diaftia Posted March 2, 2010 Author Report Share Posted March 2, 2010 Does anyone have trouble with their gps not turning on, after diaftias hybrid mod? and is there a quick fix? Ilove these mods by the way. My gps now has a on/off button now. and my unit seems to think that on is off , and off is on??preciate the help guys.. Someone else had that problem in this thread. Make sure you set your device setting in sys.txt. I am pretty sure that is what the problem was. Quote Link to post Share on other sites
runamuckr Posted March 2, 2010 Report Share Posted March 2, 2010 FABULOUS!! Diaftia, this mod is awsome, thanks for the hard work, and continued development on this. I've been running this mod for about a week and love it! This is the first major mod I've installed on my x910 and it seems to be working flawlessly. I do however have one small issue. My speed limit signs only seem to work while I'm on the highway. And some are not correct, speed limit has been the same for at least the last five years. I used Garmin mobile XT since its release and speed limit signs worked for ALL roads, also the traffic on the Garmin XT was the most accurate I've seen, MSN is seriously out of date it seems. So my question is....Can I possibly use Garmins speed limit sign data base in this mod? Can speed limit signs, speed cams, red light cams ect be updated??? Where might I find them? Quote Link to post Share on other sites
azrcnut Posted March 3, 2010 Report Share Posted March 3, 2010 Can you please put a step by step on how to do the 3d cars? I tried following idt's but can only modify the sys text Add the following codes below to sys.txt then put the .mdl and .tex file of the car you selected in the "gx" folder of Data.zip. Make sure 3dcars is in the Igo folder. [map] 3d_scale_carmodel=1 3dcarsizemin=5000 3dcarsizemax=8000 3dcarsizemul=30000 [3d] ;change the .mdl file to the car you selected car_day=flying_carpet.mdl car_night=flying_carpet.mdl ghost_day=flying_carpet.mdl ghost_night=flying_carpet.mdl [3dcar] work_dir="\My Flash Disk\APL2\iGo\3DCars" location of 3dCars folder mortscript="\My Flash Disk\APL2\iGo\3DCars\Themechanger\MortScript.exe" ;location of MortScript.exe Ok.. I did this word for word all my files are in place...I am pretty sure my sys,txt is in order....it is attached if maybe someone look at it and let me know.. It just stays on system start screen not splash...and if I put back the the stock mod sys.txt...it works fine SYS.TXT Quote Link to post Share on other sites
69sixpackbee Posted March 3, 2010 Report Share Posted March 3, 2010 Remove the colon from the front of this: :[rawdisplay] screen_x=800 screen_y=480 class="landscape" highres=0 dpi=250 and make it look like this: [rawdisplay] screen_x=800 screen_y=480 class="landscape" highres=0 dpi=250 That'll do it ..Bud Quote Link to post Share on other sites
diaftia Posted March 3, 2010 Author Report Share Posted March 3, 2010 FABULOUS!! Diaftia, this mod is awsome, thanks for the hard work, and continued development on this. I've been running this mod for about a week and love it! This is the first major mod I've installed on my x910 and it seems to be working flawlessly. I do however have one small issue. My speed limit signs only seem to work while I'm on the highway. And some are not correct, speed limit has been the same for at least the last five years. I used Garmin mobile XT since its release and speed limit signs worked for ALL roads, also the traffic on the Garmin XT was the most accurate I've seen, MSN is seriously out of date it seems. So my question is....Can I possibly use Garmins speed limit sign data base in this mod? Can speed limit signs, speed cams, red light cams ect be updated??? Where might I find them? Its actually a byproduct of the map data. My mod is set to poll when the map data presents the speed limit. That is why mostly the highways have it. You can try a updated map version or use the other map brand and see if its better in your area. Even in my area (Silicon Valley, CA) its mostly on highways with some major back streets. I have a feeling your Garmin used different maps than these units do. Quote Link to post Share on other sites
runamuckr Posted March 3, 2010 Report Share Posted March 3, 2010 Thanks, I kind got that impression as I browsed the net about this. So is it safe to assume that I can change the map data and your mod's will remain "uneffected"?? Speed cams and buildings are map specific as well? Branded POI's are NOT map specific? (some are opaque and some aren't) whats your take on this, and can it be corrected? Quote Link to post Share on other sites
Dragonrep Posted March 4, 2010 Report Share Posted March 4, 2010 I just loaded the mod on an F700BT with the 3.02 U.S. update, works great!! I love the new options and accessibility. Quote Link to post Share on other sites
bsqr Posted March 4, 2010 Report Share Posted March 4, 2010 I've installed the mod and all seems to function quite well. I've got a couple of questions though. Any thoughts about creating a shortcut to view the destination name/address while enroute? Well at least I haven't been able to find a way to access this info. I've got the left/right announcement working, but I have a difficult time remembering the address number upon arrival. A one button shortcut would be useful. Also, I have a ding-dong type of "warning" tone that comes on occasionally that I can't figure out what it is. I have the Speed Cam warning set to the custom audible setting, but also have the visual warning set to on and yet I don't get any visual warning accompanying the ding-dong so it shouldn't be a speed cam. Any ideas what this tone is trying to tell me?? Quote Link to post Share on other sites
