abb1 Posted July 14, 2010 Author Report Share Posted July 14, 2010 Abb, this is your best work yet. Be interesting how you can top this Thanks, but I already have topped it Here is a taste of what I was talking about, my potential V3.0: AS YOU CAN SEE -- MORE VEHICLE CHOICES! Quote Link to post Share on other sites
n2deep Posted July 14, 2010 Report Share Posted July 14, 2010 That look so beautiful!!! When will it be up. know im having anxieties. Quote Link to post Share on other sites
ovalball Posted July 14, 2010 Report Share Posted July 14, 2010 As always Abb this is a brilliant bit of work.Based on diaftias mod(I think )which has always been my personal favourite.Is this just a tease or are you going to make it available.....PLEASE!!!! Quote Link to post Share on other sites
abb1 Posted July 14, 2010 Author Report Share Posted July 14, 2010 As always Abb this is a brilliant bit of work.Based on diaftias mod(I think )which has always been my personal favourite.Is this just a tease or are you going to make it available.....PLEASE!!!! Well, This mod is much larger than any previous mod and a lot more complicated. I gave it to a tester to see how he would make out with it and he cannot make it work. It does work flawless as I have it installed on two systems, however, the entire contents is aprox. 40mb in sze, so it is a doozy with the DATA.zip being 24mb. It requires 10 files which MUST be loaded. If my tester cannot get it to work, then I will not put it up as I do not want the headaches. This is however, my best work, and I have never been happier with a mod yet! Also, it depends on the feedback and interest that I get as putting up these mods is a LOT of work Quote Link to post Share on other sites
ovalball Posted July 14, 2010 Report Share Posted July 14, 2010 As always Abb this is a brilliant bit of work.Based on diaftias mod(I think )which has always been my personal favourite.Is this just a tease or are you going to make it available.....PLEASE!!!! Well, This mod is much larger than any previous mod and a lot more complicated. I gave it to a tester to see how he would make out with it and he cannot make it work. It does work flawless as I have it installed on two systems, however, the entire contents is aprox. 40mb in sze, so it is a doozy with the DATA.zip being 24mb. It requires 10 files which MUST be loaded. If my tester cannot get it to work, then I will not put it up as I do not want the headaches. This is however, my best work, and I have never been happier with a mod yet! Also, it depends on the feedback and interest that I get as putting up these mods is a LOT of work Fair point Abb.Supplying a mod is one thing but having to follow it up with endless support would be a pain in the ass.If your ever looking for guinea pigs please let me know Quote Link to post Share on other sites
crilleym Posted July 14, 2010 Report Share Posted July 14, 2010 Abb, If you need another tester, I would be willing to try it out. Quote Link to post Share on other sites
Chuck88 Posted July 14, 2010 Report Share Posted July 14, 2010 Wooowwwww!!! You would be insane hiding this piece of art work from the rest of the community! Quote Link to post Share on other sites
abb1 Posted July 14, 2010 Author Report Share Posted July 14, 2010 I will require about two more testers that will test this thoroughly. I have been working on this now for about 7 weeks and the stability is rock solid on my end, but there is a lot that I cannot test such as building visibility, speedcam, signposts, etc., because we dont have them here. I also need to make sure that there are no memory errors as this mod is so huge. I have not encountered any yet, but I want to make sure that this is Rock Solid before releasing it as I do not have time to troubleshoot. If anybody is interested in testing this for me, please PM me. Keep in mind that I will need you to be in constant contact with me as to how it is going because if I have no feedback, then I will not know the results. Quote Link to post Share on other sites
nissanfrontier Posted July 14, 2010 Report Share Posted July 14, 2010 More please!!! I'll test it out if you want. I should be able to get the files as I have deleted a lot of states and such off the maps. Quote Link to post Share on other sites
Chuck88 Posted July 14, 2010 Report Share Posted July 14, 2010 Abb, I tried to install for the first time your V2.75 but iGo doesn't load and complained that ui_pioneer/800_400/loading.bmp was missing. When I dug into the data.zip file, only a file loading.JPG (instead of bmp) is present in that folder. Any clue? I did delete everything is the saved folder. Thanks. Quote Link to post Share on other sites
abb1 Posted July 15, 2010 Author Report Share Posted July 15, 2010 Abb, I tried to install for the first time your V2.75 but iGo doesn't load and complained that ui_pioneer/800_400/loading.bmp was missing. When I dug into the data.zip file, only a file loading.JPG (instead of bmp) is present in that folder. Any clue? I did delete everything is the saved folder. Thanks. Hmmmm...... 55 downloads and this is a first, as my mod NEVER had loading.bmp. It does not require the loading.bmp, however, just open loading.jpg up in photoshop and then save it as loading.bmp (make sure that you have both saved). That should solve your problem Quote Link to post Share on other sites
Chuck88 Posted July 15, 2010 Report Share Posted July 15, 2010 Abb, I tried to install for the first time your V2.75 but iGo doesn't load and complained that ui_pioneer/800_400/loading.bmp was missing. When I dug into the data.zip file, only a file loading.JPG (instead of bmp) is present in that folder. Any clue? I did delete everything is the saved folder. Thanks. Hmmmm...... 55 downloads and this is a first, as my mod NEVER had loading.bmp. It does not require the loading.bmp, however, just open loading.jpg up in photoshop and then save it as loading.bmp (make sure that you have both saved). That should solve your problem Loading.jpg is "Pioneer: Sound Vision Soul" ... I have no idea neither. When replacing the DATA.ZIP with V2.5, it just works fine; and when I open the V2.5 DATA.ZIP, there is only a file called loading.JPG (no BMP). So I am totally lost. I will try your suggestion to add loading.bmp to the archive. Quote Link to post Share on other sites
Hube2002 Posted July 15, 2010 Report Share Posted July 15, 2010 Also, it depends on the feedback and interest that I get as putting up these mods is a LOT of work Abb, what a beautiful piece of work. Everything a person could ask for. All the best features all rolled into one. This will surely surpass all expectations. It is amazing how much your work has progressed. Thanks for sharing. Quote Link to post Share on other sites
69sixpackbee Posted July 15, 2010 Report Share Posted July 15, 2010 What about the GPS load delay that will aid in the tripmeter working every time like those of us who have trouble with this function? I know that it was being discussed as a "workaround" in Diaftia's next iterration. Thanx, Bud Quote Link to post Share on other sites
abb1 Posted July 15, 2010 Author Report Share Posted July 15, 2010 What about the GPS load delay that will aid in the tripmeter working every time like those of us who have trouble with this function? I know that it was being discussed as a "workaround" in Diaftia's next iterration. Thanx, Bud Logically speaking, I don't think that this is possible to speed up the load delay, as this is in general the time that it takes to acquire a signal. The only way that this can be sped up is by changing the GPS chip to one that can acquire more satellites. The AVIC has the Sirfstar III which is the latest technology in GPS hardware.This is something that CAN'T be done through software! Sorry. Quote Link to post Share on other sites
Join the conversation
