Roland Posted February 11, 2010 Report Share Posted February 11, 2010 Where do I find this data file? It does not appear in the links from pg40. Quote Link to post Share on other sites
Woods-Rider Posted February 12, 2010 Report Share Posted February 12, 2010 I dont see anywhere in any of the instructions for where I am supposed to use the "my flash disk" files that were in the 3.0 update download. What step am I actually putting the 3.0 firmware on my AVIC? And what is meant by "flash dump in step 9? I dont see a file with that name, but there is one called "dump files" in part 2 of the 3.0 download but it is empty. Quote Link to post Share on other sites
Woods-Rider Posted February 12, 2010 Report Share Posted February 12, 2010 I did the install with the files from megaupload that were linked on a previous page. The install worked but the "system startup" window does not dissappear. I can still use the unit and have verified that it is now version 3.0. How do I get the startup window to go away? I know I probably need to reinstall 3.0, but what do I need to do differently? I have tried it 3 times with the same result. Quote Link to post Share on other sites
MyITGuy Posted February 12, 2010 Report Share Posted February 12, 2010 Where do I find this data file? It does not appear in the links from pg40. Â Bottom of page 40 contains everything you need for the update. Â There are two files, you unrar part 1 and it will decompress the files from both part 1 & part 2 of the downloaded files. Quote Link to post Share on other sites
Woods-Rider Posted February 12, 2010 Report Share Posted February 12, 2010 Where do I find this data file? It does not appear in the links from pg40. Â Bottom of page 40 contains everything you need for the update. Â There are two files, you unrar part 1 and it will decompress the files from both part 1 & part 2 of the downloaded files. Â ok, so if I unrar 1 it will do 2 automatically? Does it also combine the files so that you don't have to copy files from 2 into 1 (or vise versa) to have a complete 3.0 update in one place? I unrared both separately and manually transfered files from 1 to 2 so I probably missed some or put them in the wrong place. Quote Link to post Share on other sites
jbustos88 Posted February 12, 2010 Report Share Posted February 12, 2010 need help cant get to edit to paste the info. is there a way to caliberate the screen? Quote Link to post Share on other sites
Woods-Rider Posted February 12, 2010 Report Share Posted February 12, 2010 Sounds like your winceimg files may be bad. Try using the ones from the megaupload links, those ones worked for me. Quote Link to post Share on other sites
jbustos88 Posted February 12, 2010 Report Share Posted February 12, 2010 is there another way to paste the information from the sd. i cannot get to edit to paste the information can any one help Quote Link to post Share on other sites
MyITGuy Posted February 13, 2010 Report Share Posted February 13, 2010 is there another way to paste the information from the sd. i cannot get to edit to paste the information can any one help  Yes, you can calibrate the screen in the control panel. Also, there is an icon on the desktop or start menu for a file manager that may make it easier. Quote Link to post Share on other sites
MyITGuy Posted February 13, 2010 Report Share Posted February 13, 2010 ok, so if I unrar 1 it will do 2 automatically? Does it also combine the files so that you don't have to copy files from 2 into 1 (or vise versa) to have a complete 3.0 update in one place? I unrared both separately and manually transfered files from 1 to 2 so I probably missed some or put them in the wrong place. Â Yep, unrar part 1 and it automatically knows to extract from part two. It's one big RAR file that is only broken into two pieces based on size. Quote Link to post Share on other sites
MyITGuy Posted February 13, 2010 Report Share Posted February 13, 2010 I dont see anywhere in any of the instructions for where I am supposed to use the "my flash disk" files that were in the 3.0 update download. What step am I actually putting the 3.0 firmware on my AVIC? And what is meant by "flash dump in step 9? I dont see a file with that name, but there is one called "dump files" in part 2 of the 3.0 download but it is empty. Â As noted in the post you took the links from: In Step 11, please copy the contents of the "My Flash Disk" folder on the SD Card to the My Flash Disk Drive on the AVIC Unit. Â Don't concern yourself with step 9, all the files you need are contained in the rar files that you extract and place on a single SD Card. Quote Link to post Share on other sites
jbustos88 Posted February 14, 2010 Report Share Posted February 14, 2010 Need help! Did the update. When I reseted the unit the screen was black. Need help. Now I can't get to music or anything the screen is just black. Any ideas? Quote Link to post Share on other sites
Woods-Rider Posted February 14, 2010 Report Share Posted February 14, 2010 Need help! Did the update. When I reseted the unit the screen was black. Need help. Now I can't get to music or anything the screen is just black. Any ideas? Â try it again. Check the files and keep trying it and checking the files until it works Quote Link to post Share on other sites
villtard Posted February 14, 2010 Report Share Posted February 14, 2010 Need help! Did the update. When I reseted the unit the screen was black. Need help. Now I can't get to music or anything the screen is just black. Any ideas? Â Do not copy the "My Flash Disk" file, and paste in the "My Flash Disk" drive. You need to copy the contents of the "My Flash Disk" file to the drive. Go into the "My Flash Disk" folder when in WINCE and go to "Edit," and "Select All." Copy all of the files and paste them to the "My Flash Disk" drive. Quote Link to post Share on other sites
Biker90 Posted February 15, 2010 Report Share Posted February 15, 2010 As promised, with about 15 minutes to spare:Here is everything you need in order to complete the upgrade as outlined in the original post, but with only 1 SD Card. I just recently picked up a F700BT that I updated this afternoon and love it...now I'm off to find some good mods =D Â http://www.megaupload.com/?d=K0WJSCUR http://www.megaupload.com/?d=XDPTH67G Â These files include the X Series WINCE Upgrade, Testmode 2.3 and the Backup Files/Maps. Â Hope this helps others who may be having problems finding torrents and etc... Â [edit]In Step 11, please copy the contents of the "My Flash Disk" folder on the SD Card to the My Flash Disk Drive on the AVIC Unit. Â I've had 2 people contact me regarding issues, they read that item literally and copied the entire contents of the SD Card to their AVIC which doesn't work[/edit] I have a f90 that needs to be fully restored it is blank . will this work? Quote Link to post Share on other sites
