peccosan Posted December 30, 2009 Report Share Posted December 30, 2009 Finally did the update. Thanks dragon24 and AVIC411. I had no issues at all another f700bt updated to 3.01. The guide isnt really that bad and it was REAL easy. Everything from the download to the install went smoothly for me. I used the 1 SD method because all of the files fit in a single 2gb card. For those who are having problems just use the one card method and place the testmode in as a folder and the image files in a folder as well and just have the 2 winCE update files in the root of the card. M4T VW: your 4gb NON-sdhc card might not be compatible with the device? because anything that is over 2gb sd is NON-conventional so you can try to do the single card method. that worked for me. Quote Link to post Share on other sites
kandhavelr Posted December 30, 2009 Report Share Posted December 30, 2009 Installed 3.0 in my 700bt, it was a clean walkthru. The touch screen response is far better. Quote Link to post Share on other sites
ScoobyDoo555 Posted December 30, 2009 Report Share Posted December 30, 2009 Where did you get your 1.5gb file from? (If you don't mind my asking!) Scoob/DAn Quote Link to post Share on other sites
kandhavelr Posted December 30, 2009 Report Share Posted December 30, 2009 Dl'ed from Megaupload... I had an account. Its too big to download for free. http://www.megaupload.com/?d=36VGFWTD Quote Link to post Share on other sites
tobsta Posted January 3, 2010 Report Share Posted January 3, 2010 So this update is fine to use with an US F900BT? Whst is the difference between the F90BT, F900BT and F700? With the last modification i did i had to delete the files before i could overwrite them because there wasnt enough space on the drive. Is is safe to just delete everything on flash disk and replace is with all the files included in the update? Cheers Toby Quote Link to post Share on other sites
MyITGuy Posted January 4, 2010 Report Share Posted January 4, 2010 Here is everything you need in order to complete the upgrade as outlined in the original post, but with only 1 SD Card. I just recently picked up a F700BT that I updated this afternoon and love it...now I'm off to find some good mods =D http://www.megaupload.com/?d=K0WJSCUR http://www.megaupload.com/?d=XDPTH67G These files include the X Series WINCE Upgrade, Testmode 2.3 and the Backup Files/Maps. Hope this helps others who may be having problems finding torrents and etc... [edit]In Step 11.1, please copy the contents of the "My Flash Disk" folder on the SD Card to the My Flash Disk Drive on the AVIC Unit. I've had 2 people contact me regarding issues, they read that item literally and copied the entire contents of the SD Card to their AVIC which doesn't work[/edit] Quote Link to post Share on other sites
tobsta Posted January 4, 2010 Report Share Posted January 4, 2010 Thankyou so much. I was stressing after i did the upgrade with the megaupload upload after realising it was the IDT mod. Your a lifesaver... downloading them as we speak. Hopefully it works. Quote Link to post Share on other sites
ScoobyDoo555 Posted January 4, 2010 Report Share Posted January 4, 2010 Bugger. Bl00dy thing is unavailable Will try later, but thanks anyway Scoob/Dan Quote Link to post Share on other sites
Ray303 Posted January 11, 2010 Report Share Posted January 11, 2010 This worked well for me too -- thanks!! Here's what I did since I did not have a 2GB SD card handy: [*] Copied WINCEIMG.BIN & WINCEIMG.CKS to the root directory of the SD card. [*] Copied the testmode folder to the SD card [*] Copied the back up files to a USB drive. (This is the large batch of files at around 1.6GB) [*] Connected the USB drive to the USB port on the F90BT [*] Followed the steps as described, but simply copied the back up files from the USB drive at the stage where you are in test mode using Windows CE. USB drives are generally faster than SD cards, but this is just an alternate way of accomplishing the same thing. Later downloaded 3.101 F910BT update from the Pioneer web site and installed that. No problems so far. Quote Link to post Share on other sites
ProInstaller Posted January 18, 2010 Report Share Posted January 18, 2010 Did you get your firmware from the european pioneer site?? It looks like they have 2 firmwares available/ 1 for the avic f900bt and one for the avic f910bt.. Just to verify you downloaded the one for the 910bt instead of the 900bt? Quote Link to post Share on other sites
ProInstaller Posted January 19, 2010 Report Share Posted January 19, 2010 Thanks so much guys and avic411. Just upgraded my f90bt to 3.0 using Ray303 idea with the thumbdrive. Works Perfectly!! Now im on to upgrading to 3.02 Quote Link to post Share on other sites
lollotissi Posted January 19, 2010 Report Share Posted January 19, 2010 Hi! Can i update the 3.0 version directly on top of version 1.0? or is needed 2.0 first update and then 3.0? and after that did "hacked" EZRIDER.exe works ( I use Europe Map on US F900BT) Thanxx-- Quote Link to post Share on other sites
Major_Malfunction Posted January 27, 2010 Report Share Posted January 27, 2010 Just did this upgrade twice on my F7010BT When hitting the map menu and eject buttons and htting reset i dont get a pop sound but if i release reset i hear the cd drive and release eject and then i get the blue screen and can proceed as normal to do the update Everything goes ok during the update and the unit restarts fine Everything works except for bluetooth when pressing the phone button the unit just beeps but wont change screens etc When the unit starts up the bluetooth led flashes for a second and then goes out Have done the update twice with the same results no phone no bluetooth Have done a search but cant find much on this issue Anyone have any ideas or can offer any help ? If not where can i find the files to restore my unit to 2.0 with working bluetooth Thanks MM Quote Link to post Share on other sites
Major_Malfunction Posted January 27, 2010 Report Share Posted January 27, 2010 I also just noticed i have no working voice commands When i press the large button in map mode i hear the normal beep but the voice command screen doesnt come up Quote Link to post Share on other sites
