Jump to content
AVIC411.com
Diaftia's Hybrid mods V2.3 - UPDATED: 01/14/10
One thing I want to add... if on this "new version" you could make an arrow (up, down, left, right) when searching for POI's so it can tell you in which direction it is :) That would be awesome. As always though... great mod!
Already done.
Cheers
34by151
Link to post
Share on other sites
  • Replies 1.2k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
These mods were tested and made on a US based F90BT running 3.01.   I did a lot of coding on this to make additions and adaptations to what was there but the original mods are done by the following
Posted Images
I tried removing the "zoom=1000" from the code string for the signposts and yet they still show up small. WHat gives?
Also, regardless of the transparency settings, on or off, the freeway signs are still transparent and hardly visible.
Any thoughts?
Been reading here:
viewtopic.php?f=34&t=26901
Maybe this is whee the demons lie...:(
Thanx,
Bud
Link to post
Any thoughts?
Been reading here:
Thanx,
Bud
Bud - Without going through the signpost ini file, try to increase the zoom to 1200. 1000 is essentially 1:1, as you lower the number the bmp shrinks likewise if increase it it'll get larger.
Also you can download the bmp and ini file I did for merton on page 4. Extract the bmp only and replace the one in your unit. This one is more solid.
Good Luck!
Link to post
Alex,
I was wondering about something I mentioned to I.D.T awhile back about looking into finding a way to set current location as "Home" and working it into a future release. Question is; if this was possible would it (the AVIC) still have to enter an incorrect physical address into the "set home address" field or could it be coded to save the longitude & latitude calculations as "Home" or current location and not a physical address at all?
As a way of correcting the maps being off on house numbers
Link to post
Yes, that can be done but I doubt it will make it into the next release. The next release will be V3 due to the number of changes. It will probably be V3.1 before we get to that
Cheers
34by151
Link to post
Cheers
34by151
great news,something to look forward to,
thanks for the info.
Link to post
Cheers
34by151
N-S-E-W wrote:
Or you can add to the sys.txt file:
[poi]
use_multi_poi_icon=0
Can I also edit the sys.txt and change default lat & long to my location as well as default day and night schemes to those of my choosing??
Link to post
Any thoughts?
Been reading here:
http://avic411.com/forum/viewtopic.php?f=34&t=26901
Thanx,
Bud
Good Luck!
Okay,
Now if you can recommend a BMP editor because I cannot open them with either Roxio or Gimp.
Thanx,
Bud
Link to post
Any thoughts?
Been reading here:
Thanx,
Bud
Good Luck!
Okay,
Thanx,
Bud
You don't need a bmp editor to install the bmp. The signboard color is defined in the ini file, which you're to ignore from the download. Don't make this harder than it needs to be!
Link to post
That sounds awesome too... seriously, what are you guys waiting for? JK Beta testers? Count me in hehe.
There has been a lot of coding involved. We are definitely going to need beta testers. There is a lot more coding and image creating that has to happen before its considered a solid build. Once it is we will need at least 2-3 from EU and US. So we will definitely come knocking. :)
Are you having dreams about it every night? I know I did for about a week or so when I was into it heavily.
Its pretty insane. I have. I sometimes have a hard time going to sleep and then when I wake up its in my head. Its really ridiculous. I have not been hitting it too hard lately. 34by151 has been doing a bulk of the coding. He has a really cool development tool that lets him jam this stuff out quickly. Up to the 2.3 release and the dreams got pretty vivid. ;)
Link to post
Any thoughts?
Been reading here:
Thanx,
Bud
Freeway signs are limited in width. Adjust the W= setting and it will make them larger.
Transparency is for the navigation backgrounds not the freeway signs. Working on that put all changes to the signposts require a reboot.
Alex
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
