urboinoah Posted February 13, 2023 Report Share Posted February 13, 2023 Well I have some good news! I did some testing today and can confirm that the 32gb SD cards work great! I tried a Sandisk Extreme and an Extreme Pro and they both work well. As for the software I tried both the AVIC4500only file and a copy of the OEM SD card. Both seem to actually work really well but the AVIC4500only was version 1.02 of the firmware and the OEM SD card was version 1.06. I don't have steering wheel controls so I couldn't test those unfortunately. The headunit seems faster with the new SD cards and it is also way less buggy. I think my original SD card was pretty full for a while as my headunit got really buggy before totally giving out. Also the original SD card had version 1.00 firmware with no way to update it which is kinda werid. Pioneer really needs to support their products better Quote Link to post Share on other sites
dd36 Posted February 13, 2023 Report Share Posted February 13, 2023 Mine says 1.06 too. Maybe they fixed some of these latent issues in 1.06. It is weird that it's not publicly available. The Ebay card is 1.02. Quote Link to post Share on other sites
jnavic Posted February 14, 2023 Report Share Posted February 14, 2023 I got 1.04 from them. Quote Link to post Share on other sites
dd36 Posted February 14, 2023 Report Share Posted February 14, 2023 On 2/12/2023 at 3:37 PM, jnavic said: OEM will not need device ID reprogramming as it is same for same.  The other images floating around are modified 4400 images, and do need a reprogram (also the 8500 image that works well from @asd255) The Ebay guy claims to have copied an original card. He even calls out the fake cards. Hence it was weird his didn't work with Maestro but OEM replacement did. Quote Link to post Share on other sites
jnavic Posted February 14, 2023 Report Share Posted February 14, 2023 12 minutes ago, dd36 said: The Ebay guy claims to have copied an original card. He even calls out the fake cards. Hence it was weird his didn't work with Maestro but OEM replacement did. Hard to say what's real and what isn't - it's unfortunate, but there are some people trying to recoup their costs, and some trying to just make money. Some you win, some you lose. Quote Link to post Share on other sites
bonee Posted February 14, 2023 Report Share Posted February 14, 2023 Who is the ebay guy? Â Quote Link to post Share on other sites
jnavic Posted February 14, 2023 Report Share Posted February 14, 2023 37 minutes ago, bonee said: Who is the ebay guy? Â You don't know who The Ebay Guy is??? Quote Link to post Share on other sites
dd36 Posted February 15, 2023 Report Share Posted February 15, 2023 16 hours ago, bonee said: Who is the ebay guy? Â Multiple links earlier in the thread. He sells SD cards. Quote Link to post Share on other sites
bassilap Posted February 17, 2023 Report Share Posted February 17, 2023 On 2/11/2023 at 10:21 PM, dd36 said: Also, isn’t the underlying problem that the 16GB card fills up with logs or something? So wouldn’t a 32GB last longer? That was one thought but I don't think that's the case. My 4500 failed and i real-programmed the same SD card (took countless hours to figure out how to even make the card visible in a computer). And then it still had bootloop issues after reprogramming. So I think the flash memory just starts to fail. The other issue, even if it was a storage space issue is that simply putting it into a larger SD card doesn't mean there's more "usable" space available. The partitions from the image (specificially the partition where logs are stored) would need to be enlarged as well. Quote Link to post Share on other sites
bassilap Posted February 17, 2023 Report Share Posted February 17, 2023 On 2/13/2023 at 9:43 PM, jnavic said: I got 1.04 from them. Mine says 1.06. But I purchased from a different seller than the link @DD36 posted.  I'll see if I can get the checksums to compare. Quote Link to post Share on other sites
jnavic Posted February 17, 2023 Report Share Posted February 17, 2023 18 hours ago, bassilap said: Mine says 1.06. But I purchased from a different seller than the link @DD36 posted.  I'll see if I can get the checksums to compare. Supposedly, they are identical (the ones direct from Pioneer) 1.04 and 1.06 Quote Link to post Share on other sites
asd255 Posted February 18, 2023 Report Share Posted February 18, 2023 Pioneer apps are the same in 1.04 and 1.06 Perhaps there are differences in the system libraries. but that would take a lot of time to check. unfortunately there is no change log Quote Link to post Share on other sites
malivip Posted May 29, 2023 Report Share Posted May 29, 2023 On 9/21/2022 at 9:38 AM, MaxL said: Thank you so much @slackwaredragon i was able to recover my AVH-Z9200DAB. Also, the class 10 SD card seems make the device respond a bit faster. Good work! can you tell which file you used for z9200dab? 4400nex or 4500nex? Regards Quote Link to post Share on other sites
4500IlIll Posted October 28, 2023 Report Share Posted October 28, 2023 4400nex 1.00 firmware modded for 4500nex This one solved the issues of Bluetooth not auto reconnecting in Android and Android Auto not connecting that 1.02 has. https://1fichier.com/?yxrocgebhofeos5rbvi2 Quote Link to post Share on other sites
f9uah Posted November 21, 2023 Report Share Posted November 21, 2023 hdmi not working Quote Link to post Share on other sites
Join the conversation
