Link to post Share on other sites
N-S-E-W Posted September 26, 2009 Report Share Posted September 26, 2009 9/24/09:Big changes are: 1. Keepers new redesigned menu system for easier icon touching.2. New landing page when doing multiroute with option to view on map. You can do the standard press of the multiroute button or a long press to go directly to the map.3. Changed all the keeper icon text to be a bit more centered.4. Added elevation to the bottom of the speedometer screen.5. Removed current destination and added next turn in yellow to the top of the speedo screen.6. Changed the destination dial screen to match the background of the speedo to keep the file size down.7. Pressing the current speed sign takes you to the speedo while long pressing takes you to the destination dial screen.8. Added in new default schemes so that the direction colors on the multiroute page come up in their respective color.9. General house cleaning of old files to keep things small.10. Added snap back to car button when in flyover mode so you now no longer have to restart the flyover if you touch the map.11. "Keep Position On Road" option added to route settings.12. Stanislavovich trip computer added to hopefully make tripcomp work more consistently.13. Fixed bug where animated cursor did not work in night mode. There are updated scheme files in this mod pack. This will allow multiroute to function correctly and color code the routes in the multiroute function while on the map. I have also removed the commonlib.dll file as I think its a bit buggy and causing some people reboots. Nice job, that's a lot of stuff you have going on there. Quote Link to post Share on other sites
Geoff Posted September 26, 2009 Report Share Posted September 26, 2009 Which are the "scheme" files that need to be copied over? I've done data.zip a few times. Sorry for the n00bish questions. Thanks. Quote Link to post Share on other sites
diaftia Posted September 26, 2009 Author Report Share Posted September 26, 2009 Which are the "scheme" files that need to be copied over? I've done data.zip a few times. Sorry for the n00bish questions. Thanks. If all else fails the directions are in the word doc that is in the main zip. That should help guide you in a pinch. But the schemes get copied to the APL2/iGo/Content/Scheme folder. They are in the rar file that you download in the "Copy and Paste in APL2-iGo-Content-SCHEME" folder. You are looking for 4 files that are named the same. You are going to overwrite them. Let me know if you get stuck. Quote Link to post Share on other sites
Pioneer4x4 Posted September 26, 2009 Report Share Posted September 26, 2009 I just installed these mods on my F90BT. It seems to be OK, I haven't moved the car yet to test, I will in a few hours. 2 questions 1) Is there an instruction file/list somewhere that documents all the additional features/changes from stock 3.01? 2) I followed your 20 step instructions and there were well laid out, I did find one inconsistancy. In step 18, you phrase the way of getting to the correct path differently. It was as if you assumed the end user was in \myflashdisk\apl2\igo but I think the last location was \myflashdisk\apl2 so the content folder isn't there. I did not have any problems, I am an IT professional at a Health Care facility and deal with end users daily that use our software, but have no idea on how to user a computer, so I am just trying to make the document a little more user friendly. AND I HOPE I DIDN'T BLOW IT, by misreading your instrucions. If so, I am sorry, and will feel like a dolt... Anyhoo, It looks VERY promising, and I am looking forward to playing with it's features. Also, THANKS! Quote Link to post Share on other sites
diaftia Posted September 26, 2009 Author Report Share Posted September 26, 2009 I just installed these mods on my F90BT. It seems to be OK, I haven't moved the car yet to test, I will in a few hours. 2 questions 1) Is there an instruction file/list somewhere that documents all the additional features/changes from stock 3.01? 2) I followed your 20 step instructions and there were well laid out, I did find one inconsistancy. In step 18, you phrase the way of getting to the correct path differently. It was as if you assumed the end user was in \myflashdisk\apl2\igo but I think the last location was \myflashdisk\apl2 so the content folder isn't there. I did not have any problems, I am an IT professional at a Health Care facility and deal with end users daily that use our software, but have no idea on how to user a computer, so I am just trying to make the document a little more user friendly. AND I HOPE I DIDN'T BLOW IT, by misreading your instrucions. If so, I am sorry, and will feel like a dolt... Anyhoo, It looks VERY promising, and I am looking forward to playing with it's features. Also, THANKS! Thanks I will go and update the document. I try to make it right but getting feedback like yours for it is invaluable. As far as all the features since the inception are pretty much laid out in the first post of this thread. I start with the instructions but there is pretty much an order by date which features I added. Check that out. Thanks, Alex Quote Link to post Share on other sites