ovalball Posted March 4, 2010 Report Share Posted March 4, 2010 I've installed the mod and all seems to function quite well. I've got a couple of questions though. Any thoughts about creating a shortcut to access the destination name/address while enroute? Well at least I haven't been able to find a way to access this info. Also, I have a ding-dong type of "warning" tone that comes on occasionally that I can't figure out what it is. I have the Speed Cam warning set to the custom audible setting, but also have the visual warning set to on and yet I don't get any visual warning accompanying the ding-dong so it shouldn't be a speed cam. Any ideas what this tone is trying to tell me?? It's probably the lane notification ding dong!Does it occur at the same time as the lane change graphic? Quote Link to post Share on other sites
69sixpackbee Posted March 4, 2010 Report Share Posted March 4, 2010 Mine does it too. It is annoying so I keep the volume muted. It seems to be when you come to an intersection in which case is ALWAYS when I have past it because this thing is never close to being right. The street numbers are always a couple of houses off, it tells you to turn after you have passed the turn and it announces when you arrive at the destination on the wrong side of the street. Other that that the graphics are pretty Quote Link to post Share on other sites
diaftia Posted March 4, 2010 Author Report Share Posted March 4, 2010 I've installed the mod and all seems to function quite well. I've got a couple of questions though. Any thoughts about creating a shortcut to access the destination name/address while enroute? Well at least I haven't been able to find a way to access this info. Also, I have a ding-dong type of "warning" tone that comes on occasionally that I can't figure out what it is. I have the Speed Cam warning set to the custom audible setting, but also have the visual warning set to on and yet I don't get any visual warning accompanying the ding-dong so it shouldn't be a speed cam. Any ideas what this tone is trying to tell me?? It's probably the lane notification ding dong!Does it occur at the same time as the lane change graphic? Exactly.. I believe the exact setting is Lane Guidance. Switch that off. Right now the destination route can be set to display in the settings over next turn name. There is no shortcut only because I have ran out of things to be able to click on! I will check and see what I can do though. Quote Link to post Share on other sites
diaftia Posted March 4, 2010 Author Report Share Posted March 4, 2010 Mine does it too. It is annoying so I keep the volume muted. It seems to be when you come to an intersection in which case is ALWAYS when I have past it because this thing is never close to being right. The street numbers are always a couple of houses off, it tells you to turn after you have passed the turn and it announces when you arrive at the destination on the wrong side of the street. Other that that the graphics are pretty The ding is the lane guidance... the house numbers being off is the map data and GPS which unfortunately I can't do anything about. I have heard that using the NavTeq maps makes it more accurate but then you are stuck with the problems of Navteq maps which I believe is poor POI data. Either way working on a map changer in the next version to be able to toggle between them for those that want it. Quote Link to post Share on other sites
BorisM Posted March 4, 2010 Report Share Posted March 4, 2010 Mine does it too. It is annoying so I keep the volume muted. It seems to be when you come to an intersection in which case is ALWAYS when I have past it because this thing is never close to being right. The street numbers are always a couple of houses off, it tells you to turn after you have passed the turn and it announces when you arrive at the destination on the wrong side of the street. Other that that the graphics are pretty The ding is the lane guidance... the house numbers being off is the map data and GPS which unfortunately I can't do anything about. I have heard that using the NavTeq maps makes it more accurate but then you are stuck with the problems of Navteq maps which I believe is poor POI data. Either way working on a map changer in the next version to be able to toggle between them for those that want it. You can mix and match POI and map providers, though. You can even use several sets of POIs at once. I.e., for IL and neigboring states I use both TeleAtlas and Navteq POIs, which gives a reasonable coverage. Quote Link to post Share on other sites
diaftia Posted March 5, 2010 Author Report Share Posted March 5, 2010 Mine does it too. It is annoying so I keep the volume muted. It seems to be when you come to an intersection in which case is ALWAYS when I have past it because this thing is never close to being right. The street numbers are always a couple of houses off, it tells you to turn after you have passed the turn and it announces when you arrive at the destination on the wrong side of the street. Other that that the graphics are pretty The ding is the lane guidance... the house numbers being off is the map data and GPS which unfortunately I can't do anything about. I have heard that using the NavTeq maps makes it more accurate but then you are stuck with the problems of Navteq maps which I believe is poor POI data. Either way working on a map changer in the next version to be able to toggle between them for those that want it. You can mix and match POI and map providers, though. You can even use several sets of POIs at once. I.e., for IL and neigboring states I use both TeleAtlas and Navteq POIs, which gives a reasonable coverage. Nice! I didnt know that. I will add in the Navteq POI's and see what I get. Thanks Boris. Quote Link to post Share on other sites
N-S-E-W Posted March 5, 2010 Report Share Posted March 5, 2010 You can mix and match POI and map providers, though. You can even use several sets of POIs at once. I.e., for IL and neigboring states I use both TeleAtlas and Navteq POIs, which gives a reasonable coverage. Nice! I didnt know that. I will add in the Navteq POI's and see what I get. Thanks Boris. You can also mix Navteq and Teleatlas maps in the same folder. Unlike the POI files you can't have two of the same state in the map folder. Same goes with map versions, mix and match until you have all the states. Quote Link to post Share on other sites
